Number punches
Stamp jig
john brown 1724/04/2020 19:02:48
135 forum posts
Hi all has any one got a drawing or have they made a number an letter stamp jig,do have trouble making them look neat free hand.
DC31k24/04/2020 19:08:23
662 forum posts
If you do not receive better suggestions, this is for sure covered in one of GHT's books, but I cannot remember which one, the red or the green.
One thing you have to bear in mind is that a jig will only work well if the stamps are all made the same. So you might have to tune up the stamps themselves for ultimate success.
Clive Foster24/04/2020 19:26:58
3105 forum posts
107 photos
A simple thick walled U channel slightly shorter in the arms than the punch shank thickness works well for me. Hold the punch in with the thumb and whack the end. More feel than a nicely fitted square guide which, for me, gives better results.
I find the key to a properly neat job is to secure the guide and move the work underneath it with some sort of positive restraint at each position. Which can take rather longer to set up than you'd ideally like. I mislay the guide on a regular basis. Its gotten to the point that I'm more likely to just mill out a new one rather than spend time looking.
That said most of my punch marking jobs just need to be visible, not super neat. So I line up by eye and hit. Results are usually no worse than mildly inebriated. Quick'n easy but I wince every time I look at one.
Clive Brown 124/04/2020 19:30:19
807 forum posts
39 photos
A suggested use of the GHT Tapping & Staking tool is for letter an number stamping. He described a holder with a square through-hole and spring loading to hold the stamps. I've used this technique for, eg, my Quorn, and with a bit of practice, it works well.
If the raised metal around the imprint is removed with a very fine file, the result is comparable to engraving.
Nick Clarke 324/04/2020 19:31:20
1397 forum posts
61 photos
Posted by DC31k on 24/04/2020 19:08:23:
The green one is on the table beside me. This is not in the index, but I have only started to read the book today so I can't say it is not in the text.
old mart24/04/2020 19:38:39
3728 forum posts
233 photos
We had a Pryor set of stamps at work which had a holder like this one. This make was the only one which showed the inside of the holder.
not done it yet24/04/2020 21:36:10
6748 forum posts
20 photos
I recall mrpete222 having a video on the topic. Might be worth a search.
Martyn Duncumb24/04/2020 22:01:55
48 forum posts
The GHT green book "Building the Universal Pillar Tool" page 65 'Special Staking Operations' covers the numbering operation.
Martyn
ega24/04/2020 23:14:17
2500 forum posts
200 photos
If punching a number freehand, say, 12345, as a right-hander I find it helps to start with the 5 and work to the left.
Hopper25/04/2020 01:58:20
6217 forum posts
321 photos
Depends on what you want to stamp the numbers or letters on to. GH Thomas's Universal Pillar Tool uses a holder for the punch then has the round lathe cross slide dial he is numbering held on an angle bracket below it.Bit more on it here LINKK
But if you are stamping on a flat surface there are other way too. One is to clamp a length of 1.5" angle iron on to the job and hold the punches against the angle iron one at a time as you whack them. You still have to use your own judgement for the spacing between letters or numbers. If you just line all the punches up at once, the spacing looks too wide.
Another way is to run a piece of masking tape along the job then you can feel when the raised letter or number on the punch hits the edge of the tape and so ensures a straight line. But unlike the angle iron, you have to hold the punch square so the letter or number is not lying over at an angle etc.
I've made up various special jigs for special jobs. For stamping numbers on the face of the indexing gear on a GHT Versatile Dividing Head I made a stub to hold the gear flat on a piece of plate, then a piece of angle iron went over the gear to hold the punch in place, with a vertical piece of steel screwed to the angle to hold the punch dead upright. Took longer to make the jig than to stamp the numbers!
Hopper25/04/2020 04:11:51
6217 forum posts
321 photos
Pics of jig mentioned in last post:
Thor 🇳🇴25/04/2020 05:11:09
1608 forum posts
45 photos
Hi John,
I made my own version of the GHT Pillar Tool for stamping letters and numbers and it works well for me, see here.
Thor
not done it yet25/04/2020 08:25:31
6748 forum posts
20 photos
Hopper, counting fron zero to 23 appears to be an unusual way to mark a 24 hole dividing plate. Why did you do it that way?
Michael Gilligan25/04/2020 08:36:02
20112 forum posts
1044 photos
Posted by not done it yet on 25/04/2020 08:25:31:
dont know
It seems eminently logical to me
The ‘o’ is just a marker, which can represent zero, or can represent 24
... it may help if you think of it as numbered from 1 through 23
... much like the 24 hour analogue clock dial
Edited to improve clarity
Edited By Michael Gilligan on 25/04/2020 08:43:55
Martin Kyte25/04/2020 08:53:25
2728 forum posts
48 photos
Doing it that way numbers the gaps rather than the holes. as Michael has said quite sensible really.
regards Martin
not done it yet25/04/2020 09:05:01
6748 forum posts
20 photos
Posted by Martin Kyte on 25/04/2020 08:53:25:
regards Martin
I count 24 holes and 24 gaps - how many do you count? He has marked the holes, not the gaps.🙂
Not particularly like a 24h clock - unless he expects to divide each gap into minutes and seconds.
I will await the sensible/correct comment/explanation direct from the ’horse’s mouth’.
Michael Gilligan25/04/2020 09:09:09
20112 forum posts
1044 photos
Posted by not done it yet on 25/04/2020 09:05:01:
That is utterly irrelevant ... and frankly rather rude
Sorry I bothered trying to help you
AdrianR25/04/2020 09:29:52
575 forum posts
36 photos
MEW issue 43 page 22 A simple number/letter punch jig
IanT25/04/2020 09:53:46
1989 forum posts
212 photos
Nice Jig Hopper.
I'm not going to ask about the numbering scheme - the debate about whether '0' is a number has a long history - but makes perfect sense to me.
IanT
John Hinkley25/04/2020 10:05:38
1310 forum posts
424 photos
Just to show that there's more than one way to skin a cat ....
I had need of a means to stamp a lot of numbers on a couple of circular plates and made the jig shown below to acheive that. (The picture is a photo set up, not how it was actually done!)
Number stamping jig
I wasn't entirely (at all, actually) satisfied with the results, so ended up remaking one plate and redoing the marking. Instead of engraving or punching the numbers, I tried drawing the scale in CAD on a strip of self-adhesive decal film such that the scale exactly fitted the circumference of the plate and the number positioning was "spot-on". Result:
Numbers stamped-printed
The decal film won't be as durable as engraving or stamping but has the advantage of being readily replaceable when it has deteriorated sufficiently. You can compare the difference betwen the two methods for yourself.
Dreweatts
Rapid RC
