mystery file
what's it for?
Anthony Knights15/02/2020 16:48:04
332 forum posts
128 photos
file1.jpgThis used to be my Dad's and I've had it for years, but never knew what it was for. Some one on here will probably know. It's the same on both sides and has one safe edge. The writing at the top looks like "Dreadnought". Sorry for the poor quality photos.file2.jpg
john brown 1715/02/2020 16:54:43
111 forum posts
I have a a few like that ,use mine on car body work filler and when using lead to take it down a bit ,hope this helps.
john
Robert Atkinson 215/02/2020 17:02:06
555 forum posts
21 photos
That will be a Mill tooth / curved cut file. Used for fast cutting softer materials like aluminium alloy and commonly used for shaping body filler.
Robert G8RPI.
RMA15/02/2020 17:02:54
233 forum posts
4 photos
Yes agree with John Brown 17. I used mine on car bodywork many years ago when lead loading.
JasonB15/02/2020 17:05:11
17319 forum posts
1865 photos
I thought" Millen" cut files had the straight teeth and Dreadnought the curved ones
Georgineer15/02/2020 18:26:39
332 forum posts
16 photos
It's certainly what Dad called a Dreadnought file.
George B.
mechman4815/02/2020 18:43:21
2588 forum posts
392 photos
Also known to be used by farriers / blacksmiths when re-shoeing horses.
George.
Adam Mara15/02/2020 19:00:56
91 forum posts
4 photos
Very likely an Aven Trimmatool blade, a Surform rival from the 50's and 60's, as far as I can remember!, sold a few in my time.
Speedy Builder515/02/2020 19:01:38
1935 forum posts
132 photos
We used to use them on aircraft aluminium panels. They used to slice your fingers when your hand continued pushing, but the file stopped moving. We also used Millenicut files. These has straight teeth in sets of 5 , 4 teeth were normal and the 5th was serrated.
Dreadnaughts were a very coarse file, followed by bastards, straight cut and second cut. File cards were used to remove swarf from the file and chalk rubbed onto the file to a) stop swarf sticking to the file and b) make the cut finer for finishing.
Re-cut files had been acid dipped to "sharpen" used files.
John Baron15/02/2020 20:31:43
171 forum posts
69 photos
Posted by Speedy Builder5 on 15/02/2020 19:01:38:
+1
old mart15/02/2020 20:36:29
1251 forum posts
116 photos
As well as soft alloys, they work on wood, I have flat and half round. I used to have a double sided flat with a different coarseness each side.
Ian Skeldon 215/02/2020 20:42:13
461 forum posts
30 photos
I used em years ago on lead loaded car bodies, they were known as dreadnoughts but not sure if that's a reference to the make or type. As mentioned, they do make a mess of your fingers if the file stops quickly and you don't.
bricky15/02/2020 20:45:16
414 forum posts
48 photos
I have a flat blade of steel the lengthe of the file and it has a file handle,there are holes at both ends to which two flat dreadnought blades are attached with small bolts.One of the blades is flat and the other is half round which bolt on one at a time.I have used these blades on steel and if there is a lot to remove and shape they are great.
Frank
Anthony Knights15/02/2020 23:54:37
332 forum posts
128 photos
Thank you everyone who replied.
