How do I Calculate Pulley Diameter for Timing Belts
Neil Wyatt23/05/2020 15:33:04
18745 forum posts
733 photos
80 articles
I 3D printed a timing pulley, calculating the diameter as:
pitch x number of teeth / PI
The result was a (100 tooth) pulley that was about two pitches too large in circumference. (A 20-tooth pulley seems fine as the error is too small to have an effect).
I couldn't find a clear calculation online, but measured a real 66 tooth pulley which was just over 98.2% of the calculated diameter.
I did find a diagram that showed how the pitch line is some distance 'up' the teeth, but no formula for calculating the amount of compensation for this.
I'm printing a second pulley using the empirical figure of 98%, as this seems right if the original size was two pitches too large for a 100 tooth pulley.
But it would be nice to know a formula for calculating the correct figure, especially if I create machine pulleys in the future.
HOWARDT23/05/2020 15:45:34
777 forum posts
28 photos
Can’t remember the dimensions, but you may find it here Transdev. I used to use these in the past as they made any pulleys from supplied drawings when I did a lot of special pulley and belt assemblies.
Michael Gilligan23/05/2020 15:46:24
18761 forum posts
922 photos
Don’t forget there are different types of timing belt, with different geometries.
Probably best to look at reference material from Gates, or one of the other big manufacturers.
blowlamp23/05/2020 15:56:28
1504 forum posts
98 photos
Gearotic should have what you need.
Martin.
Edited By blowlamp on 23/05/2020 15:57:01
Neil Wyatt23/05/2020 16:00:35
18745 forum posts
733 photos
80 articles
Posted by Michael Gilligan on 23/05/2020 15:46:24:
I did spend about 20 minutes looking.
I've now found this:
Pitch Diameter (P.D.) = (Pitch x Number of teeth) / Pi (3.14159)
Timing belt pulley Outside Diameter (O.D.) further builds upon the relationship between the timing belt pulley and timing belt. The Outside Diameter (O.D.) of the timing belt pulley is in contact with the tooth bottom of the timing belt while meshing with it. The distance from the timing belt tooth bottom to the tensile cord (pitch line) will determine the Outside Diameter (O.D.) of the timing belt pulley for any timing belt pitch/timing belt tooth profile.
Outside Diameter (O.D.) = Pitch Diameter (P.D.) – (2 x U)
Note: “U” = distance between the tensile cord and the bottom of the timing belt tooth
The challenge is now finding 'U' for a 1.5mm belt, which seems to be a bit obscure...
Michael Gilligan23/05/2020 16:10:23
18761 forum posts
922 photos
Not quite, Neil ... There are different geometries of tooth available
You may need to identify which 1.5mm belt you are using
Edit: This looks quite useful
https://www.instructables.com/id/Types-of-Timing-Belts/
Edit: is this the belt profile you are using ?
https://uk.misumi-ec.com/vona2/detail/221000230640/
Edited By Michael Gilligan on 23/05/2020 16:13:44
Edited By Michael Gilligan on 23/05/2020 16:21:23
Michael Cox 123/05/2020 16:12:27
544 forum posts
27 photos
Hi Neil,
You can look up the outside diameter of standard pulleys in manufacturers literature, see for example:
**LINK**.
When I have machined timing belt pulleys I use the given outside dimension for the number of teeth and then cut the grooves to give the require angular pitch.
Should be possible to use the same method to 3D drawing and then print.
blowlamp23/05/2020 16:36:14
1504 forum posts
98 photos
From Gearotic:
HDT5 100 tooth wheel.
O/D 158.0119
Outside Radius 79.006
Pitch Radius 79.5775
Root Radius 76.846
Edited By blowlamp on 23/05/2020 16:59:23
John P23/05/2020 16:49:38
324 forum posts
225 photos
Hi Neil
From an article that i wrote in MEW 164 there are some calculations for 1/5 xl 3/8L and 5 mm htd i can't find the article among my notes .For 1/5 xl it is .200 x number of teeth divide by Pi - .020 inch = OD,
100 tooth pulley = .200 x 100 = 20 inches divide by Pi =6.366 inch - .020 inch = 6.346 inch ,in all
cases the pitch diameter is always is always greater than the OD.
John Haine23/05/2020 16:50:35
4116 forum posts
241 photos
There are several online calculators around associated with different suppliers. A while back I produced my own spreadsheet which I recently resurrected to work out the pulley spacing for power power feed (yes it worked but I did slightly reduce the spacing and added a belt tensioner). I'd be happy to share that with anyone that wants it.
Neil Wyatt23/05/2020 16:52:41
18745 forum posts
733 photos
80 articles
It seems U is about 0.5, but that's me trying to measure it with a calliper!
Still my new pulley seems OK. 0.1mm nozzle is very precise, but very, very fussy about settings!
Neil Wyatt23/05/2020 21:39:39
18745 forum posts
733 photos
80 articles
I see that several folks posted while I left the window open to sort a photo!
I wasn't ignoring you all!
It seems the calculations are different for different pulley sizes. For the 1.5mm belt the 66 tooth pulley is allowing about a ~0.5mm reduction.
The 100 tooth pulley was designed with a greater reduction than that but printed slightly oversize soworked out with a 0.5mm eduction below theoretical size.
That's not what I expected from the print, but the ridged surface does mean that prints are often slightly oversize, even with me using a correction, its the one for a larger nozzle.
I tried to arrange a click and collect of 18mm play for the platform from B&Q but they cancelled it and returned my money without explanation.
Looks like Wickes may have it but not as click and collect.
JD Metals
walker midge
rapid Direct
Dreweatts
