A good toolpost drill design
Chris Thorn19/01/2020 22:00:50
14 forum posts
4 photos
Hi all
I find myself often having to cross drill or drill on a pcd on the lathe. I have been searching the forum and web for a good toolpost drill design.Up to now I have used a Dremmel type drill to fit on my Dickson tool post on my S7 but as everyone knows they run too fast and don’t have the torque required to do anything but a small hole. I have Steve Jordan’s ideas on YouTube but they seem unwieldy and top heavy. Has anyone pout there made a robust drill that can be speed adjustable and plenty of torque?
Chris
Mike Poole19/01/2020 22:49:39
3073 forum posts
72 photos
If you can find one and have deep pockets the the Quick Step mill is a nice tool for this sort of work. A spindle with a drive from a motor often using a round belt is another popular option. The Arrand spindle is sought after and fetches a good price but they often appear on eBay and sometimes a bargain price will be paid. The drive for the spindle will be whatever you want to build though.
ega20/01/2020 00:04:14
2266 forum posts
188 photos
Before I got my QSM I had made a very simple holder to fit the 47mm (?) collar on a drill gun fastened to the cross slide at centre height.
Even simpler, clamp a bar with suitable hole in the toolpost and use this to guide a handheld drill.
bricky20/01/2020 00:21:35
522 forum posts
68 photos
I made a toolpost drill form the quill of a cheap in my case free chinese drill press.The speed of the moter was 2000rpm so I thought it would make one and also do light grinding.I stripped the drill and cut down the column with the coller with three fixing holes for the base table column ,this I now use on the mill and the base I now use fastend to the drill columm to take a scissor jack for lifting my heavy drill table.The column that I had left was used up in projects and the motor is also used.So my point is a cheap drill press could be worth looking at.
Frank
Hopper20/01/2020 00:22:00
5505 forum posts
137 photos
Use an electric pistol drill, the type with the round section on the nose designed for a second handle to stick out sideways. Make a suitable bracket that fits one end in the tool post and the other having a large round hole to fit the nose of the pistol drill. Plus some kind of cut in the bracket with a clamping bolt so it clamps down on the drill body.
You can even fit a shaft with an eccentric on it to the trigger of a variable speed drill for "hands off" operation at the rpm of your choice.
Paul Lousick20/01/2020 00:27:45
1862 forum posts
661 photos
If a hand held gun drill is too bulky, use a flexible drive cable attached to the drill with the chuck on the cable held in the too post. Should be suitable for drilling holes up to 6mm or slightly bigger.
Paul.
Edited By Paul Lousick on 20/01/2020 00:28:17
Robert Atkinson 220/01/2020 07:25:40
1090 forum posts
20 photos
My plan for this is to take the motor and gearbox out of an old cordless drill. I've kept an old Bosch that the NiCad batteries died years ago fir just this purpose. Some need the case to hold parts together but this can be solved at various levels of neatness (hacking the handle off to machining a shiny new housing. It will run off a 12V supply with speed control modified to a rotary knob.
Robert G8RPI.
David George 120/01/2020 07:42:16
1656 forum posts
497 photos
Here is my spindle drive I made recently. I had a motor left over from doing a mod to my Z axis on Chester 16V mill.
David
Michael Cox 120/01/2020 09:53:32
544 forum posts
27 photos
Hi Chris,
I only have a minilathe and I apopted a different approach using a flexible drive shaft to take power to the cross-slide, see:
I only fitted a 4 mm chuck but if I made it again I would fit a 6 mm chuck as there is more than sufficient power.
Roderick Jenkins20/01/2020 10:19:11
2123 forum posts
582 photos
I made mine from a plain shank er11 collet holder, a pair of angular contact bearings and a 200w 240v treadmill motor.
Rod
Nicholas Wheeler 120/01/2020 10:22:38
740 forum posts
51 photos
ER11 spindle motor mounted on a vertical slide. I bought the motor, mounting block, power supply and collets for £90, and spent about 10 minutes drilling and tapping 8 M6 holes to mount it to either face of the slide. That means it will mill and drill with, or along the lathe axis and at any angle to it.
Neil Wyatt20/01/2020 10:37:13
18777 forum posts
733 photos
80 articles
This is how they didikt in the old days, 'Potts Spindle' castings still available.
I made this out of an old pistol drill, I fitted the epicyclic gearbox in the steel block, the motor is in the old spice container. Drills well, doesn't mill very well due to end play.
Roderick Jenkins20/01/2020 10:41:00
2123 forum posts
582 photos
A bit more discussion on these Here
Chris Thorn20/01/2020 13:12:56
14 forum posts
4 photos
Thanks for the suggestion Guys.
I guess it comes down to either a Flexible shaft design or go for a motor mounted above the spindle to provide power. I like your modification Mike .
Rod does the treadmill motor have plenty of torque at lower revs?
Mike Waldron03/03/2020 14:20:11
40 forum posts
Neil:
I had no idea that anyone stocked the Potts castings still.
who might that be?
HasBean03/03/2020 16:24:07
141 forum posts
32 photos
Posted by Neil Wyatt on 20/01/2020 10:37:13:
Nifty idea, I have some in the bathroom cabinet...........
Neil Wyatt03/03/2020 17:40:34
18777 forum posts
733 photos
80 articles
Posted by Mike Waldron on 03/03/2020 14:20:11:
Neil:
who might that be?
Used to be available from Hemingway, but I think it's been discontinued, although they sell castings for two other Potts projects.
If you can weld, it wouldn't be hard to fabricate and you might actually get a better result.
Neil Wyatt03/03/2020 17:41:05
18777 forum posts
733 photos
80 articles
Posted by HasBean on 03/03/2020 16:24:07:
Silly billy!
Rod Renshaw03/03/2020 19:33:57
333 forum posts
Hi all
I have an arrangement using an Arrand ball bearing spindle and it works quite well for small holes up to about 4 mm.
For larger holes it's worth reflecting that it takes the same power to drill a hole in the lathe as it does in a drill press, and quite a large motor is needed to drill holes of (say) 6 mm diameter or more, especially in steel. Anything much less than 1/4 HP may seem underpowered and very slow, and 1/2 HP is much better.
Rod
Joseph Noci 103/03/2020 19:46:28
1006 forum posts
1247 photos
Posted by Robert Atkinson 2 on 20/01/2020 07:25:40:
Robert G8RPI.
Problem with this approach is that most cordless drills, and generally all the lower costs ones, have a rather low high speed rpm top end - typically 1200 to 1500rpm and that tends to be a bit low for the smaller drill sizes, below 3mm perhaps. Also, the front bearing is not the greatest, and neither is the chuck, all giving rather poor runout performance.
walker midge
JD Metals
rapid Direct
