Myford Ml7 micrometer dial.
Drawing request
Bootlegger Blacky10/06/2020 12:56:02
25 forum posts
10 photos
Hello,I was wondering if anyone out there has a drawing to make a crosslide micrometer dial for the ML7. It seems they are not available anymore and were quite pricy too. It would make a worthwhile project. Thanks
Nick Hughes10/06/2020 15:16:30
255 forum posts
142 photos
There are resettable dials available in either Imperial or Metric from Myford Ltd :- ML7 Resettable Dials
I use these on my vertical slides.
Nick.
Malc10/06/2020 15:44:18
102 forum posts
6 photos
There is a detailed article on making these in the Geo.H.Thomas book “The model engineers workshop manual” (P. 164). I made a pair for my ML7 several years ago and have found them a worthwhile feature.
ega10/06/2020 17:07:13
2266 forum posts
188 photos
Posted by Malc on 10/06/2020 15:44:18:
No doubt you first made one of his dividing devices and the tool for engraving the graduations!
Malc10/06/2020 17:36:44
102 forum posts
6 photos
Yes, I had forgotten I had made a dividing device using the lathe screw cutting gears. I cut the graduation marks just using a V shaped tool on its side in the tool post and moving the cross slide along the bed up to a pre-set stop, several shallow cuts each time. I think there is a picture of one of the finished dials in my photos. I seem to remember I also made a jig to guide the number stamp for punching the numbers. I have seen far more professional looking jobs on these pages but for a non engineer the dials turned out well enough and have certainly been useful and accurate enough for me.
Enough!10/06/2020 18:37:50
1719 forum posts
You could also look at dials that are available as spares fore current small machines - imported mills and lathes.
I fitted these from LMS to my ML7 but you could probably find something similar locally.
ega10/06/2020 22:39:13
2266 forum posts
188 photos
Posted by Bandersnatch on 10/06/2020 18:37:50:
Apart from potential import costs, they make the Myford item look rather expensive even though they don't seem to be re-settable in themselves.
Enough!11/06/2020 01:44:06
1719 forum posts
Posted by ega on 10/06/2020 22:39:13:
I bought the dials and the friction springs that match. I made simple adapters to fit them to the ML7 and they can turn continuously against the spring-friction. So re-settable. I believe that's how they are used in their original machines.
These are standard spares for common machines, which machines are probably available in the UK and elsewhere. So it's possible the dials are available too. I didn't mean to imply he should get them from LMS (necessarily). It was just an easy place to point the link at showing the ones I used.
OldMetaller11/06/2020 12:53:20
193 forum posts
24 photos
By sheer coincidence I've just been reading ME 3536, 7th May 1976. On p450 there is a short article on making these dials, with what looks like a good, clear drawing.
I'm not sure if I'm allowed to post a scan of this article here, maybe a Mod could tell me?
John.
Bootlegger Blacky11/06/2020 18:34:59
25 forum posts
10 photos
Ok,that’s great,I’ll just buy the mag! And have a good read,thanks.
walker midge
JD Metals
rapid Direct
