Another Engine Build
Ron Laden08/04/2020 10:51:13
1880 forum posts
347 photos
Starting a new project, I am keen at some point to build a Hit & Miss engine and was thinking of starting one but then thought it better if I get another engine under my belt first.
So I have decided to have a go at Jasons design of the Muncaster,s Simple Entablature Engine which he released just over a year ago and sized at 24mm bore. It caught my eye immediately thinking it an attractive looking engine with the four columns and the entablature, just looked a bit different to me.
I am about finished on the Jowitt, just waiting for some compressor fittings and seeing that I have the flywheel casting for the entablature I thought I would make a start.
I have turned the flywheel which didnt need much as it is such a clean and balanced casting plus I bored the wheel for a good fit to a piece of ground bar which will be come the crankshaft. I also turned the crank from a piece of round steel bar, just needs to go on the mill to cut the tapered sides.
mechman4808/04/2020 17:55:40
2638 forum posts
408 photos
Nice start for a nice model,like the flywheel spokes.Have a look in my album ' Vertical cross engine' of pics of my build.
George.
Ron Laden09/04/2020 09:05:04
1880 forum posts
347 photos
I was up for the dawn chorus this morning, turned the crankshaft, finished and fitted the crank arm, turned the crank pin and lock nut plus a pair of main bearings, all went well.
Ron Laden09/04/2020 12:02:55
1880 forum posts
347 photos
Posted by mechman48 on 08/04/2020 17:55:40:
George.
Hi George, Nice, when I looked at the pics of the parts I couldnt image what the cross and swing arms would be used for but when I saw the final picture of the engine it all became clear, certainly interesting.
Ron
Ron Laden11/04/2020 04:55:23
1880 forum posts
347 photos
I went through the drawings and BOM making up a materials shopping list against what I have on the shelf. The good thing about the BOM is that it has alternative materials suggested for most of the parts which is handy from an availability point of view and also cost.
Thinking what parts I could get out of what I have I did find one or two bonuses. I have some 45mm square cast iron so a 45mm slice will cover the cylinder, 12mm the valve chest and 20mm which I can centre in the 4 jaw for turning the cylinder cover.
I did consider brass for the cylinder which would look really nice but going with C/I and cladding looks good to. I was thinking of having to get the crosshead guides out of 8mm gauge plate but found some 1" x 3/8" EN3 which was just long enough for a pair of guides and a bit easier to work.
Edited By Ron Laden on 11/04/2020 04:57:29
Edited By Ron Laden on 11/04/2020 04:58:23
JasonB11/04/2020 07:08:27
17874 forum posts
1954 photos
Nothing to hold you back now Ron
Ron Laden11/04/2020 07:44:14
1880 forum posts
347 photos
No Jason, I can crack on there are some materials I need but there is also a lot I can get done from what I have.
The new compressor arrived but am still waiting for air fittings to connect the Jowitt. I give it a run it every day on the airbrush compressor and despite been on reduced air it really has settled in, its a sweet little runner, very pleased with it.
geoff walker 111/04/2020 11:47:31
398 forum posts
154 photos
Hi Ron
Another engine! Looks like you are becoming a prolific model engine maker, and why not.
Jowett looks great, good that you have it running well.
I like this engine, started making it last year but it's now "under the bench"
Now I'm in s.i. perhaps it's time to get it back on top and get it finished.
I assume you have access to J's m.e. article which is a good read with many useful machining methods.
Geoff
Ron Laden12/04/2020 08:37:28
1880 forum posts
347 photos
Hi Geoff, yes another engine for my sins I have a class 22 loco waiting to be finished plus the electric traction to get back to but I thought of having a break with the little Oscillator and then the Jowett.
I blame Jason he keeps presenting good designs of nice engines with drawings and a build/how to make (from bar stock) thread what is there not to like. (Thanks Jason)
There will no doubt be a forth engine after this one is finished but it may follow the loco.
Ron
Ron Laden12/04/2020 12:48:03
1880 forum posts
347 photos
Just finished the crosshead guides, I thought these may be tricky to make but turned out not to be so.
I machined two blanks (EN3) to size and marked one out as per the drawing and then put them together and machined as a matched pair. Removed the bulk of the waste with the end mill and then changed to a 10mm cutter and worked to the guide lines changing the position in the vice as necessary, checked the dimensions as I went.
They didnt distort much considering they are only 3mm thick about 5 thou over the length of the vertical leg so easily rectified.
Ron Laden12/04/2020 14:16:15
1880 forum posts
347 photos
Jason, Would the crosshead be ok in brass or does it need to be in steel.
JasonB12/04/2020 16:00:28
17874 forum posts
1954 photos
Won't really hurt to do it in brass if you like a bit of Bling.
Ron Laden13/04/2020 06:19:00
1880 forum posts
347 photos
Thanks Jason, I like a bit of bling but only in the best possible taste of course. wink
Ron Laden13/04/2020 13:39:53
1880 forum posts
347 photos
A bit of bling, brass crosshead..smiley
Ron Laden14/04/2020 08:28:26
1880 forum posts
347 photos
Ground a form tool for making the acorn nuts seems to have turned out ok.
JasonB14/04/2020 10:04:18
17874 forum posts
1954 photos
All looking good, you might want to think about cleaning up the hex stock with wire wool or fine Emery before you machine the nuts as it's easier to do the whole length first.
Ron Laden14/04/2020 10:28:03
1880 forum posts
347 photos
Thanks Jason, that makes sense, will do.
Ron Laden14/04/2020 18:53:33
1880 forum posts
347 photos
Started work on the cylinder its ready for boring just hope my 12mm boring bar does as well as it did on the Jowitt cylinder. I must make up a larger/stiffer bar say about 18mm diameter and make and fit a 4-5mm HSS bit in the end, doesnt need to be complicated. Anyway fingers crossed for the 12mm bar doing a good job in the morning.
Ron Laden15/04/2020 10:23:46
1880 forum posts
347 photos
The cylinder is coming along and the boring went well with a nice surface finish (GT insert) still needs to be honed of course. I was aiming for 24mm and as far as I can measure it finished out at 24.02 top end and run out to 24.04 at the bottom, quite happy with that.
Ron Laden16/04/2020 08:19:04
1880 forum posts
347 photos
Just holes to tap, shape the cylinder front and its finished.
Jason, I drilled the 2 x 3mm holes through to the inlets but not having a 3mm cutter for the notch I used a 3.5 its the closest I have. I could have just cut a 3.5 notch back to the 3mm hole but I counterbored the top of the hole to 3.5mm - 3mm deep, I know its not seen but it just looked better in doing it.
I couldnt see it would be a problem unless you tell me different of course.
