Bob Wild | 25/06/2020 22:39:18 |
86 forum posts 63 photos | I came across this article in a 1908 model engineering magazine: **LINK** My ambition always exceeds my ability so I thought I would share my progress and hopefully get some helpful advice from the experts here. My first problem was the fact that the drawings only contained a minimum of dimensions; not the sort of detail you would expect from today’s drawings. Fortunately I came across some detailed drawings from Julius de Vaal, so that was a relief, see below:
First the chassis. Not a problem so far, except the design called for channel section. I could only find some box section so I had to remove one side.
Next up the front and rear suspensions, more to follow
Bob |
V8Eng | 25/06/2020 23:56:06 |
1701 forum posts 1 photos | This guy has made an excellent one (not sure of relative models etc) and posts progress on this forum, it may be worth you contacting him by PM. I am putting a link here to his forum posts:- Edited By V8Eng on 26/06/2020 00:05:30 |
Werner Schleidt | 26/06/2020 15:41:58 |
![]() 147 forum posts 179 photos | Hello Bob, in 2014 i start to build my Fire King. My only possibility was to search in the Internet after pictures of the Fire King. I found the same plans as you and after i compare them to the pictures i thought they made their own compromises to build working models. So i decided to make my own way . And it was clear from the beginning it is a working model it should looks similar to the original, but from two meter of distances . That was my compromise. I made only an overwiew drawing and drawings for the wheels. The rest you can see in my documentation in the videos . After finishing i found an interesting book written by Ron Henderson " British Fire Engines" there are nice pictures and descriptions. And it was good to read with my limited English. By chance i had contact with him and he had a Fire KIng in display quality and his reply was it was good to build a working model. I think both is good , but i want fun by a real working model. Shortly before I am ready i had contact to the company Merrywheather and they send me some asked information about the front seat box. It contains hoses and fireman tools. I had several moments where i have to learn and shift my abilities to a new level. I wish you can do the same. Werner Ps. If you can access the issue 3334 from Modelengineer there is a discription of Cherry Hind´s Fire King many useful information i had after the completion of the build. Thanks to Vic Edited By Werner Schleidt on 26/06/2020 15:42:53 cause of typos Edited By Werner Schleidt on 26/06/2020 15:46:00 |
Werner Schleidt | 26/06/2020 16:21:41 |
![]() 147 forum posts 179 photos | Hello Bob, take a look to this link there are a few good old pictures that was one source for me. Werner |
Bob Wild | 26/06/2020 22:33:06 |
86 forum posts 63 photos | Posted by V8Eng on 25/06/2020 23:56:06:
This guy has made an excellent one (not sure of relative models etc) and posts progress on this forum, it may be worth you contacting him by PM. I am putting a link here to his forum posts:- Edited By V8Eng on 26/06/2020 00:05:30 Thanks V8Eng. I’ve had a look at Werner’s posts - very interesting and helpful |
Bob Wild | 26/06/2020 22:55:22 |
86 forum posts 63 photos | Posted by Werner Schleidt on 26/06/2020 16:21:41:
Hello Bob, take a look to this link there are a few good old pictures that was one source for me. Werner Thanks Werner. You’ve certainly built a great model and posted some great videos. I don’t think mine will be capable of riding on, but I would like it to be a working model. The boiler fills me with dread since there is so much silver soldering to do. But that is some time in the future. I am prepared to make a few compromises, for example since I have no castings the pumps will be prefabricated. Also not to happy about making the crankshaft with the valve eccentrics in the proper position. So I am going to use two Stuart 10V cylinders mounted back to back. By doing this I can fit the eccentrics from either end. Also I can’t imagine making the wheels in wood at my scale, so I will prefabricate them in steel. |
Bob Wild | 27/06/2020 22:50:03 |
86 forum posts 63 photos | My efforts at hardening and tempering spring steel were a disaster so I gave in and decided to make the leaf springs out of ms. This is my homemade bender which worked well I made a fixture to form the eyes And this is the result Finally I assembled both the front and rear suspensions and painted them.
Bob Wild | 02/07/2020 00:47:09 |
86 forum posts 63 photos | Steering components Front assembly Thought I’d better paint the model so far. To stop it rusting and get a bit of Fire Engine Red !!! |
Bob Wild | 02/07/2020 00:51:47 |
86 forum posts 63 photos | Next up the water pumps, a lot of machining here |
Bob Wild | 03/07/2020 21:28:58 |
86 forum posts 63 photos | The most interesting part of the water pump is the air cylinder. The original design was a bit boring so I decided to use the design of Tubal Cain which he used for his Lady Stephanie bean engine. This had a fluted cylinder and a relief valve.
Turning the end with my homemade ball turning attachment
The final assembly
Bob Wild | 03/07/2020 23:33:33 |
Hello Bob, take a look to this link there are a few good old pictures that was one source for me. Werner Thanks Werner. I will be happy if my machine is half as good as yours. I’ve got a copy of the Henderson book, and it does contain lots of interesting info. I’m going to try etching the nameplate as you have done, but I think that will be some time in the future. At the moment I’ve nearly finished the pumps and the cylinders. But I’m so worried about how to line everything thing up. I was thinking I might use some dummy pistons connected with a rod so I can bolt them all together. Then I can also clamp the pumps to the water cylinder. Bob
Werner Schleidt | 04/07/2020 06:08:16 |
![]() 147 forum posts 179 photos | Hello Bob, your parts are looking good. One hint if you want to etch rhe nameplates there is a free software "inkscape" . With this software i was able to overlay photos of plates and make the vector graphics of the plate. Then you can delete the photo layer and the vector graphic you can scale as you want. Then you have to make a mirrored print out at nomal paper with a laser printer at high resolution. The next step is spray non coloured piant from the side where no toner is. This give you a cheap template. Etching last an hour for 0.1 mm deepness. Unfortunatly my inscape data is lost by a drive crash. Werner
Bob Wild | 04/07/2020 12:49:56 |
86 forum posts 63 photos | Thanks Werner, I'll bear that in mind. Bob |
Bob Wild | 04/07/2020 12:52:19 |
86 forum posts 63 photos | Here's the ball turning photo that I have been having such problems with: I'm actually quite proud of the attachment as it does just what I wanted. Bob |
Bob Wild | 04/07/2020 12:54:48 |
86 forum posts 63 photos | THe only problem I have now is that 'Er Indoors wants to spend more time outdoors with the easing of the lockdown restrictions. So I'm taking her to the Yorkshire Dales in our caravan. Model Engineering on hold for a while |
Nick Clarke 3 | 04/07/2020 13:36:04 |
![]() 1423 forum posts 63 photos | Posted by Bob Wild on 04/07/2020 12:54:48:
THe only problem I have now is that 'Er Indoors wants to spend more time outdoors with the easing of the lockdown restrictions. So I'm taking her to the Yorkshire Dales in our caravan. Model Engineering on hold for a while Do you think she would notice? |
Bob Wild | 14/07/2020 22:48:05 |
86 forum posts 63 photos | Posted by Nick Clarke 3 on 04/07/2020 13:36:04:
THe only problem I have now is that 'Er Indoors wants to spend more time outdoors with the easing of the lockdown restrictions. So I'm taking her to the Yorkshire Dales in our caravan. Model Engineering on hold for a while Do you think she would notice? Brilliant, I want one |
Bob Wild | 06/08/2020 00:09:22 |
86 forum posts 63 photos | Disaster! Just finished the cylinder bottom cover. Discovered to my horror that one of the studs in each cylinder will pass straight through the inlet steam passage. I suppose that's what you get when you try to change someone else's design on the fly and don't think far enough ahead. So I have a few choices:
Not sure the best course of action. Any advice would be most appreciated. Edited By Bob Wild on 06/08/2020 00:11:00 |
Paul Lousick | 06/08/2020 04:12:45 |
2043 forum posts 722 photos | Hi Bob, Don't give uo Bob, we all have done something similar. And one of the reasons that I modelling everything in 3D CAD, allowing me to check the compatability with mating parts. It looks like there is still more work to do before it is finished so I would start again. Making a second set is often quicker than the first and you will feel better when the model is complete. Look on the bright side. You get to enjoy more of your hobby. Paul |
Werner Schleidt | 06/08/2020 12:48:30 |
![]() 147 forum posts 179 photos | Hi Bob, make ten studs and one blind stud in the cover with a dummy nut. That will be easy to make. Sometimes shit happens and a good modelengineer make the best of it. Werner |
