Peter Bell | 26/03/2020 14:31:47 |
338 forum posts 155 photos | Hello, I want to use a small 7 pin plug and socket to carry around 100ma 240v ac each pin. I have looked at the Amphenol C 091 series (T3476 001 etc, from RS) which appears to be rated at 240v ac and 5a. However I seem to remember some "communications" on this or a similar subject recently on this forum but cannot remember where and cannot find it! Can anyone point me to the thread or suggest something suitable without breaking the bank? Thanks Peter
Clive Brown 1 | 26/03/2020 14:34:51 |
589 forum posts 23 photos | Would 7 pin Din connectors suit? Cheap as chips on Ebay |
Clive Brown 1 | 26/03/2020 14:35:53 |
589 forum posts 23 photos | Posted by Clive Brown 1 on 26/03/2020 14:34:51:
Would 7 pin Din connectors suit? Cheap as chips on Ebay. Re-think, perhaps not for 240v. Sorry, meant to edit first post.
Edited By Clive Brown 1 on 26/03/2020 14:38:23 |
SillyOldDuffer | 26/03/2020 14:58:45 |
Moderator 6681 forum posts 1501 photos | Posted by Clive Brown 1 on 26/03/2020 14:34:51:
Would 7 pin Din connectors suit? Cheap as chips on Ebay Maybe in an emergency; I wouldn't. Quite apart from the 240VAC issue I hate the things. And they get worse as more pins are added. Not intended for repeat insertions either, yuk. This aviation type might better, rated for 240Vac @ 5A. 7 pin plugs or 8 or 9? Don't forget neutral and earth. Could the requirement be tweaked? I don't care much for multicore mains cabling with plugs and sockets if it can be avoided. Presumably a controller is operating remote equipment? If so, I'd prefer to send low voltage control signals to switch the mains remotely via relays. Isolating mains power from the control system could be safer. Dave |
Dave Halford | 26/03/2020 15:09:46 |
1142 forum posts 11 photos | It's normally unwise to put mains through a socket not intended for power. It's possible to for someone else to plug a ordinary signal cable into the socket and get an unpleasant surprise. |
Martin Kyte | 26/03/2020 15:25:26 |
![]() 2155 forum posts 38 photos | The one you specify would suit. I would like to see sleeving on the soldered connections though. It is amazing the things you do in your youth though. Three of us used to run Disco's as teenagers starting off in the local Scout hut. Early light show was driven by a motor driving a set of cams operating microswitches leading off to various 3 way spot banks etc. Well we wanted a 3 colour spot bank down the other end of the hut and had no multicore let alone connectors. Solution. Three lives sent down an ordinary mains extension cable one channel on each pin. Pick up the Neutral and Earth from a handy mains socket on the far end wall and Bobs yer uncle, Charlies yer aunt and Fanny's in the air force as they say. Make you cringe now doesn't it. regards Martin |
Mike Clarke | 26/03/2020 15:50:36 |
![]() 93 forum posts 7 photos | Hi, The Bulgin "Standard" or 4000 connector would suit (check their range for other possible suitable connectors) - and freely available form RS/Farnell/CPC etc They're not the most compact but easy to assemble and not expensive. Regards, Mike Edited By Mike Clarke on 26/03/2020 15:53:14 |
Clive Foster | 26/03/2020 15:50:54 |
2533 forum posts 82 photos | I like the Bulgin 8 pin style for this sort of thing RS 487-378 and 487-384. Not uber cheap tho' at around £15 the pair from RS and quite large. Clive |
old mart | 26/03/2020 16:00:00 |
2472 forum posts 169 photos | This type is rated 250V, but might be too big for your requirement. The DIN type are only up to 100V unfortunately.
John Haine | 26/03/2020 16:33:55 |
3531 forum posts 194 photos | When Weller first introduced their temperature controlled soldering irons the lead from the base to the iron, which needed 3 wires carrying 24V AC and ground, were attached at the base to shrouded terminals with little strain relief. So they upgraded the design and used a miniature Bulgin type connector - this was about a half-scale version of the old 1" diameter bulgin connectors that were often used for the mains lead on various instruments, hifi etc before IEC connectors came along. However the small Bulgin was actually designed to carry mains and certain equipment actually used it for that so there were mains leads around with 13A plugs on one end and the miniature Bulgin plug on the other - and it was possible to plug this in to the 24V output on the soldering iron base! Well one bright spark technician in the Post Office Research dept where I worked thought they would demonstrate to the safety people what could happen - it was most spectacular as the transformer tried to deliver 2400V to the mains plug! That design did not last very long! A good demonstration of why careful connector selection is very important. |
Nick Clarke 3 | 26/03/2020 18:14:21 |
![]() 1016 forum posts 36 photos | Posted by John Haine on 26/03/2020 16:33:55:
Horrible things they were too. They were used, amongst others for the mains input on Ferrograph Series 7 Reel-to-reel tape recorders and Quad 303 and 50E amplifiers. Very difficult to wire up, very limited strain relief so wires kept breaking and needing to be re-soldered and virtually impossible to sleeve the connections inside the plug - which in my case used to be solder first wire and sleeve it, solder second wire and get the sleeving on only with great difficulty and solder the third wire without sleeving as there was no room and irrespective of which connector it was. Thinking about it for the first time in years and shuddering, it would be easier today using heatshrink that the Hellerman sleeving I used to use than. |
Nick Clarke 3 | 26/03/2020 18:24:03 |
![]() 1016 forum posts 36 photos | Posted by Martin Kyte on 26/03/2020 15:25:26:
It is amazing the things you do in your youth though. Three of us used to run Disco's as teenagers starting off in the local Scout hut. Early light show was driven by a motor driving a set of cams operating microswitches leading off to various 3 way spot banks etc. Well we wanted a 3 colour spot bank down the other end of the hut and had no multicore let alone connectors. Solution. Three lives sent down an ordinary mains extension cable one channel on each pin. Pick up the Neutral and Earth from a handy mains socket on the far end wall and Bobs yer uncle, Charlies yer aunt and Fanny's in the air force as they say. Make you cringe now doesn't it. regards Martin At Uni in the seventies all of the halls of residence had hall parties and I was one of the student techs who provided lights, sound and sometimes projection. None of the extension leads we used (all 13A plugs and sockets) had fuses fitted these were only in the adaptors from Wylix plugs which were the standard in the Halls. So if a fuse blew you traced the lead(s) back to the Wylix socket and you knew that was where the fuse had blown. Saved checking each lead in a line of several. Technically this became possible after a previous student had discovered that one of the materials testing machines in the materials lab used samples 3/16" diameter and the right length to fit in a 13A plugtop! Even us students were never able to blow 3/16" dia mild steel fuses. At least not in my time...……… Edited By Nick Clarke 3 on 26/03/2020 18:24:46 |
Mike Poole | 26/03/2020 18:56:00 |
![]() Moderator 2845 forum posts 67 photos | I bought some of the eBay aviation connectors purely because they are so cheap, it would surprise me if they are fitted to aircraft. I would hope to find connectors like the military spec Amphenol on any aircraft I was a passenger in. Do these “aviation” connectors actually meet any specification for aviation use or does it just sound good in a sales pitch? the quality of my purchase was in line with the price paid but they will be ok in the non critical application I purchased them for. Are they a cheap copy of a quality connector or are they just a cheap and nastyish component? Mike |
Clive Foster | 26/03/2020 19:04:39 |
2533 forum posts 82 photos | Another type I like is the ITT Canon Trident Ringlock and QM series connector pairs. A little smaller than the Bulgin ones with crimp type removable contacts so much easier to assemble. But you need to buy contact sets separately, ideally should get the pukka crimp tool and contact extractor too. All gets very spendy for one plug and socket. I had a bunch of 12 and more way sets to assemble so I got the tools and still have a stash of contacts. If nothing else appeals I could make you up a lead set with, I think, size 16 contacts, its years since I looked at what I have. Clive |
Maurice Taylor | 26/03/2020 19:12:12 |
166 forum posts 30 photos | Have a look at this range from CPC.
Circular Threaded Panel Mount Connector Socket, 6-Pole, IP68 -SP1312/S6CPart No CN21346
Robert Atkinson 2 | 26/03/2020 19:31:45 |
![]() 883 forum posts 17 photos | The C091 series are NOT suitable for mains, certainly not UK 240V. Harting HAN series with earthing contact e.g. 6+E (assuming 1 of your 7 is earth) is about the best choice for multipole mains. What exactly are you trying to do? Robert G8RPI. |
Maurice Taylor | 26/03/2020 19:54:26 |
166 forum posts 30 photos | Hi please ignore my previous post regarding multipole connectors ,I have made a mistake only the 2 and 3 pole connectors are 240Volt rated . Do not use this range I have suggested. Sorry Maurice
Peter Bell | 26/03/2020 19:56:35 |
338 forum posts 155 photos | Thanks everyone--bit of a minefield, no wonder I was puzzled! I've also suffered the min Bulgin on hifi kit so rather avoid, the other Bulgin are a bit big. The CPC suggestion sounds good but the voltage is a bit low for a reasonable amount of pins. Dont really want to attempt dedicated crimping—also been there before! Suspected the C091 was not suitable for 240v which is why I asked the question. The application is to connect to the operating coils (240v) on 3 existing air solenoid valves. I want to connect these to relays inside a dedicated box which is housed inside a cabinet. If I use (reasonably priced) connectors I’ll be able to proof test the box in the workshop as the equipment is in continuous use. Peter |
Robert Atkinson 2 | 26/03/2020 20:52:57 |
![]() 883 forum posts 17 photos | For 3 Valves you only need 5 pins, 3 switched lives (or neutrals), 1 neutral (or live) and earth. I'd suggest a HAN A 4+PE https://uk.rs-online.com/web/c/?sra=oss&r=t&searchTerm=HAN+A You need a female on the power source obviously. You can get screw or crimp terninals and plastc or metal shells. Robert G8RPI. |
John Paton 1 | 26/03/2020 21:05:57 |
![]() 287 forum posts 17 photos | Posted by Mike Poole on 26/03/2020 18:56:00:
I bought some of the eBay aviation connectors purely because they are so cheap, it would surprise me if they are fitted to aircraft. I would hope to find connectors like the military spec Amphenol on any aircraft I was a passenger in. Do these “aviation” connectors actually meet any specification for aviation use or does it just sound good in a sales pitch? the quality of my purchase was in line with the price paid but they will be ok in the non critical application I purchased them for. Are they a cheap copy of a quality connector or are they just a cheap and nastyish component? Mike Have you told Boeing? This may assist their investigation!
