Fiber change gears
Lee Reynolds 117/07/2020 10:39:05
6 forum posts
Hi,
When I get it up and running I will have a change gear set on my Harrison M300 that will comprise a combination of metal, fiber and Delrin gears.
Do I lubricate the set, and if I do, what do you more experienced machinists suggest I use.
I seem to remember reading somewhere that nylon should not be lubricated, is Delrin the same?
Lee
Andrew Johnston17/07/2020 10:56:08
6217 forum posts
676 photos
My M300 has the original steel and Tufnol change gears. I give them an occasional squirt with ISO68 slideway oil as per the manual.
Ronald Morrison17/07/2020 11:14:09
70 forum posts
4 photos
Delrin should not need lubrication buy shouldn't be harmed by lubrication either.
Circlip17/07/2020 11:41:31
1327 forum posts
Nylon absorbs water and even the "Low" absobtion rated Nylon 6 or 6-6 does to a lesser extent. Tufnol should not be lubricated, it's a layered material.
Regards Ian.
Swarf, Mostly!17/07/2020 12:05:35
604 forum posts
62 photos
Posted by Circlip on 17/07/2020 11:41:31:
Regards Ian.
Hi there, Ian,
Are you suggesting possible delamination?
Best regards,
Swarf, Mostly!
not done it yet17/07/2020 12:05:52
6263 forum posts
20 photos
Posted by Andrew Johnston on 17/07/2020 10:56:08:
Exactly this. As per page 8 of the user manual. Or rather ‘daily’, perhaps?
john halfpenny17/07/2020 12:08:15
185 forum posts
25 photos
Henry Ford used layered tufnol for camshaft gears on millions of cars. Later he used macerated tufnol, and later still a type of nylon. No problems from engine oil.
Nicholas Wheeler 117/07/2020 12:23:20
719 forum posts
50 photos
Posted by john halfpenny on 17/07/2020 12:08:15:
Although the nylon teeth on V6 cam gears are a notorious week point.......
Lee Reynolds 117/07/2020 13:09:12
6 forum posts
Sorry Gentlemen it,s the fiber gear I am more concerned about. It came from 600 group as it was an original gear but missing from my S/H machine.
For the price I expected a metal one....silly me! and then the lubrication advice in the manual would make sense and be followed.
Lee
Michael Gilligan17/07/2020 13:20:08
18700 forum posts
912 photos
dont know
Certain grades of Tufnol are used for propeller shaft bearings ... totally immersed in, and lubricated by, water.
A little light reading: http://ahistoryoftufnol.org/whatistufnol/
and ... https://www.tufnol.com/technical/technical_materials.aspx
Edited By Michael Gilligan on 17/07/2020 13:30:35
Dreweatts
rapid Direct
JD Metals
walker midge
