Boxford drill parts
Renewing parts
Adrian L06/04/2020 09:11:51
10 forum posts
Hi all, newbie here.
I might purchase a boxford pd8 I've seen. Is it possible to obtain replacement parts for it should the need arise? For instance if the chuck doesn't run true etc.?
I would be purchasing unseen in the flesh so to speak.
Thanks in advance,
Adrian.
Adrian L06/04/2020 09:15:13
10 forum posts
HI again. I should add the Boxford drill looks to be from the 1970's.
Cheers,
Adrian.
DC31k06/04/2020 10:32:02
586 forum posts
I think if you put 'boxford PD8' into Google, you might receive some enlightenment.
Alternatively, start here:
https://www.model-engineer.co.uk/forums/postings.asp?th=70616
Adrian L06/04/2020 17:57:28
10 forum posts
Hi DC31k, I posted here first because there was a fair bit of interest in the drill and I wanted to snap it up. I tried ringing Boxford but there was no answer initially but eventually I got through to a guy in parts department who directed me through their website and it looks like parts availability shouldn't be a problem which is a bit of a relief.
I see there is someone on this site who has done some restoration work on his Boxford drill so if the drill I receive does need some remedial work I can hopefully get some advice from here.
I'm looking forward to using a good quality drill made here rather than a cheaper made chinese drill.
Adrian.
walker midge
JD Metals
rapid Direct
