Plans for 3.5" gauge Vera
3.5" gauge LBSC Reeves "Vera" plans
Adam Clarke23/02/2020 09:41:37
2 forum posts
4 photos
I have a set of plans for a 3.5" gauge 060 Reeves loco "Vera" which my Grandfather started before losing his sight, but 2 of the sheets had been damaged and torn. I have spoken to Reeves but they have no information on this model, apparently last shown in catalogue 1972!
If anyone has plans for this loco, and would be prepared to copy the 2 sheets that I require please contact me.
Thank you. Adam Clarke
Nick Clarke 323/02/2020 14:15:24
754 forum posts
24 photos
Only negative information, I'm afraid, but this was a Reeves exclusive and never apparently published in the Model Engineering press which narrows your options down a bit.
On the other hand - LBSC frequently 'reused' components so do you know what is on the missing sheets and can this be borrowed from another design?
Circlip23/02/2020 14:31:41
1100 forum posts
If ONLY damaged and torn, they could be scanned and repaired and reprinted from a PDF.
Regards Ian.
Adam Clarke24/02/2020 23:50:13
2 forum posts
4 photos
I had the original blueprints reverse copied, but the missing sections are smokebox side elevation with dimensions and full side elevation smokebox forward.
Former Member25/02/2020 11:48:48
Circlip25/02/2020 12:52:38
1100 forum posts
"Piece missing" would have been a more accurate posting, BUT another example when the big "C" word needs a good kicking. Hopefully, someone may respond and one of "Grandfathers legacy" hasn't been filed at the local recycling centre.
One of the late Sir John's projects was stymied due to stupidity by "The Authorities".
Regards Ian
Simon Cook26/02/2020 23:04:12
14 forum posts
Adam, it's your lucky day.
I have an in ticket Vera, and a complete set of drawings. I'm not the original builder, just the current custodian. I'll send you a pm.
Simon
