Box-Ford travelling steady
Joe McKean31/03/2020 07:51:11
30 forum posts
Can anyone help me with the size of thread to bolt the travelling steady onto the cross slide of a Boxford AUD, I assume it is Imperial but only have metric bolts in the workshop so cannot try them to find out.
Martin Connelly31/03/2020 09:19:56
1369 forum posts
159 photos
The usual options are to use thread gauges if you have some. If not then get either a piece of dowel or coiled paper/card and screw it in and out then measure the marks on the surface. Diameter and thread pitch will give a few possibilities to try.
Martin C
not done it yet31/03/2020 09:21:05
4639 forum posts
16 photos
Find the minor diameter (with a drill, or other rod, plus micrometer) and check charts for likely imperial candidates?
Bo'sun31/03/2020 09:25:42
141 forum posts
Using a dowel and/or piece of paper as suggested is much easier than thread gauges on an internal thread.
Hopper31/03/2020 09:27:06
4530 forum posts
94 photos
On a British lathe, most likely If it looks (or feels) coarse it will be BSW or if it looks fine it will be BSF. Diameter will be the next standard fractional size up from the hole down the middle as measured with digital calipers or a rule. Threads tapped into cast iron on old Brit machinery seem to most often be BSW but not always.
Edited By Hopper on 31/03/2020 09:28:08
Micky T31/03/2020 09:40:05
56 forum posts
29 photos
Hi Joe I'll measure them later on my Boxford for you and let you know
Micky T
Edited By Micky T on 31/03/2020 09:40:30
Clive Brown 131/03/2020 09:57:49
426 forum posts
12 photos
They are 3/8" BSW x 2" skt. hd. cap screws. Supplied with my steady by Boxford for my ME10.
Neil Wyatt31/03/2020 12:07:48
17891 forum posts
706 photos
77 articles
Someone asked me to correct the thread title.
To be pedantic, although the company was Boxford, the lathes were marketed as Box-Ford
Oldiron31/03/2020 12:51:30
442 forum posts
22 photos
Posted by Neil Wyatt on 31/03/2020 12:07:48:
All the paperwork & name plates on my Boxford have no hyphen in the word. I have several Boxford name plates, change gear plates & books I have collected over the years and none have a hyphen. I Googled Box-ford & got no results apart from Ford roof boxes. I can find no reference to Box-ford any where. I would be very interested to see any examples please Neil.
regards
regards
Mike Poole31/03/2020 13:04:32
2575 forum posts
60 photos
A quick look at the lathes.co.uk website confirms the presence of the hyphen, a picture and mention in the text.
Roderick Jenkins31/03/2020 13:10:00
1885 forum posts
481 photos
The lathes database **LINK** Shows that the hyphen disappeared sometime around 1960
Rod
Edit:  Too slow yet again!
Edited By Roderick Jenkins on 31/03/2020 13:11:27
mgnbuk31/03/2020 13:35:08
766 forum posts
60 photos
It was just Boxford when I started working there September(ish) 1980. The logo was the same bold blue font as the current version. Standard lathe colours at the time were the two tone beige/brown & I have a suspicion that the threads may have been all metric at that time, but can't find anything to back that up.
Nigel B.
Peter G. Shaw31/03/2020 13:45:14
1098 forum posts
44 photos
Don't forget that Boxford was originally an off-shoot from Denford of Brighouse when lathe production moved, or was setup in Boxtree mills, Halifax, hence Box-Ford.
Peter G. Shaw
Grindstone Cowboy31/03/2020 14:06:37
300 forum posts
27 photos
There ya go! (Must get a replacement for that when I get round to it...)
Box-Ford label
Michael Gilligan31/03/2020 15:18:56
15707 forum posts
687 photos
Clearly the real pedant would have checked the vintage of the lathe in question ... and then [if appropriate] used ‘all caps’ in the hyphenated thread title.
angel
Thanks anyway, Neil ... The resulting discussion has evidently grabbed people’s attention, and we’ve probably all learned something along the way.
Clive Brown 131/03/2020 15:40:18
426 forum posts
12 photos
not done it yet31/03/2020 16:09:10
4639 forum posts
16 photos
The title being changed to ‘Boxford’ (while perhaps not wrong at the moment, means that anyone making a search for just that topic in the future will likely not find it.
Makes no odds to me, but it might be useful for many forumers.
thaiguzzi31/03/2020 16:25:22
696 forum posts
131 photos
1969 VSL here - 3/8 BSW.
Michael Gilligan31/03/2020 16:36:26
15707 forum posts
687 photos
Posted by not done it yet on 31/03/2020 16:09:10:
But it’s much better than ’Oxford’ ... Which it was before Neil kindly changed it.
not done it yet31/03/2020 18:24:50
4639 forum posts
16 photos
yes, maybe. But a search for ‘Boxford’ brings up ten pages. A search for
Box-Ford brings up one thread.
KISS
