Another mystery tool
Ian McVickers15/06/2020 19:40:44
188 forum posts
89 photos
Came across this mystery tool today and I can only guess at what it is for.
There is not a makers name on it unless the info on the dial is it. The machined surfaces are parallel to each other. The gauge has an elephants foot on it and when laid on a flat surface the dial moves a bit and would allow a positive and negative movement if ran over an uneven surface.
HOWARDT15/06/2020 20:36:21
617 forum posts
15 photos
D.R.P.a. signifies Deutsches Reichpatent angemeldet ("German Reich patent applied for".
HOWARDT15/06/2020 20:37:56
617 forum posts
15 photos
Don’t know where the smiley came from, a copy and paste gremlin. But as for the question probably a sheet thickness gauge.
peak416/06/2020 00:19:03
1250 forum posts
145 photos
I don't know its designed purpose, but I use something similar but smaller for setting the blades in the block on my woodworking planer thicknesser.
It's interesting in that it had ground feet on both sides, unlike mine, so I'm guessing neither a flatness nor a thickness gauge.
Bill
Nigel Graham 216/06/2020 00:35:05
802 forum posts
16 photos
I am as mystified and intrigued as you are on this gauge's purpose, and it does look very specific such as setting a particular type, make and model of machine-tool; but I can tell you where the smiley is from.
The quote marks at the end of a word, 'for ' in this case, generate it.
As in "wretched smileys " or "wretched smileys" - with the punctuation mark against the letter.
Nigel Graham 216/06/2020 00:36:10
802 forum posts
16 photos
Typical - it didn't work as it usually does!
Hopper16/06/2020 02:08:22
4876 forum posts
106 photos
" Its the bracket wot does it. In conjunction with the quote mark. Leave a blank space both sides of the bracket and all is well. " )
Edited By Hopper on 16/06/2020 02:11:02
John Haine16/06/2020 06:47:22
3422 forum posts
184 photos
Do the units of the gauge give any clue?
Ian McVickers16/06/2020 20:15:14
188 forum posts
89 photos
Thanks for the info on the patent. Ive had a quick look through the info on the patent website but no much to go on so far. The increments on the dial are 0.1mm.
mark costello 117/06/2020 00:16:12
613 forum posts
12 photos
If You could look at Robin Renzetti's Repeat-0-meter it looks similar. It can have myriad uses.
mark costello 117/06/2020 00:16:36
613 forum posts
12 photos
Please delete.
Edited By mark costello 1 on 17/06/2020 00:17:42
John MC17/06/2020 08:25:06
317 forum posts
38 photos
No idea what it is. I wonder if its war reparation?
D.R.P.a. signifies Deutsches Reichpatent angemeldet ("German Reich patent applied for". Got me thinking that might be so, not sure it helps identify it's use though.
Nicholas Farr17/06/2020 09:13:04
2479 forum posts
1198 photos
Hi, I don't know what it is for, but if it was for flatness, I would expect the needles to be showing zero when placed on something flat and why would it have ground feet on the opposite side of the plunger? Do the needles rotate in the same direction or in opposite directions? My guess it's a setting gauge for a specific machine/s with left and right or up and down or even all four, adjustment situations and the ground feet would sit in a precise location.
Regards Nick.
Ian P17/06/2020 14:32:28
2439 forum posts
101 photos
Is mention of 'needles' above relevant? i.e. are there indicator dials on the front and back of this tool or just the one?
The scale markings are a bit odd too in that it has four quadrants.
Is there some zero setting adjustment that does not show in the pictures, also what is the total travel of the plunder?
Still not got a clue what its purpose was
Ian P
old mart17/06/2020 14:43:52
2201 forum posts
164 photos
It may be a specialised single purpose tool, to be used both ways up to measure something like the slot on the rear of a gun breech for the sliding block.
Michael Gilligan17/06/2020 15:57:41
16632 forum posts
724 photos
Posted by Ian P on 17/06/2020 14:32:28:
The first two pictures would show that to be the case
Ian McVickers17/06/2020 19:11:12
188 forum posts
89 photos
Total travel is just under 4mm. Laid on a flat surface the dial travels 2mm so would then have 2mm travel in either direction. No zero set or any other adjustments. The needles on both sides rotate in the same direction. I havent found anything myself yet but will keep looking.
Dick H17/06/2020 19:19:31
95 forum posts
How about using it to decide whether the upper surfaces of two plates/ or railway tracks are level before welding / tightening a joint?
old mart17/06/2020 19:41:45
2201 forum posts
164 photos
Have you tried it on a surface table? The fact that there are two sides to the dial is interesting, and that the dials are split.
Ian McVickers19/06/2020 17:15:16
188 forum posts
89 photos
Dick, I like the idea of it being used for levelling tracks or rails. That could well be it.
EngineDIY
