Tanks for CO2 engines.
Andrew Tinsley15/02/2020 15:39:29
987 forum posts
I am working on my collection of model aircraft CO2 engines, bringing them up to a good working standard. Some of the older and rarer models have lost their tanks along the way and I need to do something about it if they are ever to fly again.
The tanks are smaller versions of a Sparklets capsules (used for making fizzy drinks). I need tank sizes from 1 to 10 cc capacity. The originals appear to be extruded or maybe swaged aluminium and are only a few thou thick. Making such lightweight tanks seems to be a difficult operation without sophisticated kit.
Does anyone have any constructional suggestions or maybe some commercial equivalent used in another application?
Thanks.
Andrew.
P.S. The tanks contain liquid carbon dioxide, in case anyone is unfamiliar with these things.
John Haine15/02/2020 15:53:33
2899 forum posts
149 photos
Similar tanks are used for cycle tyre inflators and you can buy both the tanks and nifty screw-on valve assemblies from bike shops, or occasionally at Aldi.
mgnbuk15/02/2020 15:58:02
653 forum posts
28 photos
Might 12 gramme CO2 air gun cartridges be suitable ? They look like this
These are steel, approx.16.5mm diameter x 83.25mm overall length. The neck is approx. 7.3mm diameter x 9.3mm long. An empty one I have here weighs 28 grammes.
Happy to send you a couple of empties to play with if you think they may be of use.
Nigel B.
Andrew Tinsley15/02/2020 18:51:27
987 forum posts
Hello John, that sounds interesting, must google them and see what is available Nigel that is the sort of shape I am talking of, unfortunately they are too big for most of the engines and the weight is way too high. Pity they don't come in smaller sizes!
Thank you both for the suggestions,
Andrew.
Andrew Tinsley15/02/2020 18:58:38
987 forum posts
Hello John,
Not sure if I am looking for the right thing, but the stuff I am turning up has a capacity of about a liter! Ideally I would like to go down to 2 cc or less for the smaller engines.
Thanks again,
Andrew.
JasonB15/02/2020 19:08:56
17296 forum posts
1862 photos
1 articles
The cycle tyre inflators usually come in 12 and 16g so probably too big. Put "CO2 Bike Canister" into e-bay to see loads of them.
Jeff Dayman15/02/2020 19:09:21
1759 forum posts
45 photos
Gas or liquid filled thermostat bulbs have a test-tube shape made of thin copper and a small thin copper tube leading back to the switch box for the stat. You might ask a heating contractor for some scrap ones where the stat is bad. Usually the bulbs and tube are fine, just the switch in the box goes bad. Link below to the kind of stat I mean.
Years ago there was a premium cigar that came in a test tube shaped aluminum tube. Two of these, if they are still made, could be cut to desired length and aluminum-soldered back to back to form a nice light tank of a few cc's. A tobacco or cigar shop (if there are still any about) may know where to get some of the empty tubes. Just a thought.
https://www.jamesbondlifestyle.com/product/romeo-y-julieta-churchill
Edited By Jeff Dayman on 15/02/2020 19:29:37
Edited By Jeff Dayman on 15/02/2020 19:32:52
JasonB15/02/2020 19:37:15
17296 forum posts
1862 photos
1 articles
Looks like some of the Nitrous Oxide capsules come in 8g which is getting closer in size. Look for whipped cream or hippy crack
Ady116/02/2020 09:33:02
3575 forum posts
514 photos
There must be a few enthusiast sites out there who have solutions
I do know that pressurised bottles can be quite sophisticated seamless construction and have rolled threads for strength
Edited By Ady1 on 16/02/2020 09:34:11
old mart16/02/2020 19:28:47
1243 forum posts
115 photos
Making your own to be also lightweight is not really viable as CO2 in liquid form is at a pressure depending on temperature of just below 1000 psi.
Neil Wyatt16/02/2020 20:53:43
17356 forum posts
690 photos
77 articles
Gasparin CO2 power motors have small, lightweight aluminium tanks that hold liquid CO2.
They appear to have lids possibly screwed and bonded on with a screwed fitting for the pipes.
They are very light so they can't be too thick. Bear in mind they are small (I read 3cc somewhere).
DrDave16/02/2020 21:37:56
187 forum posts
36 photos
Have you tried to contact Gasparin to see if they do spares? They still have a website (gasparin.cz), but it is not clear if they are still a going concern.
DrDave16/02/2020 22:17:47
187 forum posts
36 photos
Or try here
Steviegtr17/02/2020 00:25:44
792 forum posts
180 photos
According to my bitdefender it just blocked a Trojan virus in your posting.
Steve.
We blocked this dangerous page for your protection: https://thumbs.worthpoint.com/zoom/images1/1/0411/10/gasparin-air-tanks-co2-engines-pcs_1_618756a20836c88d22f138e9b90a3f4e.jpg Threat name: Trojan.GenericKD.33016580 Dangerous pages attempt to install software that can harm the device, gather personal information or operate without your consent.
Be careful.
DrDave17/02/2020 19:10:19
187 forum posts
36 photos
Posted by Steviegtr on 17/02/2020 00:25:44:
Steve.
Be careful.
Thanks for the heads-up, Steviegtr. I did the browsing & posted the link from my ipad, so didn’t have a warning. You never can be too careful nowadays.
Andrew Tinsley17/02/2020 19:21:40
987 forum posts
Unfortunately Ing Stefan Gasparin died couple of years ago, otherwise I would have got the tanks from him. I believe that one of the Prague based dealers / model shop may have some of his stock, but for the life of me, I cannot remember his name.
Liquid CO2 doesn't need a massive container for a few cc size. The tanks are amazingly thin aluminium and I have made the screw in lids with a filler vent and supply tube to the motor without any drama. The real problem is the aluminium tank!
Andrew.
JasonB17/02/2020 19:26:41
17296 forum posts
1862 photos
1 articles
I just put "Gasparin tank" into google and first hit seems to have a good range
Edit, same source as Dr Dave. (It's safe, the photo Neil posted is what threw up a warning)
Edited By JasonB on 17/02/2020 19:28:55
Andrew Tinsley17/02/2020 20:05:50
987 forum posts
Hello Jason,
Jiri Linka is indeed the man I was trying to remember! Thank you everyone source of tank now found. That will enable me to get the older CO2 motors back into the air!
Andrew.
Michael Gilligan18/02/2020 00:09:15
15001 forum posts
638 photos
Don’t know much about CO2 motors, but; being intrigued by this thread ... I found this: **LINK**
http://www.gasparin.cz/page.php?page=co2/motors/motors&lng=en#history
The Fritz Mueller download is a gem.
Ausee.com.au
