Jager | 21/07/2020 10:55:41 |
38 forum posts 5 photos | I want to fit a wedge type qctp to my Warco WM240. The problem I have is that the existing toolpost stud is pressed into the slide top via a boss. This boss prevents a qctp from sitting down on the compound top and if I machine the boss off I fear that the remaining metal will be to weak. An alternative would be to machine a recess in the qctp some 22mm dia x 22 deep. As I have hesitated to buy a new toolpost and find t is no good I wonder if anyone here has done as I propose. Obvious questions are; is there enough meat in these wedge type toolposts and are they too hard to machine?
William Chitham | 21/07/2020 11:10:48 |
139 forum posts 57 photos | Could you make a big washer/spacer to fit round the boss for the toolpost to sit on? |
Jager | 21/07/2020 11:28:03 |
38 forum posts 5 photos | I did look at the possibility of using a packing piece but this would raise the new toolpost so much it would prevent me getting the too on centre. |
Tony Pratt 1 | 21/07/2020 11:41:46 |
1971 forum posts 12 photos | Just machine the boss off the stud until it is below the top slide surface, why do you think doing this will weaken it? I have a WM 290V & when I fitted a wedge type tool post I actually made a new stud. Tony |
Journeyman | 21/07/2020 11:50:49 |
![]() 1159 forum posts 235 photos | You cannot machine out the bore of a wedge type tool-post, there is not enough meat on the central tube that holds it all together. The boss can be machined off or reduced in diameter to fit the tool-post. See Journeyman's Workshop for details of fitting wedge type tool-post to my WM250, it is over a couple of pages as it includes making a a toolpost mount for the cross-slide as well. John |
Jager | 21/07/2020 12:03:16 |
38 forum posts 5 photos | Posted by Tony Pratt 1 on 21/07/2020 11:41:46:
Just machine the boss off the stud until it is below the top slide surface, why do you think doing this will weaken it? I have a WM 290V & when I fitted a wedge type tool post I actually made a new stud. Tony I feel the boss is part of the compound casting essential for the strength/integrity of the whole and machining it off would leave a very thin section for fitting the stud to. |
mechman48 | 21/07/2020 12:14:28 |
![]() 2947 forum posts 468 photos | I fitted a Bison QCTP ( Dickson clone ) to my WM 250V-F, I had to machine the boss off as I had similar problem, plus the original post was smaller than the block so I had to make a new post to fit so far it has worked just fine, getting on for about 7 years now. i still have the original 4 way tool post so if I ever need to use it again all I need to do is make a spacer to fit the 4 way post, not difficult to do. George. |
BC Prof | 21/07/2020 12:28:32 |
166 forum posts | On both the 280 and gh600 I found that the stud and boss was held in place by a roll pin accessed from. the underside and hence not part of the casting .
Brian |
Tony Pratt 1 | 21/07/2020 13:51:10 |
1971 forum posts 12 photos | Is the boss not part of the stud? Tony |
mechman48 | 21/07/2020 15:01:21 |
![]() 2947 forum posts 468 photos | Posted by Tony Pratt 1 on 21/07/2020 13:51:10:
Is the boss not part of the stud? Tony No the boss is part of the casting. When I did my WM250 I had to remove the anti rotation roll pin from the stud / post via underside of the top slide ( you have to remove the top/compound slide on the WM 250 ) then the stud / post will tap out, then you can machine off the casting boss, then make up a new stud / post to suit your new QCTP. Does your WM240 manual not have a page that shows exploded view of the top slide? George. |
Tony Pratt 1 | 21/07/2020 15:55:26 |
1971 forum posts 12 photos | Ah the 240 must be different, my WM 290V Warco topslide is flat & the stud had a stepped diameter. Tony |
Jager | 23/07/2020 12:09:55 |
38 forum posts 5 photos | Thank you gents for your observations which point me in the direction of machining off the boss and making a new stud. Due to my natural caution and inexperience in these matters I am still hesitant despite your various experiences. As your mods have been to larger machines I wonder if they have thicker castings. I am now trying to find out if a piston type toolpost is capable of being machined out to allow me to retain the boss. Again, many thanks for your input. |
Donald Williamson | 23/07/2020 14:43:53 |
18 forum posts | Hi I to have a warco lathe which I have had for a few years prior to it I had a clark lathe and mill and i purchased a qctp for it, I to discovered your problem using it on the warco what I did was to bore the qctp to accommodate the boss on the top slide I also had to alter the 4 recesses to under the qctp to suit the locating pin, I hope this helps. My qctp was from arceurotrade. |
Jager | 23/07/2020 14:50:34 |
38 forum posts 5 photos | Posted by Donald Williamson on 23/07/2020 14:43:53:
Hi I to have a warco lathe which I have had for a few years prior to it I had a clark lathe and mill and i purchased a qctp for it, I to discovered your problem using it on the warco what I did was to bore the qctp to accommodate the boss on the top slide I also had to alter the 4 recesses to under the qctp to suit the locating pin, I hope this helps. My qctp was from arceurotrade. Thanks for the response. Is yours the piston, or wedge type? I have been advised there is insufficient meat in the wedge type to bore out for the boss. Was the qctp hardened and difficult to machine? |
mechman48 | 23/07/2020 15:01:47 |
![]() 2947 forum posts 468 photos | As I understand it; & from other posters, it can be bored out but preferably with a carbide insert / tip tool as these QCTP generally have very hard / case hardened skin. Try a file across a corner / edge if it skips it's hardened. George. |
Jager | 25/07/2020 18:19:37 |
38 forum posts 5 photos | Job done! Bowed to superior knowledge and machined the boss off and made a new stud. Incidentally the old stud needed an inordinate amount of pressure to remove so I applied some heat and then pressed it out, I suspect there was some epoxy in there. Thank you one and all. |
John Templeman | 11/03/2021 19:51:06 |
20 forum posts 15 photos | Jager, I too have a Warco WM240 could you tell me which QCTP you fitted to your lathe as I am not sure which to buy for mine Regards John |
