Colouring steel
Steviegtr | 18/01/2020 02:09:29 |
![]() 2421 forum posts 336 photos | Anyone know how to blacken steel or any other metal. Is it a dye or a process with chemicals. I use liver of sulphur for Zinc. But not sure about other metal's. By blacken I mean like gunmetal etc. Steve. |
Thor 🇳🇴 | 18/01/2020 06:00:04 |
![]() 1598 forum posts 45 photos | Hi Steve, You can buy so called cold blacking solutions for steel, a friend of mine has tried and it works. I just heat the mild steel parts to about 270 to 300 deg. C and apply linseed oil, the treatment will to some degree protect against corrosion. Others use motor oil. The treatment is best done outdoors. Thor |
Baz | 18/01/2020 07:46:44 |
705 forum posts 2 photos | I have also used the cold blacking kits for steel and am quite impressed with them, the only one that I cannot get to work is the brass blacking kit. |
Danny M2Z | 18/01/2020 08:39:07 |
![]() 962 forum posts 1 photos | Posted by Steviegtr on 18/01/2020 02:09:29:
Anyone know how to blacken steel or any other metal. Is it a dye or a process with chemicals. I use liver of sulphur for Zinc. But not sure about other metal's. By blacken I mean like gunmetal etc. Steve. Just google "cold blue for barrels" then pick whatever you can legally purchase. One tip, Cleanliness and de-greasing is mandatory. * Danny M * |
Mick B1 | 18/01/2020 09:10:41 |
2155 forum posts 117 photos | Gun-bluing paste G96 works for me on a warm and well-degreased surface. It's generally well-regarded as a quick and relatively simple home bluing or blacking solution. Last for decades at least. There's a Phillips lookalike that works pretty much the same. See the 24-pdr cannon in my album for evidence. Edited By Mick B1 on 18/01/2020 09:11:59 |
Mike Woods 1 | 18/01/2020 22:11:56 |
40 forum posts 1 photos | There was a discussion of blueing (and blacking) steel in a recent post, which may be useful. https://www.model-engineer.co.uk/forums/postings.asp?th=141342&p=1 |
Steviegtr | 18/01/2020 23:33:37 |
![]() 2421 forum posts 336 photos | Thanks all. |
