Connectors for multiple LED lamps
Rod Renshaw28/03/2020 17:47:24
88 forum posts
I have mounted a lot of LED lamps around and about my lathe, several in the locker spaces in the lathe stand, more under shelves above and behind the lathe and more shining down on the lathe itself, both fixed and mobile. It looks bright and is functional and I am pleased with the set up which sort of "grew" over time.
I am not so pleased with the rats nest of bell wire which has developed behind the lathe and which connects all the lamps up to the same 12 v supply. To make the system tidy and also adaptable to any future changes it needs a socket strip rather like a miniature version of the mains power strips which are readily available. I had thought of using XLR or phono type plugs on each lamp lead but I can't seem to source a power strip. Clearly, I could buy a lot of sockets and a box and make one, but are commercial ones made? It does not have to be XLR or phono, just something suitable for 12 volts and a few hundred milliamps max.
thanks Rod
Michael Gilligan28/03/2020 17:59:45
15491 forum posts
670 photos
It probably doesn’t get you much further, Rod ... but the DIN loudspeaker connectors [one pin, one blade] are adequate, convenient, and cheap.
There may be a suitable strip available somewhere, but I’ve not seen one.
pgk pgk28/03/2020 18:03:23
1729 forum posts
287 photos
How about something as simple as a couple of rows of 5-way Wago stuck to a backboard? Infinitly expandable.
wago
pgk
Neil Wyatt28/03/2020 18:25:20
17740 forum posts
697 photos
77 articles
What about powerpole connectors? You can build up your own multi-way connector.
DC31k28/03/2020 18:31:12
182 forum posts
Search Google for 'xlr multicore stage box' or 'xlr punched panel'. Maybe your best option is to buy an empty box and the correct number of sockets and assemble it yourself.
Martin Kyte28/03/2020 18:47:16
1808 forum posts
33 photos
How about stackable 2 pole banana plugs
Bit cheaper than XLR's
regards Martin
Frances IoM28/03/2020 20:28:25
747 forum posts
26 photos
I have the following connector system on some small audio interfaces which would work well the male plugs (8mm wide) have small screw fixtures for the wires - however I don't know the manufacturer
Kiwi Bloke29/03/2020 08:51:34
408 forum posts
It's not clear just how easily adaptable or 'professional', or well-shielded you'd like the system to be. A red and black (if it's a d.c. system) 'ring main' could be run around the area and broken into using el-cheapo 'chocolate-block' screw terminal connectors for spurs to lamps or other devices. If it's got to be a pluggable system, 4mm banana plugs? (I guess I'm a bit tight, but I like cheap-but-effective solutions.)
Dave Daniels29/03/2020 09:24:23
69 forum posts
Posted by Frances IoM on 28/03/2020 20:28:25:
Colour looks a bit like Camdenboss.
The O.P. might look here to see if there is anything suitable.
ttps://cpc.farnell.com/w/c/cable-leads-connectors/connectors/pcb-connectors/pcb-terminal-blocks/pluggable-terminal-block-headers-sockets/prl/results?brand=camdenboss&pageSize=100
D.
Bandersnatch29/03/2020 17:24:38
1600 forum posts
58 photos
As an alternative suggestion Rod, have you considered setting up a switch panel and simply hard wiring to that .... eliminating all the connectors? Simple single-pole switches are all that's required (and perhaps a master switch to turn everything off at the end of the session).
I have a series of these above my lathe, mill and two benches, all wired with speaker wire to a central control switch-box and it works out very well for me.
Rod Renshaw30/03/2020 12:13:14
88 forum posts
Thanks to everyone who responded to this question and all the suggestions made.
I have not really decided which to go with, and this time it may be a matter of seeing what is actually available since so many firms are not operatng normally.
I am rather taken with the idea of Wagu connectors as they don't have lots of little screws and are cheaper than XLR.
Rod
