Can a Wiggler be Used Horizontally?
Steven Volz13/07/2020 12:53:40
9 forum posts
I found a post saying 'yes' to this question with an expired link. Will someone please give me a definitive answer couched in terms suitable for the hard of thinking. Ta.
Tim Stevens13/07/2020 13:02:21
1205 forum posts
If you are using a wiggler to line up the axis of one part (which can be rotated) with marks etc on another part then the orientation does not matter. It can be dome with the point upwards, downwards, or sideways, or any angle in between.
This answer is based on my experience - exactly how you define 'definitive' is not clear, but I hope it helps.
Regards, Tim
Bazyle13/07/2020 13:25:26
5295 forum posts
201 photos
Read old copies of ME. That's how they were invented - long before model engineers had mills.
Clive Foster13/07/2020 13:27:57
2254 forum posts
76 photos
Huffam explicitly say that their version of the wiggler can be used both horizontally and vertically.
Indeed the instruction leaflet shows it in horizontal orientation. But that is probably because it gives a better print and figure layout.
However the Huffam is rather better engineered and better behaved than the common £5 or £10 set.
EngineDIY
