Polly Steam Plant
Joseph Harland 102/03/2020 05:34:10
10 forum posts
Hi All,
I'm in the middle of making a copy of Tubal Cain's POLLY.
Do I need to remove the remnants of silver brazing flux from inside the boiler and if so - how?
Joe Harland
mick H02/03/2020 07:56:55
723 forum posts
21 photos
It will dissolve when you pickle and rinse it.
Mick
Joseph Harland 102/03/2020 10:27:48
10 forum posts
Thanks Mick, I was worrying about how to rinse out the inside - there are only 2 small openings.
Joe
Norman Billingham02/03/2020 11:57:56
39 forum posts
We teach students on our basic course at SMEE to make Polly. So far I think we've had about 120 made. We use copper tube to make the boiler and just give it a wash through with hot water to remove flux residues after brazing in the end plates. We've never had a problem. It's actually more important to wash thoroughly when you've used soft solder with Bakers fluid flux as in soldering the firebox to the base - chloride residues from the flux can be corrosive to steel.
Good luck with the build
Joseph Harland 105/03/2020 06:04:19
10 forum posts
Thanks for the advice Norman (and Mick), I am carrying on.
EngineDIY
