Phosphor Bronze grade for boiler bushes
Matt Stevens 113/04/2020 19:12:22
97 forum posts
11 photos
Hi All,
I am building the 6" vertical AJ Reeves boiler which calls for Phosphor bronze use on the bushes.... trouble is there are lots of grades out there. What type of PB should i be using?
I have heard there are drawn and cast grades - likely the latter is easier to machine on a lathe where i don't have coolant running. Another point is that i am based in Canada so a grade i can get in North America would be great...
Thanks
Former Member13/04/2020 19:16:51
1329 forum posts
Matt Stevens 113/04/2020 19:18:59
97 forum posts
11 photos
Posted by Bill Chugg on 13/04/2020 19:16:51:
PB102 is what I use.
Bill
Hi Bill - Isnt that the drawn stuff? Does it machine ok given i am not running coolant on my 9" lathe?
I have heard Calphos 90 mentioned alot as well....
Matt Stevens 113/04/2020 19:22:21
97 forum posts
11 photos
I see C544 mentioned as a grade...any comments?
Former Member13/04/2020 19:26:25
1329 forum posts
Matt Stevens 113/04/2020 19:48:24
97 forum posts
11 photos
Thanks Bill..... i see that McMaster-Carr carry 510 and 544 grades. I believe 544 does have some lead in it, buts its more accessible and cheaper. If this is a suitable grade for boiler bushes then it might be a good bet.
Former Member13/04/2020 19:59:25
1329 forum posts
Matt Stevens 121/04/2020 20:54:08
97 forum posts
11 photos
Interesting how Bill's posts have been removed???
Anyway, from doing abit of research, it seems that PB102 is a common grade in the UK which is equivalent to C510 in North America. C544 is more common over here yet it doesnt seem that there is a comparable British Standard equivalent. See attached link for info.... **LINK** .
I still wonder if both C544 and C510 are ok for boiler use.....i would like to buy C544 which is far more accessible.
Thoughts?
Thor 🇳🇴22/04/2020 05:54:07
1483 forum posts
41 photos
Hi Matt,
Doesn't C544 contain zinc and lead (in addition to tin)? If so it may not be as suitable as C510.
Thor
Matt Stevens 122/04/2020 13:11:06
97 forum posts
11 photos
Yes i believe there is 4% lead in C544. Not sure about zinc.....Could you explain why you think this is a problem for boiler bushes?
I believe C544 is much easier to machine also than PB102/C510
duncan webster22/04/2020 15:39:03
3710 forum posts
69 photos
The spec for C544 is here **LINK** claims to be 'good' for brazing, so should be OK for silver solder as that is slightly lower temp.
It appears to be very similar to Colphos 90, **LINK** which machines a lot more easily than drawn PB102, which can be a right pig to drill and tap, it closes up on the drill.
Edited By duncan webster on 22/04/2020 15:42:56
Thor 🇳🇴23/04/2020 05:37:17
1483 forum posts
41 photos
The subject was discussed earlier, see here.
Thor
rapid Direct
JD Metals
MIDLNDS GARDEN RAIL Jan 2022
