Regulator control.
terry callaghan23/04/2020 10:28:05
237 forum posts
10 photos
Hi chaps. I am a bit worried about the regulator control connections on a Martin Evans Columbia locomotive I am working on. The regulator is the twin popper type that is mounted on the front of the boiler within the smoke box. A control arm 56mm long complete with a 4mm face square formed end, extends to just outside the smoke box. The control arm needs a clockwise turn of 45* to fully open the regulator. Onto this square is fitted a connector as per the picture. My worry is that the connecting area is very small with only a very small locking pin to hold both together.
my question to you all out there, is three fold. Is this connection up to the job and safe. Is there a better way of making this connection. Would making a larger connection surface be better. Thanks, Michael a8b5fa18-d8cd-4514-9c70-255f3f89777c.jpeg
Nigel Graham 230/04/2020 00:16:15
1898 forum posts
26 photos
The square looks to be smaller than the rod can accommodate, unless that part visible is actually a sleeve carrying the shaft inside it.
Perhaps more to the point, it looks a bit short rather than too small. I'd suggest it ought end flush with the face of the operating-arm for maximum strength and contact area.
walker midge
rapid Direct
JD Metals
