Serious Readers, serious prices
Can I justify the cost of a replacement bulb
ega14/04/2020 21:04:58
2255 forum posts
186 photos
Thanks to everyone for throwing some "superior light" on this.
The suspect bulb is indeed a 12v 5w MR16 - not something I have in stock but no doubt I can get one when the Corona dust settles.
I will aim to check the power supply first, however, and the Ikea will serve for the time being. I think I caused some confusion above: the Ikea replacement is a whole lamp ie base, gooseneck and integral bulb.
Howard Lewis:
I took your first standard to be standard as in standard lamp - sorry for any confusion!
As it happens, I have a vintage Anglepoise which could find a permanent home on my desk and, with some modification the SR could make a useful machine lamp.
Edited By ega on 14/04/2020 21:05:25
Robert Atkinson 214/04/2020 21:06:58
1086 forum posts
20 photos
Google GU5.3/MR16 5W LED pick a beam angle and "colour"
e.g. https://www.ledbulbs.co.uk/products/philips-5w-led-gu53-mr16-very-warm-white-71063 (I don't know this supplier, do your due dligence)
At a few quid it's worth a punt. pretty sure it will fit and OK electrically.
Robert G8RPI.
Edit MUST TYPE FASTER!
Edited By Robert Atkinson 2 on 14/04/2020 21:08:03
ega14/04/2020 21:34:24
2255 forum posts
186 photos
Posted by Robert Atkinson 2 on 14/04/2020 21:06:58:
Robert G8RPI.
Thanks for the tip. This does seem to be a commodity market which was probably not the case when I bought my SR unit in c 2013.
Stuart Smith 514/04/2020 22:48:50
231 forum posts
27 photos
I have found the craft light company to be good.
Serious Readers are very expensive as others have said. I must admit, I don’t understand why people buy them.
Enough!14/04/2020 23:01:54
1719 forum posts
1 photos
Howard, I don't want to derail the thread - I PM'd you.
Geoff Theasby15/04/2020 03:21:47
613 forum posts
17 photos
I was discussing this very subject with Serious Readers about a month ago. They claim that High Definition LED lights, which they use, give very accurate colour rendering, with a CRI rating of 100. Ordinary LED score 75-85. This may well be so, but I use a white LED in my reading light, with which I am completely satisfied, for the princely sum of £3. They didn't like that. They claimed that the quality would be remembered after the price is forgotton. As they charge £400 for a desk light, and £600 for a floor-standing light, it would be a long, long time for me to forget those prices...
Kiwi Bloke15/04/2020 06:47:39
609 forum posts
1 photos
If I remember the old ads, Serious Readers made a song and dance about the spectral properties of their lamps. Perhaps it's important. Perhaps it's a matter of taste. With MR16 LEDs, you can choose from a range of LED spectra ('warm white', 'cool white', etc., etc.). It's worth experimenting, they're so cheap - some (earlier?) 'cold light' LEDs made some colours look horrible, but I find no problem now.
Just a caution, IIRC, there was discussion here about there being both 12V and 220V LEDs in MR16 packages. AFAIK, 12V is the usual type.
Edited By Kiwi Bloke on 15/04/2020 06:52:01
Mick B115/04/2020 08:57:20
2018 forum posts
116 photos
Posted by Geoff Theasby on 15/04/2020 03:21:47:
Reading being very largely a black-and-white matter, seems to me they should - if their 'CRI' actually means anything real - rename the company Serious Lookers At Pictures?
wink
Lambton15/04/2020 09:16:07
694 forum posts
2 photos
ega, give The Light bulb Company a call on 01869 36222222.
Eric
ega15/04/2020 10:32:01
2255 forum posts
186 photos
Thanks to Stuart Smith 5 and Lambton for their recommendations and others for the interesting comments.
I see that there is considerable scepticism about the value of the SR product and I shall not buy their replacement bulb before trying the much cheaper mainstream offering. As to beam angle, this does seem to vary widely with the narrower beam more common.
My SR desk lamp is imposingly heavy but on examination most of this comes from the 180mm dia steel disc in the base which interestingly seems to be either laser or water jet cut.
Neil Wyatt15/04/2020 11:31:38
18776 forum posts
733 photos
80 articles
For that price I would expect each LEDto be individually hand-crafted by acolytes trianied for years in the art of hand-etching semiconductor wafers.
Michael Gilligan15/04/2020 23:00:47
18923 forum posts
941 photos
On the apparently popular subject of silly LEDs
Here is a rather powerful one from YUJI [*]
https://youtu.be/bBV-1VNWscA
[*] who also make high CRI devices, as I recently mentioned on another thread:
https://www.model-engineer.co.uk/forums/postings.asp?th=154966
Edited By Michael Gilligan on 15/04/2020 23:02:44
Kiwi Bloke16/04/2020 08:16:52
609 forum posts
1 photos
ega - Since it appears that there's an appreciable amount of beer tokens already sunk in this lamp, you might consider passing over a few more...
Tunable LEDs are interesting - the spectrum emitted can be altered. It seems that a spectrum with a lot of blue wakes you up in the morning, but should be avoided in the evening, when a more red-heavy spectrum will prepare you for slumber. Plus, you can alter the 'white balance' if doing something when optimal colour fidelity is required.
pgk pgk16/04/2020 08:42:37
2317 forum posts
293 photos
Isn't there something about too much blue led light causing macular degenerations? If one wants to be able to keep on reading....
pgk
Kiwi Bloke16/04/2020 10:08:47
609 forum posts
1 photos
Posted by pgk pgk on 16/04/2020 08:42:37:
pgk
I think that's conjectural, however, here in NZ, the sun's bright and we're a bit close to the ozone hole, so I took up the option of a filter coating on my specs to 'prevent' macular degeneration. It makes the reflection, off the front of the lenses, of light sources look purple. Expensive rip-off? We'll see (I hope).
ega16/04/2020 10:47:24
2255 forum posts
186 photos
Tunable LEDs: I think this kind of feature is also available for your computer screen; TV too, of course.
Mike Poole16/04/2020 11:21:37
3071 forum posts
72 photos
It is very difficult for the layman to sort the cod science and bullshit from the truth in many areas. We cannot know everything about everything but we can keep our bullshit detectors tuned and ready for action. Where we were once only able to ask a few mates or go down the library to do a bit of research we can now ask google. This is also full of people who think they know what they are talking about but in fact don’t. A bit of careful research should sort the truth from the rubbish. A piece of equipment like these lamps are rather outside most peoples knowledge so claims are easy to make unchallenged so could be the absolute truth or a total pack of lies, who can tell? If a car salesman told you a 1litre micra ate Ferrari’s for breakfast most people would suspect a lie but it’s difficult to dispute claims about lighting and eyesight, just be suspicious.
Michael Gilligan16/04/2020 16:07:34
18923 forum posts
941 photos
Posted by Mike Poole on 16/04/2020 11:21:37:
It is very difficult for the layman to sort the cod science and bullshit from the truth in many areas. […]
Many areas; but not Colour Rendering Index ... it is extremely well documented.
Specific claims might be economical with the truth, but CRI can be measured in the lab, against internationally agreed standards.
ega26/11/2020 12:54:04
2255 forum posts
186 photos
Ian Parkin:
Belated kudos to you for your suggestion that the SR power supply was the culprit!
Having previously eliminated the MR16 lamp and, as I thought, the PSU, I had decided that the switch was faulty. I have now installed the unit, shorn of its heavy base, on my lathe powered by a Maplin adapter. Incidentally, the price of a spare MR16 from Homebase was £6 and it promises 25 years' life! As you may recall, the SR item was £44; I can only wonder what they charge for a replacement LED driver.
BOLDON
JD Metals
walker midge
rapid Direct
