Warco Super Major Milling Machine - Stripping Gearbox
Lee Jones 625/05/2020 11:25:42
252 forum posts
125 photos
You know those jobs you wish you had never started!!
So when pushing the mill, the gears can make a tremendous knocking sound.
Being the inquisitive type I really wanted to find out what's going on. With a view to identifying any potential issue early and thus prevent any further, potentially irrecoverable, damage.
On my Harrison M300 lathe, viewing the gearbox is a simple matter of loosening a few cap-head screws and lifting off the top plate.
The Mill looked a little more involved, but not a lot more (spoiler: I was wrong)!
Remove face plate and dials:
Remove the motor:
Remove the 6 cap-heads and simply lift the top plate.
Ah, balls! Looks like the gears get lifted out with the top plate.
Have a quick peek inside, then put the plate back on.
After much; pushing, pulling, bashing (rubber mallet) and screwing (using them as a press, it went back on.
Put everything back together and forget the the whole thing.
Ah balls! The 1, 2, 3 gear selector has disengaged !!!
Re-strip - this time we need to go big. In for a penny ...
Taking another look at the exploded view parts list to locate all of the curclips and bearings.
Now we play a little game of 'jimmy up the plate and bash down the gear shafts' using pin followers (so as to avoid lifting all the gears out before I've had a good look at them).
Success:
Now time to drop the oil.
Ah balls! Dropped the plug and overwhelmed the funnel.
Oil everywhere. All over the floor and contaminated the cutting fluid system:
Gears out:
Nothing appears out of sorts. No worn teeth. Everything looks tight and in good order.
Time to put it all back together again.
Also think I found the source of the clattering. There's a plate at the back of the mill head which protects the screw. A little grub screw keeps it in place which was pretty loose:
Once we're all back together, I'll give it a test by removing it during a heavy cut.
Fingers crossed!
John Baron25/05/2020 19:27:38
512 forum posts
194 photos
Hi Lee,
A very nice breakdown of the gearbox and components. Thanks for posting !
That duplex gear just behind the spindle that is moved by the selector arm on yours is the one that was plastic on mine, the one that I replace with a steel one.
Lee Jones 625/05/2020 19:42:45
252 forum posts
125 photos
Ah yes, good idea. Steel for the win!
Phillip Slattery22/06/2020 08:47:55
4 forum posts
Great little write up and or warning :P
What do you think of the mill ?
Lee Jones 622/06/2020 10:08:24
252 forum posts
125 photos
To be honest, I don't have anything to compare it to.
It's doing what I require of it. Although it is still noisy during some operations.
Jordi Tomas22/06/2020 16:24:08
8 forum posts
12 photos
Hi,
I have a chinese milling machine, whith the head as this one Warco, but with the round colum. And I would like to ask you if anyone know wich model is this Warco, in order to ask if is possible to buy the squared column individually?
Thanks
terry callaghan31/01/2021 19:08:59
237 forum posts
10 photos
Hi jordi. Sorry but round and square column are totally different and nothing is interchangeable.
larry phelan 101/02/2021 10:54:28
1137 forum posts
14 photos
From looking at this, seems like a good idea to leave my mill alone !
As I said before Let sleeping dogs lie !! If it aint broke, dont fix it.cheeky
walker midge
JD Metals
rapid Direct
