Pillar drill running in reverse
mick H24/05/2020 18:31:27
723 forum posts
21 photos
I have just spoken to my son in Canada. He bought a S/H pillar drill (make SA LR 102902-6) about a year ago and has only just started using it but it runs anticlockwise. It seems to be a straightforward pillar drill with an induction motor and no reversing facility. What could be wrong with it please ?
Mick
Martin Connelly24/05/2020 18:49:02
1426 forum posts
165 photos
It probably has a start capacitor and run capacitor. If so it could be start capacitor open circuit or missing. Centrifugal start switch for the start capacitor stuck open circuit. Broken wire in the start capacitor circuit.
These are not in any special order. The start capacitor starts the motor going in the correct direction then is disconnected when the machine is up to speed.
Martin C
old mart24/05/2020 20:30:15
1927 forum posts
151 photos
A photo of the wiring going into the motor would help, if I'm right, just swapping the correct two wires might do the trick.
mick H24/05/2020 21:03:49
723 forum posts
21 photos
Thanks gents. I will try and get some photos to post.
Mick
John Baron24/05/2020 21:24:24
309 forum posts
123 photos
Hi Guys,
I've had that, a stuck open CF switch ! The motor starting in different directions at random.
Mike Poole24/05/2020 21:58:30
2706 forum posts
64 photos
Try spinning it by hand in the correct direction and then start it while spinning, if it runs in the right direction then the start circuit is u/s as mentioned above.
EngineDIY
