Gipsy manifold material
David K19/01/2020 15:32:27
211 forum posts
152 photos
According to my plans the inlet manifold should be made of mild steel.
looking at a couple of completed engines on the internet I notice one has used brass and another has used a mixture of brass and steel as the one pictured below.
Is there any reason for using brass , as in the bottom plate on this one,
old mart19/01/2020 15:34:58
1085 forum posts
113 photos
It looks pretty.
JasonB19/01/2020 16:05:52
17061 forum posts
1839 photos
And it does not show the silver solder joint
Steviegtr19/01/2020 16:13:46
469 forum posts
126 photos
WOW. Very nice.
David K19/01/2020 19:25:39
211 forum posts
152 photos
Stainless it is then.
JasonB19/01/2020 19:33:44
17061 forum posts
1839 photos
I think if I were doing it I would machine some stock down to 0.475" and then mill out the recess from below to 0.425" deep and then recess the bottom plate into the 3/8" wide passage so no joints are visible unless you are looking from underneath.
Andrew Johnston19/01/2020 19:41:42
5111 forum posts
594 photos
Depends on which engine, but on the Gipsy Major the inlet manifold was steel. It has two half pressings with a welded seam and individual steel plates welded on that bolted to the cylinder heads.
Tim Stevens20/01/2020 18:19:24
1123 forum posts
Brass has an expansion coefficient very close to that for Al alloys. The value for Steel is rather less. I suspect this might have been one factor in the mind of the bloke what made it.
Cheers, Tim
Paul Kemp21/01/2020 00:45:41
376 forum posts
18 photos
Posted by Tim Stevens on 20/01/2020 18:19:24:
Cheers, Tim
Not sure I follow your thinking there? Steel top, brass bottom, sounds like a recipe for a banana to me? As it's the inlet manifold would it actually get hot enough over its length to make any appreciable difference? If it were the exhaust a different story maybe. If you are suggesting coef of ex to match the aluminium crankcase then that only holds good if the whole thing is brass?
Paul.
JasonB21/01/2020 07:14:01
17061 forum posts
1839 photos
The lower tapered part down to the carb is aluminium but at such a small size I doubt expansion would be an issue and the suggested Araldite to join it would have enough flex to compensate.
