Startrite Mercury drill
Feed stop nuts thread specification
David Galt20/04/2020 20:07:50
5 forum posts
Hi All,
I have a Startrite Mercury floor standing drill. Unfortunately I have lost the knurled two feed stop nuts off the top of the feed stop. Looking to replace them I measured the thread (male part). It was measuring as 14tpi with and approx 15.9mm over thread. From this I assumed it was a 5/8” BSF and ordered a couple of lock nuts. Of course they did not fit!
Can anyone confirm what the thread specification is?
not done it yet20/04/2020 22:38:28
6748 forum posts
20 photos
What thread form is used on the rest of the machine? Could they have used a non-standard thread?
Michael Gilligan21/04/2020 00:05:15
20112 forum posts
1044 photos
Posted by David Galt on 20/04/2020 20:07:50:
That does seem an eminently reasonable assumption
... Have you inspected the new nuts ?
Pete.21/04/2020 00:12:39
796 forum posts
235 photos
7/16 14tpi
Pete.21/04/2020 00:15:59
796 forum posts
235 photos
I just checked mine with a thread gauge, that's what it was on mine.
David Galt21/04/2020 06:33:37
5 forum posts
On the basis that 7/16 BSW takes a 11.5mm clearance drill, I ruled that out as my thread externally was nearly 16mm
David Galt21/04/2020 06:39:23
5 forum posts
I have minimally inspected the new nuts with a vernier only, as I don’t have thread gauges. Internal diameter inside the nut is 15.5mm. It’s difficult to measure the tpi
Michael Gilligan21/04/2020 07:21:14
20112 forum posts
1044 photos
Posted by David Galt on 21/04/2020 06:39:23:
Just screw the nut onto a wooden dowel, David ... Then measure the tpi of the the impression.
Clive Brown 121/04/2020 08:46:02
807 forum posts
39 photos
The minor dia. for 5/8" BSF is about 14mm, so whatever you have been supplied with doesn't seem to be that.
Nearer to 11/16" BSF in fact.
Edited By Clive Brown 1 on 21/04/2020 08:50:12
Oldiron21/04/2020 09:52:58
963 forum posts
40 photos
Do you have the tools to make a new set of nuts ? Or even a new stop bar.
regards
Gary Wooding21/04/2020 10:17:10
969 forum posts
254 photos
In the following chart the tapping drill size should indicate the ID of the nut.
Pete.21/04/2020 10:40:51
796 forum posts
235 photos
Might as well buy a thread gauge, if you don't want a decent one, you can buy a cheap one for a couple quid, it'll pay for itself by dodging one wrong order.
Martin Kyte21/04/2020 11:03:55
2728 forum posts
48 photos
I Have a bench mount Startrite and the nuts on that are 14 TPI 5/8" BSF if that is any help.
regards Martin
Hopper21/04/2020 11:07:51
6217 forum posts
321 photos
Posted by David Galt on 21/04/2020 06:33:37:
BSW is irrelevant to BSF. Different TPI, different thread depth. And clearance drill? Do you mean tapping size drill? Clearance size drill for 7/16 would be 15/32".
Edited By Hopper on 21/04/2020 11:08:38
not done it yet21/04/2020 11:47:18
6748 forum posts
20 photos
I’ll stick with metric, unless the OP confirms the rest are imperial. No age given for this machine and it is a common mistake by the inexperienced to measure the distance between ten crests instead of eleven...
But still only guessing. Initially I thought that maybe they had used a bastard thread, like 16mm x 1.75mm pitch (some manufacturers are known to do this sort of thing), but now I reckon it could be 16mm coarse thread.
Rod Renshaw21/04/2020 12:26:05
376 forum posts
My 1970s vintage Mercury bench-top drill appears to be built to Imperial standards and the depth stop thread measures as 5/8 " X 14 TPI and the thread gauge seems to confirm 55 degree angle thread, though I can't find an actual nut to confirm, all my stuff is smaller than that. I wonder if the O P has been sent the wrong size nuts, it does happen, young people now only get taught about metric!
Anyone got a spare 5/8" BSF nut they could send him?
Rod
Martin Kyte21/04/2020 12:30:02
2728 forum posts
48 photos
I concur with that. Thats what mine is.
regards Martin
Farmboy21/04/2020 12:31:09
167 forum posts
Can't tell you the size as it is completely missing on mine and replaced with a bit of threaded rod and nuts, but spares do seem to be available ( for more than I paid for the whole drill ) from Machine Spares Ltd.
Mine is actually a benchtop model but I believe the head is the same as the floor standing one, although there are several models, I believe.
Mike.
Edited By Farmboy on 21/04/2020 12:39:34
David Galt21/04/2020 12:31:10
5 forum posts
Metric? Ok, I have just had a look over the drill and there are m8 bolts holding the motor down and m5 holding the cowl on.
M16 x 1.75? Funny you should say that, because I have a standard M16 nut which starts for a couple of threads but then tightens. The 5/8-14 BSF doesn’t even start.
I include the enclosed photo of pitch. I set my vernier to 25.4mm and took the photo. I count 14 pitches.
25.4/1.75 is 14.28 so I think you may be correct.
next question is if it is M16x1.75, then where would I buy a couple of half nuts? Or even better, knurled thumb nuts?
Many thanks for your help so far.
not done it yet21/04/2020 12:52:43
6748 forum posts
20 photos
The standard pitch for 16mm is 1.5mm and 16mm coarse is 2mm. I doubt if 16mm x 1.75mm pitch anything is available - unless to special order. Fingers crossed that the new nuts supplied were metric instead of imperial!
Dreweatts
Rapid RC
