Fly press weights.
larry phelan 121/01/2020 09:47:33
577 forum posts
11 photos
Good morning all,
Having now got my flypress set up on its new bench, I am looking for ideas about how to make weights for it. Suitable lumps of cast iron are somewhat thin on the ground around here. Even the local scrapyard has nothing much to offer [scrapyards are not what they used to be ]
Any ideas ? I,m sure some of you have been there, done that.
Thanks in advance for any ideas.
RichardN21/01/2020 09:54:16
112 forum posts
9 photos
Large bean can full of lead on each arm... I've seen that in many workshops.
Paul Lousick21/01/2020 09:55:19
1285 forum posts
512 photos
Dumbbell exercise weights are a source of cast iron discs.
Paul
Edited By Paul Lousick on 21/01/2020 09:56:48
David George 121/01/2020 10:01:31
1054 forum posts
333 photos
Have some cast. Make a wooden or plastic model, two halves of a sphere. And a core mould for the hole to match the top of the handle. You could sell spares.
David
noel shelley21/01/2020 11:35:08
72 forum posts
It would not be rocket science to cast them on the stubs in lead. They would then fit well. Use a ball as a pattern to make a split mold in plaster of paris. set up on stub, seal bottom with clay or plaster, hole in top. Pour in lead. leave for 30mins open, repeat on other stub if needed. Simples ! Noel.
noel shelley21/01/2020 11:36:15
72 forum posts
If You need more details PM me.
not done it yet21/01/2020 12:41:22
3933 forum posts
15 photos
Cement works local? They will use large cast balls. Generally, up to about 100mm.
Jeff Dayman21/01/2020 12:44:02
1719 forum posts
45 photos
Surely some sawcut and drilled steel cylindrical shapes would function just the same as spheres on a flypress? Much cheaper and easier to obtain than custom spherical castings I expect. All edges chamfered for safety of course.
If they need to be hollow / lead filled, they could be fabbed from steel tube and a steel disk welded together then lead cast in.
Baz21/01/2020 14:01:54
317 forum posts
Couple of old cannonballs, drilled and filed to fit?
BOB BLACKSHAW21/01/2020 14:28:17
263 forum posts
59 photos
If you need any advice on tooling and how the press can be used for fine limit work. PM me.
Bob
old mart21/01/2020 15:20:52
1085 forum posts
113 photos
As already mentioned, exercise weights would be useful, and there are a lot of unwanted ones about. Whatever weight you use, make sure it is secure on the press, as they can fly off, I have witnessed it happen.
Buffer21/01/2020 15:35:33
131 forum posts
35 photos
Float from a toilet valve in sand then pour in molten lead.
Bandersnatch22/01/2020 01:37:53
1398 forum posts
40 photos
Posted by Paul Lousick on 21/01/2020 09:55:19:
... as long as you don't need to machine them too much. I tried these for a model-engine flywheel once - the skin went all the way through. Quality they are not (nor need to be in their intended use).
Paul Lousick22/01/2020 04:26:01
1285 forum posts
512 photos
Exercise weights are made from similar cheap cast iron as used in sash window weights. Sometimes it is OK to machine but Murphys Law says that most of the time it is crap. But they are cheap and good if used in the right application. Car brake discs are better souce of machinable cast iron if it is a suitable size to suit the application.
Paul.
bricky22/01/2020 07:31:59
402 forum posts
47 photos
Lead as suggested in a mould ,if plaster of paris is not availiable use scimming plaster from a building merchants.
Frank
Bazyle22/01/2020 09:41:46
4894 forum posts
195 photos
Modern exercise weights are concrete with a plastic sheath. If the mounting is a spike like mine or just a rod you can make a mould of that out of plasticine, cast a soft plaster 'spike', cast a concrete block around that and dig out the plaster. No point in using anything more expensive than concrete as size is not an issue.
AJW22/01/2020 10:46:38
278 forum posts
117 photos
On my flypress I used an old 3 jaw chuck nipped up on the stub, worked well enough!
Alan
Paul Lousick22/01/2020 11:58:02
1285 forum posts
512 photos
One of the options given was to to use concrete but if you would like the weight to be heavier for its size, add lead or steel to the mix.
One of the companies which I worked for manufactured industrial cranes like the ones on building sites but much bigger and the cost of cast iron or steel for the counter weights was expensive. The weights were more than 20 tonnes each. They were made by casting concrete using steel as the aggregate. Mainly from the discarded pieces remaining after punching parts from steel plate. The smaller the parts, the better because you can pack in a higer proportion of steel. For the flypress weight you could use any small metal objects, nuts, bolts, lead fishing weights, etc. Use concrete, polyester resin, builders joint filler or other bonding agent to hold the casting together.. The mould coukd be simply a childs plastic ball.
Paul
Circlip22/01/2020 12:18:52
1020 forum posts
"Where have all the foundrys gone, Long time passing .........."
Pity you're not in China or India.
Regards Ian.
ega22/01/2020 12:46:27
1436 forum posts
115 photos
Posted by old mart on 21/01/2020 15:20:52:
I accepted a set from a friend with this in mind only to find that the outer plastic casing contained some brownish-coloured material that definitely wasn't CI.
Does anyone know what alternatives to CI are used fro this purpose?
