Wot's this for ? help please
Stewart Hart17/06/2020 08:58:17
651 forum posts
354 photos
I bought a spindle and drive belt for a project I'm developing as part of the kit there was a small "C" clip that I can't for the life of me work out where it goes see attached picture, its got something to do with the bearing assembly but that's as much as I can work out there is no obvious place for it to go. Can any one shed a bit of light on this mystery
Brian Wood17/06/2020 09:17:37
2270 forum posts
37 photos
Stewart,
I looks as though it should retain a bearing, perhaps the right hand one on the mounting block that doesn't look as though it is fully home.
Other views may help
Regards Brian
Bo'sun17/06/2020 09:25:15
202 forum posts
I agree, the "C" clip groove might be obscured by the bearing.
JasonB17/06/2020 09:28:27
18875 forum posts
2078 photos
I would say it just slips loosly onto the shaft between read bearing and toothed pulley as a crude spacer so the pully boss does not rub against the bearing's outer race. Better to bin it and turn a small spigot onto the pulley boss or make up a thrust washer as position of pulley sets the end float.
There are usually no grooves in the spindle on these items.
Edited By JasonB on 17/06/2020 09:29:58
Stewart Hart17/06/2020 09:29:14
651 forum posts
354 photos
Hi Brian that was my thoughts but it’s a lose fit on the shaft there’s no groove on the shaft or in the bearings for it to fit the bearings which are flanged are fully home
Stew
Stewart Hart17/06/2020 09:51:31
651 forum posts
354 photos
Hi Jason
I was thinking it was something to do with end thrust the shaft is a tight fit in the bearings but I cannot see how end thrust when drilling will be restrained I’m intending to use Loctite to fix the bearings better and ditch the clip
Thanks for your input chaps
Stew
Nicholas Farr17/06/2020 10:55:40
2438 forum posts
1193 photos
Hi Stew, maybe the shaft has moved in the bearings one way or the other and there might be a groove hiding under one of them.
Regards Nick.
Phil P17/06/2020 11:11:03
657 forum posts
166 photos
The clip could not have just dropped off the shaft if that is where it fits.
Was the whole thing assembled like that when it arrived ?
Phil
JasonB17/06/2020 11:16:17
18875 forum posts
2078 photos
To save any more suggestions If you look at the many of these on e-bay etc none have grooves but all have the ring
Stew I would say that the larger dia at the base of the chuck taper should go against one bearing to take the drilling pressure and the pulley slid up to take out and play.
Edited By JasonB on 17/06/2020 11:19:27
not done it yet17/06/2020 11:17:13
5010 forum posts
20 photos
Have they supplied a ‘c clip’ instead of a ‘chuck key’?
JasonB17/06/2020 11:21:45
18875 forum posts
2078 photos
Found itsmiley From the same set of images to the ones I posted above
Edited By JasonB on 17/06/2020 11:22:37
Stewart Hart17/06/2020 11:40:23
651 forum posts
354 photos
Hi Chaps
I think Jason is correct its just a crude spacer to go between spacer and pulley to take some of the thrust, as for the other end I'm going to fit a sleeve between the slightly larger collar diameter and the bearing locating on the inner race this should take up the thrust, I'm unsure wether to fit another spacer between the two bearing again on the inner race so that they share the thrust. I want to see just what duty these spindle will do, there's a few videos of them in use doing light work.
Just what I'm planning to do with it you'll have to wait until next week some time when I've got the fixture completed I'll post a video of it in action hopefully:- its another bit of pottyengineering devilry devil.
Stew
duncan webster17/06/2020 13:01:43
2795 forum posts
41 photos
If they are flanged bearings then if you attempt to apply end load to the one at the pulley end won't it just be pushed out of its housing?
Edited By duncan webster on 17/06/2020 13:03:29
not done it yet17/06/2020 13:30:56
5010 forum posts
20 photos
The clip appears to be a simple spacer, rotating with the shaft/pulley/inner race to crudely prevent the pulley bearing on the outer race. As those components are all totating at the rame speed there should not be a problem. A small diameter washer would suffice just as well.
Are both bearings properly designed to accept axial thrust, I wonder?
Ian P17/06/2020 14:20:51
2420 forum posts
101 photos
Posted by not done it yet on 17/06/2020 13:30:56:
I think products like this one a mainly 'designed' with saleability as the first priority, performance and longevity are further down the list.
I doubt the bearings are anything special.
I bought a 'Dremel' type power tool that looked quite good in the pictures. It has a cylindrical aluminium body and is fitted with a 1/4" Jacobs type chuck, it also has a supplied 24VDC power supply with speed control all came in a nice moulded carrying case. Now its arrived I find it near useless, It has a brushed motor bonded (I think) into the ali tube outer case and the chuck is bushed in some way so that it fits the 3mm motor spindle (not removable). It has the about 3mm axial freedom in the motors plain bearings and obviously no provision made for thrust.
Yes, it a hand power tool and it was not expensive but not one I would recommend
Ian P
EngineDIY
