Mag Base LED Work Lamp
Ignatz30/03/2020 16:17:34
100 forum posts
58 photos
Just finished this new LED work lamp and thought that it might be of interest to others here on the forum.
For the base I used a flexible magnetic base indicator holder which I was lucky enough to find in like new condition. The articulated arm tightens up when that little lever tensions a cable that runs inside. These things don’t have the best reputation as indicator holders, but I figured it would make a great lamp base and far better than I might produce.
I tossed out the original bit at the end of the arm that would hold a dial indicator - a rather cheesy affair of cast Zamak - and replaced it with a little turned and welded mounting piece I cobbled together. Nothing special, that, and not worthy of posting dimensions or work progress snapshots.
Hope this inspires some of you.
Michael Gilligan30/03/2020 17:15:13
15455 forum posts
668 photos
That’s very tidy ... but I think I would re-route the cable, to avoid chafing by the locking mechanism.
Ignatz30/03/2020 18:21:19
100 forum posts
58 photos
A fair observation... took the advice and gently pushed it around the base to one side. wink
