Are spares available
mick H | 10/02/2020 09:48:51 |
735 forum posts 21 photos | My usual soldering iron failed over the weekend so I dug out a Henly Solon 25W iron which I bought as used/new some years ago. Sadly this also failed after about 10 minutes work on electronic components. When I stripped it down the heating element seemed to have suffered a partial disintegration. Working on the principle that I have never had anything but a positive response from the members of this site, I thought it worth asking whether Solon spares are available at possibly some remote outpost ? Mick |
David George 1 | 11/02/2020 05:51:21 |
![]() 1426 forum posts 456 photos | Hi Mick I would have thought that a soldering iron of that age would have used a simple nichrome wire element and there are a few seller's on the net. You would just have to measure the wire gauge and order to suit. David |
Speedy Builder5 | 11/02/2020 06:58:06 |
2179 forum posts 152 photos | £7.99 for a 25watt Henly. on ebay ! |
mick H | 11/02/2020 07:57:52 |
735 forum posts 21 photos | Ridiculous nostalgia really, I suppose, but this iron has not been used and is identical to one I had when I was about twelve years old. There are probably better items on the market but nostalgia strikes again. Maybe I will have a look at a different nichrome wire element as David suggests. Thanks for the help. Mick |
Russell Eberhardt | 11/02/2020 09:09:17 |
![]() 2602 forum posts 85 photos | Can you still buy "Savbit" copper bearing solder to stop the bit disolving? P.S: To answer my own question, CPC list it and it is still a tin/lead alloy. Russell Edited By Russell Eberhardt on 11/02/2020 09:14:04 |
John Haine | 11/02/2020 09:33:42 |
3521 forum posts 194 photos | I don't know how many Solon irons I got through. Horrible tat - had some at home, used others in development labs on holiday jobs. When I started working after graduating I discovered Weller irons, what a revelation. Frankly I'd just buy a proper modern iron. |
Nick Clarke 3 | 11/02/2020 09:38:47 |
![]() 1008 forum posts 34 photos | One advantage of the larger Solon irons was the heat capacity of the massive bits - and if the 65W job I used to use was not hot enough it nicely fitted through the grill of the 2 bar electric fire to get a bit of extra warmth! |
Ian S C | 11/02/2020 10:27:02 |
![]() 7468 forum posts 230 photos | I still use the 65W Solon that dad bought before WW2 when he was doing radio repairs. I think it is all origional, tip and element. For larger work I have a 175W Weller. When I got the Weller the tip was badly eroded A new tip was going to be $NZ80, so I wen't and saw my metal supply man and bought a piece of 20 mm copper, I think it was 100 mm long. I have a pair of old copper soldering bits, about 2lb each, which each heat quickly on a gas ring. Ian S C |
Geoff Theasby | 11/02/2020 10:41:07 |
613 forum posts 17 photos | <Ahem!> I refer the honourable gentlemen to the Henley Solon Owners Club, started in the pages of Club News. There are a multitude (3) of enthusiasts/obsessives, membership is free, and you get nothing for it. (Unless, of course, you have spare parts to help the afflicted above) |
John Haine | 11/02/2020 11:00:01 |
3521 forum posts 194 photos | One interesting failure mode I experienced more than once. Handle was in two parts with a horizontal split line, moulded from some sort of Bakelite material. The part of the handle nearest the element tended to get quite hot and the plastic degrade, to the point that one day when you were pressing the bit against a terminal part of one half of the moulding would fracture along a moulding feature and the entire hot element part become detached, apart from the live wires. Exciting! |
Pete Rimmer | 14/02/2020 18:15:18 |
870 forum posts 54 photos | Posted by mick H on 10/02/2020 09:48:51:
My usual soldering iron failed over the weekend so I dug out a Henly Solon 25W iron which I bought as used/new some years ago. Sadly this also failed after about 10 minutes work on electronic components. When I stripped it down the heating element seemed to have suffered a partial disintegration. Working on the principle that I have never had anything but a positive response from the members of this site, I thought it worth asking whether Solon spares are available at possibly some remote outpost ? Mick I think that the old Solon elements were insulated with asbestos, so you might want to take care with the debris of a disintegrated one. |
Steviegtr | 15/02/2020 00:39:16 |
![]() 1757 forum posts 233 photos | I just bought a soldering station from Lidl. I think it was £6.99 Controller + holder. Even has some reels of solder with it. Steve. |
Nicholas Farr | 15/02/2020 10:06:45 |
![]() 2535 forum posts 1204 photos | Posted by Pete Rimmer on 14/02/2020 18:15:18:
My usual soldering iron failed over the weekend so I dug out a Henly Solon 25W iron which I bought as used/new some years ago. Sadly this also failed after about 10 minutes work on electronic components. When I stripped it down the heating element seemed to have suffered a partial disintegration. Working on the principle that I have never had anything but a positive response from the members of this site, I thought it worth asking whether Solon spares are available at possibly some remote outpost ? Mick I think that the old Solon elements were insulated with asbestos, so you might want to take care with the debris of a disintegrated one. Hi, I didn't find any asbestos in this old 250W Solon iron. The element is wound on Mica sheet and Mica sheets separate the two elements from each other with two narrower thin iron plates in the middle and Mica sheets insulated the elements on the outside, the whole assemble then fitted into the slot of the copper bit. The outside Mica sheets just fell to bits during disassemble. Wont bother to try and fix this one, but might mount the copper bit onto a piece of steel and heat it in a flame, maybe one day. Regards Nick. |
