Femi Hem Saw 782XL
Alan Wilkinson 106/06/2020 17:06:31
39 forum posts
Hi I just bought a Femi Hem saw and its got a two pin plug on it is it ok to just cut this off? and fit one of ours the only two pin adaptors I have are only 1amp rated so will not stand the saw I dont think.?
ITs the 780xl model I though I had seen a posting on here about Jason having one but cannot find it now,
atb Alan
JasonB06/06/2020 17:11:37
18151 forum posts
1998 photos
1 articles
Mine came with a UK 3-pin on it from a UK supplier.
Alan Wilkinson 106/06/2020 17:14:18
39 forum posts
mine came from Italy but can I just lop off the 2 pin plug and fit a proper one??
Edited By Alan Wilkinson 1 on 06/06/2020 17:14:52
Anthony Knights06/06/2020 17:17:32
396 forum posts
174 photos
Mine was the same. I cut the plug off and fitted a UK 13 amp. No problem. Mine had Border Force stickers all over the box it came in, so I assume it came directly from Italy.
Spurry06/06/2020 17:17:55
194 forum posts
66 photos
Shouldn't be a problem, providing you have a 230/240v motor.
Alan Wilkinson 106/06/2020 17:41:19
39 forum posts
Ok its for the chop then thanks all for replies.
ChrisB06/06/2020 17:51:09
493 forum posts
190 photos
Most probably, when you cut the power lead you'll find there are 3 wires. Although it's 2 pin it should have earth contacts on the the side.
I bought a Nebes bandsaw from Italy, it's similar to the femi and changed the plug to 3pin, it had 3 wires.
JohnF06/06/2020 18:24:32
986 forum posts
142 photos
You can also get Euro/UK converter plugs see here **LINK**
Dave Halford06/06/2020 21:02:19
761 forum posts
6 photos
Posted by JohnF on 06/06/2020 18:24:32:
Not at 900W
Michael Briggs06/06/2020 22:03:12
188 forum posts
9 photos
Same as Jason, mine came from a uk supplier with a moulded 3 pin plug fitted, just checked and as you would expect the metalwork is earthed.
Ron Laden07/06/2020 05:32:28
1939 forum posts
383 photos
My Femi came from a UK supplier and is wired with a typical euro Schuko "earthed" plug. It came with a Power Connections UK SCP3 adaptor fitted (by the supplier I guess). Impressed with the adaptor, comes with easy access 13 amp fuse and the Schuko plug is locked in, no danger of it pulling out or working loose.
JasonB07/06/2020 07:08:53
18151 forum posts
1998 photos
1 articles
Main difference between the one Ron has and the adaptor linked to earlier is that Ron's has the earth tab to connect to the side of the euro plug so machine will be earthed.
Gray07/06/2020 07:55:39
1033 forum posts
13 photos
Axminster sell a 13A grounded Schuko converter similar to the one shown in Jasons post
JohnF07/06/2020 08:32:49
986 forum posts
142 photos
Posted by Dave Halford on 06/06/2020 21:02:19:
Not at 900W
Quite correct Dave I should have looked closer but it was the first I saw when I looked for an example—- should have paid more attention! I have a couple of items with such adaptors but they are earthed and 13amp fused
Dave Halford07/06/2020 09:25:39
761 forum posts
6 photos
Posted by JohnF on 07/06/2020 08:32:49:
Not at 900W
John, To be honest I had no idea someone could get an adapter that fits in a 13A socket that was only rated at 2.5A and fused for 3A. Hopefully the pin spacing only matches Euro shaver plugs.
EngineDIY
