cylinder lubricators
ratchetless drive
john valks21/02/2020 09:19:24
3 forum posts
hi everyone, has anyone made a successful lubricator drive, that has stood the test of time, and not given problems after just a few hours running? if so info, please....
oldvelo22/02/2020 03:17:24
294 forum posts
56 photos
Hi John Please post more details as to the end use of the lubricator. I.E. Lubricant amount and viscosity continuous or intermittent delivery Etc.
Eric
john valks22/02/2020 16:03:38
3 forum posts
Hi Eric, the type is for the 5" g 9F. and is of the ball and wedge, clutch drive. I have made several,, they run but are unreliable in a short time, either slipping and no delivery, or jamming up. so I am going back to ratchet and pawl.. you can see one being built on utube,, on account. No23mk2. part 66, 67, & 68 john
oldvelo23/02/2020 20:38:20
294 forum posts
56 photos
Hi John Working in industry I worked on machines that had a sprag clutch fitted. They come in all sizes with the same dimensions as a Ball Bearing. possibly one of the very small ones would fit the bill. Took a peek at you tube
Not a good idea to make the outer in  any old steel it will FAIL even in a short time. The whole thing needs to be made from hardenable steel and properly hardened and tempered. The units I worked on had given thousands of hours service in harsh conditions.
Eric
Edited By oldvelo on 23/02/2020 20:40:55
John Rutzen24/02/2020 08:29:38
348 forum posts
19 photos
I have made a couple according to the drawing by S. Purinton in ME. It's just a wound spring round a 1/4 shaft and another attached to the arm. The spring grips one way and releases in the other direction. Works very well and costs next to nothing.
Rapid RC
Dreweatts
