simple tongs
celso ari schlichting10/07/2020 21:44:08
112 forum posts
how i make this simple tongs:
https://youtu.be/O1FS9KktKH4
Greetings from Brazil
Celso Ari
IanT11/07/2020 10:16:10
1613 forum posts
151 photos
I liked the small welded fabrication aspect Celso, simple MMA and it looked vey good after grinding. The oil quench was a bit hairy - definitely an outside job.
A well made and useful Blacksmiths tool though. Well done and thank you for sharing!
IanT
Grizzly bear11/07/2020 18:50:34
252 forum posts
8 photos
Very good, you made it look easy. But many operations.
I too liked the pivot.
Do you read the English OK, or do you translate?
Regards, Bear..
celso ari schlichting11/07/2020 21:18:08
112 forum posts
Posted by IanT on 11/07/2020 10:16:10:
IanT
Thanks Ian...Regards from Brazil
celso ari schlichting11/07/2020 21:22:41
112 forum posts
Posted by Grizzly bear on 11/07/2020 18:50:34:
Regards, Bear..
Dear friend Bear, I understand a little English, I get a little confused when people
use slang or very technical or specific words, except that I can communicate
reasonably well
DMB11/07/2020 21:59:28
1014 forum posts
Celso Ari,
If you do not understand a word, try the translator and if its still a bit confusing, private message the person who posted it. Never be afraid to ask, one or more of us will try to explain things. Not helpful that there is different slang used in different areas of UK and some things have a different name depending on which part of the country. An English Lake is an Irish Lough or a Scottish Loch. There are many more examples.
DMB11/07/2020 22:22:00
1014 forum posts
Celso Ari,
Just watched your youtube on making tongs. Thanks for sharing. I like your design of the joint, might make a set of tongs using your design.
Bill Dawes12/07/2020 13:21:11
363 forum posts
Well done, greetings from Somerset in the UK. Something I have been thinking about for a while so this has given me some inspiration, It is about time i used my welder I have buried in the back of the garage, never used it enough to get past the stick welding itself to the job! Thank you for sharing, interesting to see how many different parts of the world we get posts from on this forum.
Best regards
Bill D.
Michael Gilligan12/07/2020 18:30:06
16365 forum posts
714 photos
The best translator I have found is DeepL
O melhor tradutor que encontrei é DeepL
https://www.deepl.com
Edited By Michael Gilligan on 12/07/2020 18:31:21
celso ari schlichting13/07/2020 23:12:45
112 forum posts
Posted by DMB on 11/07/2020 22:22:00:
Celso Ari,
Thanks John, I'm glad you liked it ... a big hug from Brazil
celso ari schlichting13/07/2020 23:15:19
112 forum posts
Posted by Bill Dawes on 12/07/2020 13:21:11:
Best regards
Bill D.
Bill, a welding job always helps in completing a project and is one of the things that I use a lot in the workshop
Cheers
Celso Ari
celso ari schlichting13/07/2020 23:16:55
112 forum posts
Posted by Michael Gilligan on 12/07/2020 18:30:06:
Michael, i will definitely use it soon, thanks for sharing
EngineDIY
