milling crankshaft on cnc mill using A axis
geoff adams02/02/2020 15:54:35
160 forum posts
195 photos
iam working a midget engine and wanted to rough out the journal on the cnc mill i wrote a program but Jason B sent me link for program all i had to do was enter the stock dia the throw of the journal and dia of journal
if anyone is interested in the program iam sure Jason will post the link
iam very impressed very easy to set up
Geoff
JasonB02/02/2020 16:46:10
17828 forum posts
1949 photos
That is better than the usual thump, thump, thump of turning from the solid. I wonder if a flat ended ctr cutting bit would work better than the rounded one you were using as the cutting speed at the edge of the tool should be faster.
For those interested the program is one the late John S wrote and used to demo the Sieg CNC machines at shows. Works straight out of the box for machines like the Sieg that have their 4th axis on the right but needs a slight tweak if it is on the left.
fizzy02/02/2020 17:28:52
1705 forum posts
115 photos
that would make life simple...if only I ever dared to fit my 4th axis. Why not go the whole way and cut to size with a flat tool? Surely a good finish is possible? My cnc computer got filled with dust and went pop earlier in the week so had to drill 300 holes by hand, awful job! Time to build a decent enclosure for the pc and driver box so it doesnt happen again. Theyre great when they work!
geoff adams02/02/2020 17:43:59
160 forum posts
195 photos
the cutter is an 8mm flat slot drill i think its the video gives the impression its a rad cutter
Geoff
Emgee02/02/2020 17:45:46
1445 forum posts
212 photos
Jason
Is the crankshaft program available from your Dropbox with a link please ?
Emgee
JasonB02/02/2020 17:50:08
17828 forum posts
1949 photos
Can be copied from the first post in this thread, also a Linux version further on, JS's was for Mach3
Martin Connelly02/02/2020 18:32:13
1222 forum posts
147 photos
F50
G19
G01 X0 Y0 Z10 A0
G060 A360 Y0 Z10 K10
G17
M30
Try this. Gives the required motion. Simple to understand. I could add parameters to allow for throw and pin radius and offset for subsequent pins. This will currently give a zero diameter pin with stroke of 20 if the bottom of the cutter is on the a axis centre line when z=0. Bottom of the cutter 3mm above a axis centre line at z=0 gives a 6mm diameter pin.
Martin C
Edited By Martin Connelly on 02/02/2020 18:34:52
Andrew Johnston02/02/2020 18:49:39
5402 forum posts
625 photos
Posted by fizzy on 02/02/2020 17:28:52:
Standard endmills and slotdrills are not flat on the end. They're slightly hollow ground, so you end up with a barrel shaped crankpin not a cylindrical one. The problem can be ameliorated, but not eliminated, by offsetting the cutter.
Martin Connelly02/02/2020 19:12:41
1222 forum posts
147 photos
F50
G19
G01 X0 Y0 Z10 A0
G02 A360 Y0 Z10 K10
G17
M30
Fixed the G02 line. Didn't see the corruption caused by editing the line.
Martin C
Martin Connelly02/02/2020 19:57:49
1222 forum posts
147 photos
F50
G19
G01 X0 Y0 Z10 A0
G02 A360 Y0 Z10 K-10
G17
M30
Added the minus sign in K-10
This is what happens when you type it in here before checking it in Mach3.
Martin C
Another thought, G02 may need to be G03 depending on the a axis positive direction.
Edited By Martin Connelly on 02/02/2020 20:06:26
Ian Johnson 102/02/2020 21:33:15
248 forum posts
77 photos
Great to see some 4th axis CNC and using a John Stevenson program too! Turned out nice.
I use Vectric Vcarve which uses the Z axis as the A axis when rotary milling, bit of a cheat really because it is still only three axis milling not 4 axis. So I had to start writing my own programs for true 4 axis milling, nothing as ambitious as this though!
I need to get my 4th axis plugged in, not used it for a while, I also need a tail stock support like yours before attempting something like a crank.
Is it an optical illusion or is the cutter slightly off centre to the journal?
Ian
old mart02/02/2020 21:50:21
1519 forum posts
136 photos
I take it that the finishing cuts after the photographs were taken were by resetting the Y axis two or three times to get the journals cylindrical.
Emgee02/02/2020 23:41:52
1445 forum posts
212 photos
Jason.
Having read all posts on the MEM forum am I correct in thinking the first Mach3 posted code is functioning correctly provided direction of the A axis is correct ?
Emgee
JasonB03/02/2020 06:57:18
17828 forum posts
1949 photos
Emgee, Yes, that is the one Geoff used.
Old Mart, no the middle of the pin is slightly raised due to the shape of the end teeth of a typical cutter as already mentioned by Andrew as the cutter always stays directly above the pin's ctr line by moving in the Y axis.
Should also say that it was mostly written by Adam, John's son.
old mart03/02/2020 19:20:54
1519 forum posts
136 photos
No, Jason, if the cutter stayed above the pin centre line the centre of the pin would be larger. Clearly the cutter centreline was offset as the machining marks confirm, making the pin smaller in the centre.
JasonB03/02/2020 19:46:20
17828 forum posts
1949 photos
I agree that the one Geoff has shown does appear to have fillets in the internal corners which suggests something is off, which is why I thought a ball nose cutter was being used.
This is how one done by JS looks with no additional passes after running the code.
Originally posted by JS in this thread with sketches by Andrew of how Y follows the pin
old mart03/02/2020 20:34:02
1519 forum posts
136 photos
Is that a 7 cylinder engine with only 2 main bearings or what is it?
JasonB03/02/2020 20:48:23
17828 forum posts
1949 photos
Read the thread.
old mart03/02/2020 22:17:14
1519 forum posts
136 photos
Found it eventually after the usual ramblings, just a demo.
geoff adams04/02/2020 06:33:09
160 forum posts
195 photos
Morning all from the replies it seems that i have the y axis off creating a fillet in the corner
the a axis is left on the mill all the time i will check the set up this morning. mach 3 does lose it self, i relied on it remembering the y offset
anyway off to specsaves this morning to pick up new glasses that might help will let you all know how i get after resetting and checking the setup and running another test piece
thanks Geoff
