Carbide Insert Designations & Suppliers
Dr_GMJN09/05/2020 21:29:20
1033 forum posts
All,
Many years ago I was given some Sandvik 8mm carbide tool holders and inserts. I'm now pretty much out of inserts, and initially wanted Sandvik again. The prices are daft, so I sourced some from Chronos.
The original Sandvik inserts were DCMT 07 02 04 PF.
Having de-coded this, I think they were suitable for fine work on model engineering type work, however, today I've been turning some small top-hat bushes and shims for a rc model car. It occurred to me that the nose radius of the inserts was a bit big for this type of job, where I wanted a sharp internal corner on the inside of the bush overhang. I believe it is 0.4mm. Normally I'd have chamfered the mating part external corner to 0.5mm x 45 or something, but I couldn't get access in this case.
Question: The Chronos product code for their inserts was DCMT070204. There was no option to choose other options, so I'm guessing it's a 0.4mm nose radius again. Where can I get reasonably priced DCMT inserts and specify the nose radius? Or, as ever, any other comments on what I'm doing and how I'm doing it are welcome.
Thanks.
ETA: For scale,  the larger OD of the top hats was 7mm.
Edited By Dr_GMJN on 09/05/2020 21:30:33
KWIL09/05/2020 22:08:01
3395 forum posts
66 photos
Cutwel tools £4.36 + vat. buy a whole box get a box free.
JB tools also a good source.
Hollowpoint09/05/2020 22:51:49
423 forum posts
53 photos
The last two digits are the radius so just google DCMT070202 and you will find plenty of suppliers.
Ian McVickers09/05/2020 22:56:43
210 forum posts
105 photos
Check out Shop-apt. Always had good service from them.
Dr_GMJN09/05/2020 23:03:03
1033 forum posts
Thanks all.
what is a good radius for an insert used in a fly cutter - presumably reasonably large?
jimmy b10/05/2020 04:22:40
724 forum posts
42 photos
good starting point for info!
Jim
Thor10/05/2020 05:56:28
1373 forum posts
40 photos
Here are a couple of links explaining what the insert codes mean:
***Link***
***Link***
You can get DCMT 07 02 04 here, if the ALU versions fit your holder they have inserts with 0.2mm nose radius. Seems you can get DCMT 070202 here.
Thor
Edited By Thor on 10/05/2020 06:10:45
JasonB10/05/2020 07:02:54
20640 forum posts
2296 photos
For the non ferrous and even ferrous and fine work I would get DCGT 070202, APT mentioned above sell them in twos if you don't want to get a whole box.
I've not tried such a pointed shape insert in a flycutter, most then to use the rhombic CCGT or round RCGT. But if you are going to use the DTMT then try 0.8 tip radius
J
PS are those arms off a Rough Rider or Sand Scorcher
magpie10/05/2020 10:04:40
477 forum posts
91 photos
My fly cutter. I get a really great finish with this one. 100_0823 (small).jpg
Dr_GMJN10/05/2020 10:04:58
1033 forum posts
Thanks very much everyone - I think that answers my questions.
Dr_GMJN10/05/2020 10:12:54
1033 forum posts
Posted by JasonB on 10/05/2020 07:02:54:
They are actually off my 1984 Frog that I’m mildly upgrading to play around in the garden during lockdown.
IIRC they are the same basic arms as the Sand Scorcher and Rough Rider, but those versions had ball joints screwed into them instead of the shoulder screws I’ve got. Even when new it had around 1/2mm of play in the assembly (up and down and side to side), and combined with play elsewhere (and wear) I could move the wheels several degrees by hand. I did restore a Rough Rider in the past - far more robust in this area, but heavier too.
Cheers.
Michael Gilligan10/05/2020 10:21:14
18082 forum posts
847 photos
Posted by magpie on 10/05/2020 10:04:40:
surprise ... How do you get it to give that straight-line finish ?
MichaelG. angel
Dr_GMJN10/05/2020 11:02:59
1033 forum posts
Posted by Michael Gilligan on 10/05/2020 10:21:14:
MichaelG. angel
That's awesome work, but I was going to ask the same question.
Dr_GMJN10/05/2020 11:13:42
1033 forum posts
So G seems to be a tighter tolerance on insert dimensions in 'plan'?
How does this affect cutting performance (assuming the actual cutting geometry is the same as an M designation)?
Michael Gilligan10/05/2020 11:17:41
18082 forum posts
847 photos
Posted by Dr_GMJN on 10/05/2020 11:13:42:
I’m sure Jason will explain in detail, but
G = Ground
M = Moulded
Dr_GMJN10/05/2020 11:35:04
1033 forum posts
Posted by Michael Gilligan on 10/05/2020 11:17:41:
G = Ground
M = Moulded
OK, thanks.
So in practical terms...the entire cutting geometry in three dimensions is a tighter tolerance, or just the overall dimensions in one plane? The Sandvik chart doesn't make it very clear:
Andrew Johnston10/05/2020 11:38:52
6055 forum posts
671 photos
That's a wrong assumption, the cutting geometries are different. The ground insert generally has a better defined edge and a higher rake angle. Since it is ground the surface finish is better and thus swarf is less likely to stick to the insert. That's important when turning materials like aluminium. Moulded insert on the left, ground on the right:
Ground inserts are intended for non-ferrous materials, although of course they will work with ferrous. I don't use them for ferrous as the edges are a bit delicate.
Off topic - given your sobriquet are you a real doctor or a medic? smile
Edited By Andrew Johnston on 10/05/2020 11:40:06
JasonB10/05/2020 13:09:37
20640 forum posts
2296 photos
What Andrew says, **GT tend to have a crisper edge so are happier taking very fine depths of cut and also less likely to deflect long slender parts. The polished finish helps stop aluminium building up on the tip and they have a higher top rake angle which although not teh usually suggested geomerty for brass works very well and can actually reduce that shower of chips that a zero top rake tool tends to produce.
This shows a 0.2mm tip on the left of the DCGT type and a 0.4mm DCMT on the left.
Same DCGT taking a 1 thou cut off EN8, probably easier to see the swarf as it pile sup on teh cross slide than coming off the tool.
Different types of swarf
Dr_GMJN10/05/2020 18:07:25
1033 forum posts
OK thanks all.
Yes, I was getting a spray of fine chips when I was making the bushes. I cut very nicely though, and surface finish was OK. I think I'll get a few different types and try them.
Jon Lawes10/05/2020 18:36:09
560 forum posts
This thread has been a real education. Maybe this sort of thing should be a Model Engineering Magazine article if it hasn't been already.
walker midge
JD Metals
