What to use on my Sherline mill to round off pinion wire leafs
Chris TickTock13/12/2019 17:27:07
297 forum posts
18 photos
Hi, I am getting better on my Sherline lathe but work to be done regarding my Sherline Mill. Later next year I hope to concentrate on the mill but until then can anyone suggest a possible workaround for this issue:
pinion wire comes in many diameters if you are lucky enough to find it but sometimes you may have the correct wire in terms of number of leafs but the wrong diameter. I am told it is possible to reduce the diameter and I can easily do this on the lathe. However you will be left with square edges that need rounding off. There are special cutters I am sure but until I get there is there something more prosaic like a burr that could be used on my mill for this small job if I had to do it?
Chris
Nigel Graham 213/12/2019 17:56:21
452 forum posts
I am not a clock-maker but looking at that in general terms, unless the radius is critical simply grind a small concave form tool from high-speed steel.
Another approach for more definite results is to make a form tool by drilling a hole through a piece of gauge-plate, cutting the corner off and heat-treating to suit.
Chris TickTock13/12/2019 20:39:13
297 forum posts
18 photos
Posted by Nigel Graham 2 on 13/12/2019 17:56:21:
Thanks Niigel, I get your first suggestion infact the method I will be using to make a brass wheel next year relies on making such a tool you first mention.
However unfortunately I cannot mentally get an image of the 2nd concept you suggest maybe someone could clarify this.
Chris
roy entwistle13/12/2019 21:32:07
1092 forum posts
In 65 years clock making I've never found a source of pinion wire. How do you know the diameter is wrong?
Roy
Chris TickTock13/12/2019 21:41:27
297 forum posts
18 photos
Posted by roy entwistle on 13/12/2019 21:32:07:
Roy
Hi Roy, this is hypothetical in as much as if you sourced a length of say 10 leaf pinion wire at say 9mm dia then needed for another job 8.6 mm you could turn the diameter down on a lathe but need to correct the leaf profile. My source was just a one off lot of new old stock. I suspect making your own is the norm unless you know different?
Chris
roy entwistle13/12/2019 21:57:36
1092 forum posts
The Module or DP would be wrong . you can get away with .5 Mod but that's about it How do you know what the diameter should be? If it's just one pinion then I would use a file
Roy
speelwerk13/12/2019 22:46:42
344 forum posts
1 photos
Posted by roy entwistle on 13/12/2019 21:57:36:
Roy
Never tried and perhaps in a clock you can get away with .5 Mod, but is it not .05 you mean since in a musical box governor it would wear out the corresponding wheel in record time. Niko.
Michael Gilligan13/12/2019 23:22:51
14624 forum posts
634 photos
To the best of my knowledge: traditional Horological pinion wire was never intended to be used ‘as supplied’ and will always need some shaping and finishing ... i.e. it is a convenient ‘make from’ material. Skimming it down to size will just mean that you need to do more of the same.
Very happy to be proved wrong !
JasonB14/12/2019 07:11:09
16912 forum posts
1817 photos
1 articles
Posted by Chris TickTock on 13/12/2019 20:39:13:
I would imagine something like this either grind up an HSS tool or drill/file some HCS to profile and then make a simple holder or even use a flycutter if you have one then you can make whatever shape you like- just the tips or the whole tooth form.
Couple of photos from my Milling for beginners series
roy entwistle14/12/2019 08:40:01
1092 forum posts
Speelwork Quite correct I did mean 0.05 Blame it on a senior moment blush
MichaelG Again quite correct. I've only seen pinion wire once and that was in the now defunct clock museum at
Prescot. I believe that it was made by drawing so could only be crude and possibly only made in watch sizes
Look up Wig-Wag polisher for interest
Roy
Michael Gilligan14/12/2019 08:58:50
14624 forum posts
634 photos
Largely ‘academic’ for most of us, because of the cost, but
Here, for reference, is Thornton’s page: **LINK**
https://ppthornton.com/product/pinion-cutter-2/
Note the range of sizes and counts surprise
The standard profile is described in BS 978 part 2, but obviously a reasonable approximation will work.
P.S. ... The lantern pinion is an admirable alternative, both technically and financially.
Michael Gilligan14/12/2019 09:12:53
14624 forum posts
634 photos
From the ninth edition, 1896, of Briitten’s ‘Handbook Dictionary and Guide’
Edit: Just found this : https://youtu.be/VHysXT7RaIM
... and don’t forget to watch Clickspring’s masterclass : https://youtu.be/XkJJid3_bhg
Edited By Michael Gilligan on 14/12/2019 09:30:04
Michael Gilligan14/12/2019 09:48:20
14624 forum posts
634 photos
Posted by roy entwistle on 14/12/2019 08:40:01:
[…] I've only seen pinion wire once and that was in the now defunct clock museum at
From Chris’s other recent thread, it appears he has some vintage stock of 8mm diameter pinion wire ... which would be a useful size for clockmaking.
https://www.model-engineer.co.uk/forums/postings.asp?th=147933&p=1
JasonB14/12/2019 10:10:07
16912 forum posts
1817 photos
1 articles
From your scan that's an interesting and simple way to relieve a small cutter and the "pusher" is useful too as a standard Ctr often stops you getting in close, bit like a half ctr in the tailstock.
speelwerk14/12/2019 10:20:47
344 forum posts
1 photos
What I found on clock fairs is too small for my use but being cheap just bougth it. This older thread is perhaps also of interest **LINK** . I cannot see myself acurate making large correctings to pinion leafs with a file, if needed it is better to make a new one the correct size. Niko.
Edited By speelwerk on 14/12/2019 10:21:40
Edited By speelwerk on 14/12/2019 10:24:44
blowlamp14/12/2019 10:22:55
1218 forum posts
82 photos
I think pinion wire is quite often filed/abraded and then polished to final form.
Michael Gilligan14/12/2019 10:40:38
14624 forum posts
634 photos
Posted by JasonB on 14/12/2019 10:10:07:
There was a lot of innovation in the American watch and clock industry. yes
... hence importance of the little book that linked in the ‘Build a watchmakers lathe’ thread
[quote]
For background reading, you will probably find no better reference than this: **LINK**
https://archive.org/details/watchmakerslathe00good
[/quote]
MichaelG..
Michael Gilligan14/12/2019 10:52:45
14624 forum posts
634 photos
Posted by Michael Gilligan on 14/12/2019 08:58:50:
Not sure if this **LINK** really counts as an ‘extract’ but anyway ...
Michael Gilligan14/12/2019 12:26:09
14624 forum posts
634 photos
Clever chap, Duane H. Church star
https://patentimages.storage.googleapis.com/6a/19/01/dc93bfb577df05/US476953.pdf
Chris TickTock14/12/2019 13:33:59
297 forum posts
18 photos
Really grateful for all help will study all posts carefully and report back.
Chris
mid gard rail Jan 2020
Ausee.com.au
