calculation for a sine bar
bricky10/06/2020 19:19:27
521 forum posts
68 photos
I am going to make an R8 gear cutting arbour and have been trying to work out the packing for a sine bar to set the taper turning attachment.The included angle for the taper is 16.51deg and I have calculated the vertical at 18.23 with trig,.I am not confident that I am correct,could some kind soul give verify this answer please.I havn't done trig since 1964 so remembering is a struggle.
Frank
AdrianR10/06/2020 19:28:49
540 forum posts
36 photos
What is the centre distance (hypotenuse) on your sine bar?
Adrian
old mart10/06/2020 19:30:46
3345 forum posts
208 photos
It depends how long the bar is. I have two 5" and one 2" at the museum, and I recently saw a 10" one on ebay. There are probably plenty of metric ones about as well.
Just put this calculator in your browser favourites:
http://www.carbidedepot.com/formulas-trigright.asp
Edited By old mart on 10/06/2020 19:33:35
JasonB10/06/2020 19:35:47
21436 forum posts
2448 photos
That would be right for a 5" bar
bricky10/06/2020 19:35:55
521 forum posts
68 photos
No wonder I can't get my head around trig,The sine bar is 5".
Frank
JasonB10/06/2020 19:41:18
21436 forum posts
2448 photos
I just use CAD, enter angle an 127 and it gives the height
Martin Connelly10/06/2020 19:41:53
1891 forum posts
203 photos
The sine of the half angle (8.425 deg) is 0.1465. For a 5" sine bar the gauge block stack for this angle is 5*0.1465 = 0.7325"
Martin C
This is based on an angle of 8 deg 51 mins. I think some diagrams have this as 8.51 degrees. Not sure which is correct.
Edited By Martin Connelly on 10/06/2020 19:47:15
AdrianR10/06/2020 19:42:21
540 forum posts
36 photos
Well the value 18.23 is right for 16.51 degrees but I don't think the angle is correct. I think it is 16 degrees 51 minutes which is 16.85 degrees. That would give 18.61 mm
Does anyone definitively know the angle as I have seen some other forums arguing what the angle is.
Adrian
JasonB10/06/2020 19:49:27
21436 forum posts
2448 photos
Model Engineers Handbook has it as 16deg 51 mins so that's 18.607mm
Edited By JasonB on 10/06/2020 19:50:01
bricky10/06/2020 19:56:11
521 forum posts
68 photos
Thanks for your confirming my effort ,I can proceed with confidence.
Frank
Martin Connelly10/06/2020 19:57:11
1891 forum posts
203 photos
Crawford collets has 8 deg 25 mins for the half angle. Seems conclusive that people who are using 16.5 degrees have misread (or copied someone else who has misread) the angle when written as degrees and minutes as a decimal value.
Martin C
AdrianR10/06/2020 20:04:08
540 forum posts
36 photos
I too am thinking of making an arbour, what is the best steel to use without hardening or grinding?
Adrian
Martin Connelly10/06/2020 20:10:00
1891 forum posts
203 photos
I think for most home workshop machines the motor will stall before any steel arbour for an R8 spindle bends, as long as you don't make it really skinny.
Martin C
old mart10/06/2020 21:44:14
3345 forum posts
208 photos
I have the lathe taper turning attachment set for MT2. It was set by length bars and trigonometry, but even that didn't get it exact. It ended up finally by trial and error using a MT socket as a gauge to feel the exact angle. Unfortunately, R8 sockets to test don't seem to exist, unless you have a mill spindle laying about. It is important to have your tool height exactly dead on or the taper will not be a cone.
I don't attempt to make an R8 arbor from scratch while soft ended blank ones are easy to get hold of.
https://www.ebay.co.uk/itm/RDGTOOLS-R8-SOFT-END-BLANK-END-ARBOUR-7-16-UNF-DRAWBAR-BRIDGEPORT/370487538089?hash=item5642c731a9:g:2~QAAOSwolVc-hCl
Edited By old mart on 10/06/2020 21:47:44
Edited By old mart on 10/06/2020 21:50:44
not done it yet10/06/2020 22:00:52
6325 forum posts
20 photos
Same here with MT2 (which are much cheaper and with more choice of end size). Shrink fit (and pin?) a shaft and machine to size. Job done.
bricky10/06/2020 22:29:39
521 forum posts
68 photos
I like a challenge and want to make steps on the arbour for saws as well as gear cutters.I think that a one piece unit will have more rigidity.
Frank
SillyOldDuffer11/06/2020 10:55:05
7550 forum posts
1680 photos
Posted by AdrianR on 10/06/2020 19:42:21:
Adrian
Not found a definitive 'R8' yet! It's not in my copy of Machinery's Handbook (20th Edn), which led me to assume R8 was just ANSI Standard Steep Machine Taper, 3½" to the foot, or 16.2602°. Not so!
Tubal Cain's Model Engineer's Handbook 3rd Edn and this link quoted as a Wikipedia reference both give 16 degrees and 51 minutes, which is 16.85° in decimal money. Tubal Cain and Wikipedia's Bridgeport collet drawings differ slightly, but the angle is the same. I think 16.85° is trustworthy.
R8 probably isn't in Machinery's Handbook because it's not a standard taper. (ie not recognised by ANSI, BS, DIN, ISO or other standards body.) Rather R8 started as a proprietary Bridgeport taper and since the patent expired has survived due to the wide popularity of the well-known Bridgeport milling machine. The rest of industry looks to have standardised on 3½" to the foot, but there are lots of different formats.
R8 doesn't seem to have any particular merit as as a home workshop taper. It's a quick release type not that different to the International Standard steep taper. Looking at the drawings R8 collets are lighter with a smaller gripping area, ie not so strong. I'd guess being smaller and lighter suits smaller mills better than the hefty standard collets found on machines bigger than a Bridgeport. Does R8 have any advantage over MT on a hobby sized mill other than quick release? I doubt it!
Confusion abounds, but my figures agree with Jason's. A 5" sine bar should be lifted by 18.607mm ( 0.7325" ) to set a taper half-angle of 8.475°
Have to say I found the maths quite error prone. Specifying angles in degrees, minutes and seconds is 'difficult' compared with decimal degrees. As most calculators work in radians, there's a few conversions to get wrong or forgetting to set the machine correctly. 16°51' = 16.85° = 0.2941 radians. After remembering to divide the angle by two, then recall from soh, cah, toa that the wanted height is 'o for opposite', hence height = sin(angle) X length of sine bar. Just to add to the fun, given a 5" sine bar, Jason worked in millimetres, same as me. I also used QCAD to check the result; I can't think of a quicker or safer way to get the answer. A human friendly drawing plus a computer doing the sums is hard to beat.
Why is nothing ever easy? Doesn't help I spent so many Maths Lessons staring out the window thinking about girls...
Edit: pesky smileys!
Edited By SillyOldDuffer on 11/06/2020 10:56:49
Martin Connelly11/06/2020 11:45:14
1891 forum posts
203 photos
I had Sharp EL-531GH calculator to hand when I first looked at this. It lets me put in angles as degrees, minutes and seconds and to convert to decimal values and back.
Martin C
Howard Lewis11/06/2020 12:02:37
5299 forum posts
13 photos
If the included angle is 16.51 degrees, the half angle is 8.255 degrees. Sin 8.255 is 0.1435789.
To incline it at 8.255 degrees, a 5 inch Sine bar would need to be raised by 5 (0.1435789 ) inches which is 0.7178949 Inches or 18.234531 mm.
So 18.235 mm should be fairly close, but some slight lapping may still be needed for an exact fit..
AdrianR11/06/2020 12:16:58
540 forum posts
36 photos
When I was at school I had Miss Clarkson as my teacher. A woman who struck fear in all the kids. Tweed clad, Short, rotund with a mop of grey hair Einstien would have been proud of. To finish the image off, she had a witches wart complete with hair on her nose.
I had trouble remembering the trig formula until I made up Some Old Hag (Sin = Opposite/Hypotenuse) Can Always Help (Cos = Adjacent/Hypotenuse) To Oil Aircraft (Tan = Opposite/Adjacent).
I now look back on her with fondness, she went out of her way to get me into A level maths after failing my O level. She even gave me lunchtime lessons three days a week.
Adrian
walker midge
BOLDON
rapid Direct
JD Metals
