Speedometer Ratios
James Alford05/03/2020 07:26:07
408 forum posts
74 photos
I have the attached speedometer which I wish to use on an Austin Seven. I do not know what vehicle it is from.
The Austin speedometer does 1040 turns per mile, but I am not sure what this new speedometer's turns per mile are. I suspect that it is 800, but I am not sure. Can anyone clarify what the small numbers near the oddometer mean? I can then work out what gearing I would need to put into a small ratio adapter gearbox or perhaps print a new dial face.
For clarity, the numbers are SN3253/07 and 800. It is 3" od if that helps at all.
Thank you.
James.
Edited By James Alford on 05/03/2020 07:28:21
Edited By James Alford on 05/03/2020 07:28:38
Redsetter05/03/2020 07:45:21
139 forum posts
800 is 800 turns per mile, the SN is a Smiths part number.
Robert Atkinson 205/03/2020 07:56:54
873 forum posts
17 photos
Calibration of this type of speedometer depends on the action of rotating magnets on a non-ferrous disk (eddy current torque) The maget strength and distance to disc are critical. If the distance between magnet and disk is fixed the calibration can be changed by de-magnetising the magnet. Age may have already moved the calibration in the right direction. Changing this will not correct the odometer as it is direct drive.
Robert G8RPI.
not done it yet05/03/2020 08:11:34
5340 forum posts
20 photos
It will be 800 tpm as stated above. Easily checked by driving it with a fixed speed drill for a measured time and noting the difference in odometer reading? Alternatively, driving it at 800rpm in the forwards direction should give an indication of 60mph, so can be checked at any other input speeds which are within the range of the instrument.
John MC05/03/2020 08:28:40
329 forum posts
38 photos
That looks like a chronometric rather than a magnetic instrument, could be wrong. Have a look at Gaggs speedo website, might help.
Clive Brown 105/03/2020 08:36:25
579 forum posts
23 photos
My memory of chronometric instruments on 'bikes is that they are identified on the dial, but could be wrong. If it's driven the needle will move in small steps rather than smoothly.
Former Member05/03/2020 08:51:23
1329 forum posts
Nick Clarke 305/03/2020 10:13:51
1008 forum posts
34 photos
Many years ago I was involved in fitting the first mechanical tachos to trucks and we had a selection of splitter gearboxes that went into the speedo cable to provide a second cable to drive the tacho.
The gears in these boxes were chosen from a large range that Lucas provided to give the correct ratio. Still a stock item?? Probably not after all this time, but it might be worth a web search to see perhaps?? Or maybe talk to a speedo repair business?
Fitting a gearbox with one cable left off might give you the drive in the form you want.
Bob Brown 105/03/2020 10:28:31
1016 forum posts
127 photos
It might be worth speaking to Speedy cables as they can recalibrate speedometers **LINK**
Richard Marks05/03/2020 10:43:46
201 forum posts
8 photos
Calibration is 800rpm to show 60mph, speedo should indicate 60mph at 800 revs cable speed.
Neil Wyatt05/03/2020 10:49:55
18404 forum posts
718 photos
78 articles
An app like google maps or a GPS will give you the easiest way to calibrate the speedo.
You can also use it to do a journey of known length to check the odo.
Richard Marks05/03/2020 12:41:30
201 forum posts
8 photos
Odo and speed indication will be matched by internal gearing, so if you drive the instrument at 800 revs it will show 60mph and one mile will be added to the odo in one minute.
Neil Wyatt05/03/2020 14:15:02
18404 forum posts
718 photos
78 articles
Posted by Richard Marks on 05/03/2020 12:41:30:
The speedo function has to integrate rotations per unit time so it is usually driven by a magnet like an old electricity meter. This means the speedo reading can vary with calibration while the dodometer ration is fixed.
It's worth remembering that speedo and odo accuracy can be no more accurate than the known tyre diameter. This can vary by 1-2% just from legal tyre wear, let alone variations due to different types of tyre and state of inflation...
A good summary here:
www.wewantanycar.com/news/car-speedo-how-fast-are-you-going/
Edited By Neil Wyatt on 05/03/2020 14:17:36
Edited By Neil Wyatt on 05/03/2020 14:20:35
Richard Marks05/03/2020 15:58:33
201 forum posts
8 photos
Many years spent as a Speedometer engineer and Calibrator of all models and Police instruments in the 60s means I should know a little bit about them, as I said before run it at 800 rpm and note the results to see if it is accurate, if not send it to a calbration company to get it checked.
John Paton 105/03/2020 18:22:29
287 forum posts
17 photos
Faced with a similar dilemma, but recognising the probable need to calibrate several times with different dis tyres and different ratio differential I elected to use Hall effect sensor on the driveshaft and a digital to analogue converter ( drives a motor which then drives the speedo!)
you can then set it to whatever conversion ratio you require.
Not cheap but the easy solution if you may need various ratios and prefer an original anologue speedometer clock.
Nimble05/03/2020 18:52:34
44 forum posts
Hi James,
You could check out www.howardinstruments.com.au site as they have a number of ratio change setups, but I have no doubt there are many UK vintage car speedo specialists that would be able to assist you.
Regards, Neil
James Alford05/03/2020 21:56:33
408 forum posts
74 photos
Thank you for all of the suggestions and information, which will be a great help. Knowing that the speedometer is 800 tpm is useful. I shall have a look at the various websites which have been suggested and see whether I can find a device with a known number of revolutions per minute with which to test it.
James.
not done it yet05/03/2020 22:36:05
5340 forum posts
20 photos
I believe Declan Burns (to be found on the morris minor owners club forum can actually supply a modified drive to convert different speedos, when modifications are made to the car.
Incidentally, mechanical speedos are notoriously optimistic on speed indication. The legal range is to indicate up to +10% optimistic but with zero allowance for pessimism of the true speed. Calibration of police devices have to be certificated, of course.
Hopper05/03/2020 23:10:16
5016 forum posts
111 photos
Posted by not done it yet on 05/03/2020 22:36:05:
Not just the old mechanical speedos. Most modern electronic speedos are set up the same. They generally read up to 10 per cent optimistic. I guess manufacturers don't want their drivers to have a bad impression of their car by getting too many speeding tickets.
Michael Gilligan05/03/2020 23:28:38
16982 forum posts
752 photos
Incidentally, mechanical speedos are notoriously optimistic on speed indication. The legal range is to indicate up to +10% optimistic but with zero allowance for pessimism of the true speed. …
Which is [approximately] +/- 5% of the actual target reading ... it’s just that they shift the target to accommodate that ‘zero allowance for pessimism’
EngineDIY
