Boiler Bri | 05/04/2020 18:45:52 |
![]() 835 forum posts 197 photos | I have had these kicking around for ages. Does anyone know what they are? |
Boiler Bri | 05/04/2020 18:47:35 |
![]() 835 forum posts 197 photos | |
peak4 | 06/04/2020 00:50:19 |
![]() 1317 forum posts 147 photos | The pair on the right look like lantern toolholders. Bill |
not done it yet | 06/04/2020 11:23:32 |
5345 forum posts 20 photos | P4, My first thought, but the bolt cannot push and pull at the same time? Because BB has not said there are any movable parts at the bottom end have to assume they simply fit in a slot of some description. Parts for some form of jig?] I thought the pair on the left might be for holding a saw/blade, possibly for sharpening? Or fitting longer blades in a machine? Edited By not done it yet on 06/04/2020 11:25:42 |
peak4 | 06/04/2020 12:48:48 |
![]() 1317 forum posts 147 photos | Posted by not done it yet on 06/04/2020 11:23:32:
P4, My first thought, but the bolt cannot push and pull at the same time? Because BB has not said there are any movable parts at the bottom end have to assume they simply fit in a slot of some description. Parts for some form of jig?].............................. Edited By not done it yet on 06/04/2020 11:25:42 Wouldn't it work if the "toolpost" was poking through a thick washer to set the centre height of the tip; so long as the washer is thick enough to raise the bottom of the tool above the oval bottom of the hole of course. Bill |
Nick Clarke 3 | 06/04/2020 15:14:23 |
![]() 1009 forum posts 34 photos | Dunno about the two on the left but the two on the right, apart from looking to be far far too small to be toolholders remind me of fittings for glass shelves or doors in shopfittings or furniture. |
magpie | 06/04/2020 15:32:36 |
![]() 463 forum posts 80 photos | Could the 2 on the left be to clamp onto a sheet or strip of metal and hold a tube or rod in the 'V' whilst soldering or welding the two parts together ??? |
John Paton 1 | 06/04/2020 16:09:28 |
![]() 287 forum posts 17 photos | +1 for lantern toolholders (minus their dished washer and matching boat to go under the tool itself.
I am thinking that the items on the left may be steadies for use when turning / threading long slender shafts? I say this as they seem to be similar centre height to the lanterns and same tee slot size? Both items fit on lathe cross slide? Might not be for metal but quickly reduce spindles and the like? One fits the original outside diameter and the other the new 'reduced' diameter? Could be handy when turning longer lengths of wood, plastics and similar flexible materials? |
Kenneth Deighton | 06/04/2020 19:44:11 |
69 forum posts | The two round objects are valve lifters from some unknown engine Ken.. |
stevetee | 06/04/2020 20:32:05 |
138 forum posts 14 photos | |
bernard towers | 08/04/2020 23:34:31 |
65 forum posts 57 photos | Valve guides for ford v8 side valve circa 1940s, they bring back memories! |
Bernard Wright | 11/04/2020 12:06:59 |
78 forum posts 16 photos | They look like drive trips off a machine with a movable table ie. milling machine or engraver... |
