VFD Question
3 phase voltages and setup for VFD
Carl Wilson 417/01/2020 12:00:02
671 forum posts
53 photos
Old mart should have added "on this site". Lot of clever clogs here.
SillyOldDuffer17/01/2020 13:09:21
6175 forum posts
1335 photos
Posted by Steviegtr on 16/01/2020 22:49:14:
The windings in most multi speed motors have multiple windings around a pole. So 4 windings on single speed & 8 windings on 2 speed & so on. This does not mean the motor goes from a 4 pole motor to a 8 pole motor as some have suggested. Its just a different winding on the same pole.
Not wrong exactly, but I think this depends on exactly what's meant by a 'pole'. To an electrical engineer a physical pole isn't necessarily the same as a magnetic pole.
If it walks like a duck and quacks like a duck it is a duck. When someone says a 'motor goes from a 4 pole motor to a 8 pole motor', they mean electrically, not literally. I prefer the electrical engineering view because Stevie's definition of 'pole' gives the wrong answer from:
RPM = Frequency * number of poles
I find it easier to think of motor poles in terms of effect rather than their physical layout and like to believe only motor designers have to do both! I could be wrong again...
Andrew Johnston17/01/2020 13:14:34
5635 forum posts
652 photos
I don't follow that? The equation for the synchronous speed (in rpm) of an induction motor is 2 times frequency (Hz) times 60, all divided by the number of poles. Assuming that the frequency is fixed then the only way to change the speed is to change the number of poles. Of course windings aren't added or removed, simply connected in a different sequence. But the upshot is to change the number of poles.
Edit: Thought better of it
Edited By Andrew Johnston on 17/01/2020 13:18:13
EngineDIY
