Hello from West Sussex, looking for ID for my first lathe
JAMES HUGGINS30/05/2020 21:40:21
14 forum posts
8 photos
img_20200513_171405.jpgscreenshot_20200510_162638_com.facebook.katana.jpgHello my name is Jim and I'm from West Sussex.
I recently bought my first lathe. It looked like a little gem when I saw the listing and for £120 (not complete however) I thought bargain. Look really well made.
I went for a small lathe as I don't need anything too big and I thought it would be easier to learn with.
I can't find out any information about this lathe or who it's made by even, the only marking is U32 in the leg casting. I need to source some compatible parts and ideally the auto feed parts as they are missing.
Any info would be a massive help, thanks.screenshot_20200510_164156_com.facebook.katana.jpg
Steviegtr31/05/2020 01:25:55
2141 forum posts
299 photos
Hi Jim & welcome. Wonder if it's an early Myford, although I think they had flat belts. Someone will be along in the morning with an answer. Horlicks knocks you out. I think I decended from a tabby cat.
Steve.
JAMES HUGGINS31/05/2020 10:08:41
14 forum posts
8 photos
Thanks for the warm welcome, I assume tabby cats sleep a lot 😆 it was a late post I will admit. I didn't intend for the pictures to be all over the place like that. I'll get the hang of it!
Brian Wood31/05/2020 10:16:32
2409 forum posts
37 photos
Hello James,
I don't think this is an early Myford, but I am willing to be proved wrong! We'll see what others think.
Kind regards and welcome aboard
JAMES HUGGINS31/05/2020 11:31:59
14 forum posts
8 photos
The nearest to it I've seen style wise on lathes.co.uk is a Drummond but nothing identical
Hopper31/05/2020 11:57:55
5505 forum posts
137 photos
Portass or IXL?
Bazyle31/05/2020 11:59:19
5920 forum posts
220 photos
The toolpost and probably topslide are Drummond as is the style of the back gear lock but not the rest of it.
Redsetter31/05/2020 13:19:11
181 forum posts
On Lathes UK, "Small Unknown British Lathe no 99" is very similar, though the bed is different.
It looks a nice old machine, but don't expect too much from it. It will be difficult and probably uneconomic to restore fully. As your first lathe, if it is not too badly worn, it is worth setting it up with a motor and a countershaft, and you will learn a lot.
You don't need an auto feed to start with, but you will need a chuck, or chucks, so the first thing is to find out what thread is used on the mandrel nose and try and source a suitable backplate.
not done it yet31/05/2020 13:47:43
6078 forum posts
20 photos
Posted by Redsetter on 31/05/2020 13:19:11:
I doubt it ever had an auto-feed - but that could be overcome with modern-day electronics, if really wanted.
Personally, I would only consider a counter-shaft and motor if I had a suitable gash motor to hand. More likely fit a 1/2HP 3 phase motor (with VFD) with a suitable multi-sheave pulley and attach that as a drive.
It looks well made and may not be too worn. V (or round?) belt drive might give a clue as to maximum age.
If you are lucky, there may be suitable chucks on epay or gumtee. With luck, it may be the same as some more common lathes - thread size, pitch and form (along with the register details) posted here might even turn up a suitable candidate.
Harry Wilkes31/05/2020 15:11:47
1133 forum posts
64 photos
Sorry can't help with the question but welcome to the forum
H
JAMES HUGGINS31/05/2020 16:34:18
14 forum posts
8 photos
You can see on this pic here hopefully; the slotted drive fitting in the feed screw and also off the back of the drive spindle where gears would have been. It would be nice to cut threads one day. The dovetail bed has adjustment in, although the tailstock does seem a bit worn, I can probably shim that though np.
The spindle thread is 3/4x10. When I Google that all that comes up are adaptors 😆 I assume from that, people use more common chucks with a different thread.
What size chuck would you suggest for such a small lathe? Do you want some measurements?
I have a 350W ac motor I was going to try to begin with. They are V pulleys, tiny... 7mm.
Edited By JAMES HUGGINS on 31/05/2020 16:34:40
JAMES HUGGINS31/05/2020 17:17:59
14 forum posts
8 photos
Oh wow that's extremely close! Just seeing the dogging clutch mechanism for the auto feed will help as I can make all that up from scratch
Michael Gilligan31/05/2020 19:20:01
18325 forum posts
872 photos
Posted by JAMES HUGGINS on 31/05/2020 17:17:59:
Oh wow that's extremely close! ...
Extremely close ... but not quite there
Note the comment about #99 not having bearings split on only one side.
MichaelG
old mart31/05/2020 20:05:44
3185 forum posts
201 photos
I would think it uses round belts, judging from the angle of the vees in the pulleys. Leather with a simple link of bent iron wire for the join. Its hard to tell from just the pics, but a 100mm chuck looks possible. Give us the measurement from the centre of the spindle straight down to the frame. You have six speeds over a quite good range with a very strong looking back gear.
Edited By old mart on 31/05/2020 20:11:08
Edited By old mart on 31/05/2020 20:15:37
duncan webster31/05/2020 20:12:51
3354 forum posts
61 photos
with that style of headstock bearing spindle speed doesn't want to be more than 700 rpm ish, so unless you're prepared to only use the big pulley direct driving to a little pulley on your motor, a counter-shaft is called for
JAMES HUGGINS31/05/2020 22:23:22
14 forum posts
8 photos
Posted by Michael Gilligan on 31/05/2020 19:20:01:
MichaelG
Right yes I see that, I only have single split bearings. Is there a rule of thumb for tightness with that style bearing or just measure the heat?
@old mart
would you suggest a decent second hand chuck in that size of which I could get a mounting plate for with 3/4x10 thread?
@duncan
Speeds are something I'll need to learn about first. I mean turning down small diameter steel bar would probably be my main use and possibly boring thicker diameter to make tube. I've no idea what speeds Ill be needing but my thinking was I could if needed have a speed controller set up with a DC motor.
Andy Carlson31/05/2020 23:30:07
371 forum posts
129 photos
Nice looking lathe. I hope the two of you are very happy together.
It would be interesting to see some of the principal dimensions - height from the top of the bed to the centre of the spindle being the main one (easiest to measure from the bed to the tip of your tailstock centre). An idea of the overall length would be good too.
I'd guess about a 3 or maybe 4 inch chuck based on your photos... but that's guessing your dimensions from the wooden decking.
You're in need of a chuck backplate. I can't immediately see any off the shelf ones with that thread size. If you can't find a second hand one then getting from not having an imperial threaded backplate to having your first one may be a bit of a 'chicken and egg' problem because ideally you would use a lathe to machine one from a suitably sized blank and it's hardly an ideal first exercise in lathe use. Do you have any friends who could help?
Michael Gilligan31/05/2020 23:33:12
18325 forum posts
872 photos
Posted by JAMES HUGGINS on 31/05/2020 22:23:22:
MichaelG
Heat is a good indicator that the bearing is too tight and/or under-lubricated
The big problem with this style of bearing [as mentioned on lathes.co.uk] is that it is all-too-easy to over tighten the screw and crack the housing ... especially if the bearing is significantly worn.
Tread carefully: it looks a nice lathe and you want to keep it that way.
Michael Gilligan31/05/2020 23:44:42
18325 forum posts
872 photos
Posted by old mart on 31/05/2020 20:05:44:
I would think it uses round belts, judging from the angle of the vees in the pulleys. Leather with a simple link of bent iron wire for the join. […]
This style of belting is good: **LINK**
www.ebay.co.uk/itm/12-Feet-Transmission-Belt-Watchmaker-Lathe-Jewelers-Belt-Watchmakers-PU-2MM-10MM/302149867073
Remarkably similar to the expensive Swiss product, but silly-cheap.
Keith Long31/05/2020 23:44:52
864 forum posts
11 photos
James,3/4in. x10tpi (3/4 in.BSW) is the same nose thread used on the Drummond round bed lathes,so by keeping a look out on EBay and other sales site you might well be able to pick up chucks and faceplates that will fit straight onto your lathe without having to do any machining or modifying.
JD Metals
walker midge
