Dell | 10/01/2020 17:44:50 |
![]() 101 forum posts 34 photos | Hi all
Ian McVickers | 10/01/2020 18:16:44 |
222 forum posts 110 photos | Not good that you've had to send it back but at least Warco customer service has sorted out a refund for you. Cant you fit in something a bit bigger like a Colchester Bantam size? |
Emgee | 10/01/2020 18:48:44 |
2404 forum posts 285 photos | Derek, seems you had a bad experience with the lathe from Warco but they did do the right thing by refunding your money. Not sure you will have a much better experience with an Emcomat SL lathe, they are pretty lightly built so prone to flexing if not treating them with a lot of care. Emgee |
Former Member | 10/01/2020 19:18:31 |
1329 forum posts | [This posting has been removed] |
Dave Wootton | 10/01/2020 19:30:58 |
290 forum posts 65 photos | Hi Have you considered a Hobbymat if you are looking at a small machine, never used one but I know someone who has been using ( and abusing) his since the80's, mainly on projects I would consider far too big and heavy for it with seemingly no problems or harm. So they must be tough little things, not sure if they are still made, but there should be a few about secondhand, there's one on the lathes.co.uk website at the moment. Dave
vintage engineer | 10/01/2020 19:44:59 |
![]() 256 forum posts 1 photos | Perhaps someone in their workshop was not doing what they should have done. They obviously tried to resolve the problem and they did the honorable thing and took it back and refunded you. |
Dell | 11/01/2020 09:07:30 |
![]() 101 forum posts 34 photos | Thanks for the replies Yes I can’t fault Warco for refunding my money but took lots of phone calls to get sorted, I have already purchased the Emco Unimat SL although I have yet to receive it and as I am mostly only going to be making very small brass clock parts it should be okay, only time will tell. i have seen about the motor shortcomings and the one I have purchased has two motors one on the lathe and one on the mill so maybe they have had an easier life but we will see. Dell |
Michael Gilligan | 11/01/2020 09:10:23 |
![]() 20056 forum posts 1040 photos | Sounds like a good choice to me, Dell MichaelG. |
Former Member | 11/01/2020 10:11:39 |
John Haine | 11/01/2020 10:11:59 |
4622 forum posts 273 photos | One problem with the early Unimats is that they used a different spindle thread, M12 x 1 IIRC, whereas the later ones and the C0 style lathes use M14 x 1. So it may be harder to find new accessories. |
Graham Meek | 11/01/2020 10:34:59 |
461 forum posts 299 photos | Posted by Derek Allum on 11/01/2020 09:07:30:
i have seen about the motor shortcomings and the one I have purchased has two motors one on the lathe and one on the mill so maybe they have had an easier life but we will see. Dell Hi Dell, As a long time Emco user I am confused. On the Unimat SL that I once owned the headstock was also the milling head. It was not until the introduction of the U3 that there was a separate milling head. Unless your machine has two headstocks, but I cannot see the point in that. As on the SL the headstock has to be removed to insert the pillar to set up for milling. Of the two machines the U3 was the better machine, I turned out some very good work on this machine. Do you have a photograph of your purchase? Regards Gray, |
Former Member | 11/01/2020 11:19:39 |
Andy Carlson | 11/01/2020 12:14:09 |
428 forum posts 132 photos | I have an SL and I like it a lot. For small work it is very handy to be able to pull it out of the shelf where it is stored, plonk it on the desk, plug in and go. I've even taken it out and about on occasions. I fitted mine with an ER16 collet holder which gets used for almost every job on the lathe. The M12 x 1mm spindle thread does indeed make it tricky to source attachments - I used an ARC Euro holder but needed to resort to using another lathe to make a backplate. There is a set of pictures on Flickr from a chap who made an ER16 holder almost entirely on the Unimat with a very neat trick for cutting the threads. https://www.flickr.com/photos/65657096@N00/albums/72157632104757918 Or one can be had from these folks... but that loses the advantage of machining the holder on the spindle where it will eventually be used. https://www.rcm-machines.com/en/chuck-er/collet-chuck-er16-with-m12-x-1-inside-thread/rcm12er16 Good luck with your Unimat! Regards, Andy |
Dell | 11/01/2020 16:10:08 |
Pictures as requested advert said Unimat SL
Former Member | 11/01/2020 16:45:25 |
Oldiron | 11/01/2020 17:35:57 |
960 forum posts 40 photos | In case people do not know Yahoo groups is being shut down by Verizon, Yahoo's new owners. The Unimat site is being transferred to Unimat. Not a member so not sure of the state of play at this time. It seems many of the Yahoo groups are transferring to www.groups.io and there is a bit of a backlog at the minute. regards |
Graham Meek | 12/01/2020 11:18:39 |
461 forum posts 299 photos | Hi Dell, As I suspected the milling facility is not as Emco intended. In some ways not a bad thing as the motors were an Achilles heel. Regards Gray, |
Andy Carlson | 12/01/2020 11:38:58 |
428 forum posts 132 photos | Looks like a nice unit that has been extensively improved. The milling/drilling column doesnt seem to owe much to Emco. I hope you are very happy together. |
Andy Carlson | 12/01/2020 11:41:15 |
428 forum posts 132 photos | Posted by Oldiron on 11/01/2020 17:35:57:
In case people do not know Yahoo groups is being shut down by Verizon, Yahoo's new owners. The Unimat site is being transferred to Unimat. Not a member so not sure of the state of play at this time. It seems many of the Yahoo groups are transferring to www.groups.io and there is a bit of a backlog at the minute. regards I was in the Yahoo group and my account was moved across automatically. As far as I can tell it's all up and running on groups.io |
Michael Gilligan | 12/01/2020 11:42:43 |
![]() 20056 forum posts 1040 photos | Posted by Andy Carlson on 12/01/2020 11:38:58:
Looks like a nice unit that has been extensively improved. The milling/drilling column doesnt seem to owe much to Emco. I hope you are very happy together. . +1 from me The column looks familiar ... possibly originally from a photographic enlarger Is it, perchance, 1_1/4” inches diameter ? MichaelG. Edited By Michael Gilligan on 12/01/2020 11:43:42 |
