Imperial supplies of mild steel
Martyn Duncumb02/01/2020 22:09:37
41 forum posts
3/32" was a popular thickness of strip steel in various widths specified in articles in ME in the 60s and 70s.
Apart from round 3/32" none seems to be available now and the metric equivalent of 2.5mm does not seem to be listed either.
What does one do to get round this? Machine down from the next size up?
Thanks
Martyn
Andrew Johnston02/01/2020 22:19:35
5837 forum posts
662 photos
Unless some of the model engineering suppliers list it you'll need to cut from 2.5mm cold rolled sheet.
Roger Vane02/01/2020 22:57:56
100 forum posts
18 photos
Maidstone Engineering list 3/32" flats - 3/4" and 1" wide. (Phone no: 01580 890066)
Martyn Duncumb03/01/2020 11:24:35
41 forum posts
Many thanks for your suggestions. Can see now that sheet or broader strips can also provide what I want.
Martyn
duncan webster03/01/2020 20:03:20
2956 forum posts
34 photos
If we are talking bright strip, beware of cutting down the middle of say 3/32 * 3/4 to get 2 bits of 3/32*5/16, you will get 2 nicely curved bits. Been there, done that.
Martyn Duncumb03/01/2020 20:24:55
41 forum posts
Thanks Duncan, point noted.
Martyn
Tomfilery04/01/2020 10:08:42
127 forum posts
4 photos
Martyn,
You can still buy "key steel" in imperial sizes, but it will be expensive.
I assume it is used for keys to fix gears to shafts, so may not come in the exact size you need.
Regards Tom
Andrew Johnston04/01/2020 10:22:04
5837 forum posts
662 photos
Keysteel is normally a thou or two oversize so it can be filed/machined to fit the keyways.
DiogenesII04/01/2020 11:05:07
173 forum posts
72 photos
GLR Kennions still supply in 3/4 & 1" widths..
JasonB04/01/2020 13:01:06
19589 forum posts
2150 photos
Depending what you are doing with it and how deep your pockets are there is still quite a wide range of widths available in gauge plate
EngineDIY
