Gear software
mick H19/06/2020 08:03:38
766 forum posts
28 photos
I recently asked for information on types of wood suitable for making gears and had a very generous and helpful response. May I now take this a step further and ask whether anyone knows of software into which one can input gear data ie pcd, number of teeth and module and obtain a two dimensional printout of the gear. This is for my son who needs to make wooden gears for a project. His hope is to glue a paper image of the gear onto suitable wood and cut around it.
Mick
Michael Gilligan19/06/2020 08:14:36
20113 forum posts
1044 photos
If he has an iOS device, and is happy with Involute gears ...
Easy Gear is probably all he needs: **LINK**
https://apps.apple.com/gb/app/easy-gear/id1197863906
Edited By Michael Gilligan on 19/06/2020 08:16:51
SillyOldDuffer19/06/2020 08:45:47
8516 forum posts
1915 photos
Quite a few if you dig around:
Online, via a browser **LINK**
Software:
Specifically for wooden gears
GearDXF is popular, and I think I've used it under wine on Linux.
There's a gear drawing tool in Inkscape. (Slight learning curve, it's part of a much larger vector drawing package.)
Not tried it, an add-on for QCAD : **LINK**
I usually use the gear tool in FreeCAD, I think there's one in Fusion360 too, and likely in other CAD packages. But getting into general purpose CAD tools just to draw a few gears is hard work!
Peter G. Shaw19/06/2020 09:01:14
1413 forum posts
44 photos
Asuming external or spur gears, it is surprisingly easy to draw involute gears using a basic CAD package - as long as you are familiar with all the CAD packages commands. Ivan Law's book in the Workshop Practice Series shows how to draw the teeth using an acceptable shortcut. The general idea is to draw one tooth, and then copy it however many times around the circle.
If you have access to it, MEW290 includes an article from me which goes into this.
I must admit that initially it does seem daunting, but then once one is done, it becomes a lot easier.
Peter G. Shaw
mick H19/06/2020 13:29:33
766 forum posts
28 photos
Thank you gents. Just what he needs.
Mick
Bill Davies 219/06/2020 13:52:45
278 forum posts
11 photos
Perhaps cut a base circle from plywood, plus a length of string and a pencil, which would provide a suitably accurate involute for this project. Or even get the long-unused compass set and protractor out, and draw it.
Bill
Bill Davies 219/06/2020 14:10:53
278 forum posts
11 photos
To show it's not too tedious to draw the curve, here's part of a scan of an A3 drawing I made a few weeks ago to give me some idea of the error between a circular arc and an involute, so I haven't actually drawn the involute, just tested various radii to detemine the fit. It's not very clear because the pencil drawing was quite light; I've attempted to increase the contrast. The scan is in my album.
Bill
Adam Mara19/06/2020 15:57:20
167 forum posts
8mm Foamex PVC gears cut on small CNC router using the Wooden Gears software, this is a prototype final version will probably be Perspex, Its for controlling a water valve using a Arduino Uno and a L298 motor driver, Another of my crazy projects!valve gears.jpg
DC31k19/06/2020 20:43:06
662 forum posts
All good suggestions. Could I add one more thing please?
If he is to go the 'print out' route, try to print a line of a known dimension on the same sheet then check it with a ruler. If you calculate the gear diameter beforehand, you can even use the printout itself.
Some printers have issues with scaling and especially if printing something near to the size of the sheet of paper can do unexpected things. You need to check in both X- and Y-directions until you are confident that printing something 100mm dia. actually comes out on the paper as 10mm diameter.
Michael Gilligan20/06/2020 08:48:09
20113 forum posts
1044 photos
Posted by DC31k on 19/06/2020 20:43:06:
An excellent point yes
... and, if I might add, nicely addressed by options in Easy Gear
Dreweatts
Rapid RC
