5" gauge tender horns
Peter Simpson 107/04/2020 17:31:50
165 forum posts
8 photos
I have just fabricated the frames for my tender. Now looking to make the horns, Reeves can supply the casting at £96, this is to steep for me. Can anybody suggest a suitable method and materials to fabricate horns without using castings ?
Former Member07/04/2020 17:45:12
Peter Simpson 107/04/2020 17:48:17
165 forum posts
8 photos
BR standard class 2
Former Member07/04/2020 17:56:15
John Hilton07/04/2020 18:36:22
113 forum posts
22 photos
I made mind for a 3.1/2 tender on my CNC mill. Pretty easy really, milled in one operation out of 1/2" steel.
You tube has Mr Crispin making hornblocks for Springbok somewhere I recall. Worth a look.
Clive Brown 107/04/2020 19:52:27
403 forum posts
11 photos
Phew! priceof castings seems to rocket.
Could you fabricate from ,say, 1/2" x 1/2" x 1/8" steel angle and silver solder in any necessary triangular webs. A bit fiddly, but cheap.
Alternatively, horns for other designs seem a bit cheaper, eg those for my 5" Priness of Wales are "only" about £65.
Any scope there?
Former Member07/04/2020 20:13:03
Trevor Crossman 107/04/2020 20:38:05
131 forum posts
17 photos
Hello Peter, fabricate them from 1/8" steel angle and save yourself around £85. The picture below shows those that I made for the tender to my 5" Salisbury. They took me a couple of hours to saw the pieces for all 6 and file them to size, and an afternoon to silver solder together. I made a simple jig to hold the parts together while heating or the small pieces float on the molten flux 😄
Edited By Trevor Crossman 1 on 07/04/2020 20:43:54
Peter Simpson 108/04/2020 17:47:35
165 forum posts
8 photos
Trevor thanks for your suggestion That's the way I will go.
Mikelkie09/04/2020 22:24:54
98 forum posts
13 photos
How about aluminium castings . quick and easyAluminium horn
Peter Simpson 115/04/2020 09:35:20
165 forum posts
8 photos
Trevor how did your soldering jig work. trying to work out design that will not get soldered to the angle iron,
Peter
Nick Clarke 315/04/2020 16:14:48
684 forum posts
21 photos
GLR have pictures of many of their castings on their site - the GWR ones for the Keith Wilson 5" Mogul come out about half the price.
Former Member15/04/2020 16:50:39
Trevor Crossman 116/04/2020 09:05:58
131 forum posts
17 photos
Posted by Peter Simpson 1 on 15/04/2020 09:35:20:
Peter
PM and a picture sent.
Peter Simpson 116/04/2020 09:42:40
165 forum posts
8 photos
Hi Trevor nothing has arrived in my in box.
Peter
Trevor Crossman 116/04/2020 10:43:15
131 forum posts
17 photos
Posted by Peter Simpson 1 on 16/04/2020 09:42:40:
Peter
Oh well, it's adrift somewhere out in the ether, check your spam folder though.
Here's the support piece, angle has two pieces of titanium sheet angle bolted to each end which supports the horn angle piece and is solder proof. If you don't have any or can't find any locally, PM your address and I will post you a piece. Not shown in the picture is the hold down which was a vertical bar with a guide piece at the top through which a piece of pointed stainless steel rod passed and held down the small gusset pieces.
Ausee.com.au
