Myford S7 / 254 tailstock oil nipples
duncan webster08/04/2020 21:19:52
2532 forum posts
49 photos
specifically the one at the handwheel end, any one know is it screwed in or pressed? How would I get it out, and what size hole will be left.
In case you're wondering I want to clamp something round the shiny screwed in bit and the nipple is in the way.
Martin Kyte08/04/2020 22:07:55
1776 forum posts
33 photos
I'm fairly sure both nipples on the barrel are 2BA. I would imagine th eone on the cap to be the same. I'll have a proper look tomorrow.
regards Martin
duncan webster08/04/2020 22:50:08
2532 forum posts
49 photos
Mine doesn't have a hex on it if that gives a clue
Martin Kyte09/04/2020 14:37:25
1776 forum posts
33 photos
Hi Duncan
This is my tailstock. Not sure if I can add anything else helpfull.
regards Martin
duncan webster09/04/2020 15:35:48
2532 forum posts
49 photos
Ah well, my oil nipples don't have hex on, and I've tried turning them with a pair of pliers, no success. Suspect they are pressed or loctited in. I've come up with another cunning plan, which doesn't require removal of the nipple (sounds painful). Thanks anyway
Martin Kyte09/04/2020 15:45:57
1776 forum posts
33 photos
If it is a push fit. If you remove the cap, takes about 2mins. You should be able to push the nipple out from the inside with a suitable sized slug poked down the hole and a bit of leverage.
Still if you have one of Baldricks plans. Multiple processes for de-hiding felines and all that.
regards Martin
ega10/04/2020 09:05:39
1607 forum posts
135 photos
Posted by Martin Kyte on 09/04/2020 14:37:25:
Hi Duncan
regards Martin
That looks to be a relatively recent tailstock; are the hydraulic nipples standard? And are they still 2BA?
It looks as though Myfords started with pressed-in oilers (Zerk?), progressed to the, to me, normal 2BA push type and then settled on hydraulic.
Whatever, it's quite the best-looking amateur lathe tailstock!
Martin Kyte10/04/2020 13:46:53
1776 forum posts
33 photos
They are indeed 2BA. It's actually not a new tailstock but a Myford refurbished one. I bought a factory reconditioned lathe with my old one as part exchange. Which provved a very good deal.
Myfords always did have nice castings.
regards Martin
Ausee.com.au
