Forum sponsored by Allendale Dec 6th
Plumbing question
John Hilton11/12/2019 12:57:22
96 forum posts
20 photos
Wow. I am reading this with great interest as the OP!
I certainly have enough info to blind my accuser with science!
I did wonder - just to compound the issue - would we expect different results (within reason) if the subject was a gas which could be compressed?
keep them coming!
Howard Lewis11/12/2019 13:26:50
2588 forum posts
2 photos
For the same pressure differential between inlet and outlet, the limit on flow will, be the smaller pipe.
The longer the small diameter section is, the more the flow will decrease, because of the friction with the pipe wall. This will apply to all fluids.
If a gas is at pressure at the inlet to the minor diameter, and there is minimal back pressure at the outlet, the gas will expand, decrease in temperature. If it expands, the volume will increase.
The drop in temperature during expansion is used to liquify gases, reducing it to below its critical temperature, where recompression can liquify it.
Witness the nozzle of a CO2 fire extinguisher, which will become coated with "frost", because of the drop in temperature, condensing and freezing moisture in the surrounding air.
Gases will behave differently, depending on whether they are above or below the critical temperature, and not like liquids which are only VERY slightly compressible, when subjected to high pressures.
Howard. .
SillyOldDuffer11/12/2019 14:06:43
5002 forum posts
1061 photos
Posted by Howard Lewis on 11/12/2019 12:14:16:
Folks, are we not making mountains out of molehills?
The theoretical discussions are interesting, but do not do much to help the OP. ...
The OP was asking about a pipe between the tender and the locomotive.
The pressure available to promote flow is going to be of the order of a few inches of water, or probably less than 200 mm.
The pressure differential may be increased by the sub atmospheric effects of the injector that it feeds.
But basically, it all comes back to "Will a 1/4" pipe reduce the flow through a 3/8" pipe"?
The simple answer, in these circumstances is a common sense "YES".
As the late Rudi Mischetlager used to say "Common sense is not that common"
Remember the motto of the amateur radio world, KISS, "Keep It Simple Stupid"
Well, it depends. I prefer Einstein's 'Make everything as simple as possible but not simpler'. He also said 'If you can’t explain it, you don’t understand it well enough.'
Personally I incline to argue there is no such thing as common sense. Here's a few definitions to choose from. Common Sense is:
  • What I think you should know without any argument! (Depends on me not being an idiot.)
  • A notion shared by many people. (Depends on other people not being idiots.)
  • Anything that might be reasonably expected. (Depends on what's meant by 'reasonable'. In English Law, decided by precedence and court cases.)
  • Making sound practical decisions with no need for specialised knowledge or understanding. (Depends on the idea that experts know nothing, education is unnecessary, and experience valueless.)
  • The basic practical knowledge and judgment needed to survive. (Assumes newborn babes can survive on their own.)
  • Just as good as someone else's moral position. (Assumes it's not necessary to understand morality or ethics.)
I'm not sure John's question has been answered correctly, though I think Hopper and Robert both correctly identify the main consideration, which is the difference between a tender that's just a tank, and one containing a pump. One assumption is the tender gravity feeds water to an injector, equally valid is a tender containing a force pump for directly injecting high-pressure water into the boiler. Maybe both are wrong, could be the tender is used to fill a tea-urn on the back.
If John wanted a simple practical answer to the effect of a choke on water flowing under gravity, easy enough to do the experiment. The experiment would also find the actual relationship between choke and output volume, useful for answering a question like 'will the choked pipe enough flow to allow an injector to fill the boiler'? A rather harder question is, 'how much longer will it take to fill a boiler with a force pump if the pipe is constrained?' In the latter case, the smaller pipe may be necessary to manage the high-pressure involved, not just a casual feature.
While practical skills are high value, they are strongly reinforced by effective theory. I'm impressed by Lord Kelvin, (physicist as smart as Newton and Einstein) who is alleged to have said: 'if you can't put numbers on it, it ain't worth sh1t!'
devil
SillyOldDuffer11/12/2019 15:22:43
5002 forum posts
1061 photos
As a picture is worth a thousand words:
If the tap on the open tank is cracked open, the amount of water flowing out of the tank will be constrained. If the tap is fully opened, then more water flows but the volume is limited by the water pressure and the diameter of the outlet pipe.
In the pressured tank, something rather different happens. If the piston in the large cylinder is pushed down a fixed volume of water is transferred to the small piston, which moves much further inside its cylinder. And in reverse, pushing the small piston down moves a fixed volume of water back into the large cylinder, which pisto moves a small distance. While the presence of a choke in the pipe makes no difference to the flow, or to the movement of either piston, it does make a difference to the pressure!
Open tanks are typical of domestic water systems: water pressure at the tap is usually obtained by gravity feed from a reservoir on higher ground, not from a directly connected force pump. As a system gravity fed water is cheaper and more controllable. Most of the system runs at low pressure, up to about 10bar.
Pressured systems are typical of heating systems and Hydraulic systems like power steering and road diggers. In a hydraulic system small pipes are used to transfer energy as high-pressure water. The high-pressure is easily produced by a force pump, and the relative movement of different diameter pistons can be exploited to multiply force at the expense of movement or vice versa. The small pump on my Hydraulic engine crane allows me to lift a 1/3rd ton lathe with no trouble at all. Hydraulic systems run at much higher pressures, say 500 or 600 bar. The very high water pressure available from a simple force pump - little more than a lever operated ram in a plain cylinder - is excellent for testing boilers. Although the pressure is much higher than that produced by steam, there is very little energy stored in it. If a water pressured boiler gives way, it won't explode.
Testing a boiler by pressurising a gas is very dangerous because gas acts like a spring. If the boiler breaks, it could well explode because compressed gas contains stored energy that can be released almost instantaneously.
Gases and liquids follow the same basic rules, but the compressibility of gases cause considerable side effects compared with liquids. But designing a ship's propeller is much the same mathematically (I'm told) as designing an air-screw. They're not interchangeable though - large bladed ship propellers turn slowly in a thick fluid, while slim aircraft propellers spin fast in a thin fluid. Propellers have to be optimised to the working fluid.
Edited By SillyOldDuffer on 11/12/2019 15:24:49
Maurice Taylor11/12/2019 16:25:35
52 forum posts
4 photos
In the pressured tank example, the pressure will be the same in all areas of the tank.The small cylinder will have the same pressure acting on it as the large one.
Martin Kyte11/12/2019 16:26:39
1539 forum posts
24 photos
The essential question, with apologies to the original poster, is not will it affect the flow which of course it does, but does it matter. To answer this the require flow rate needs to be known allong with the/any downstream restrictions.
For small flow rates it's going to matter less. Zero flow would give the same static pressure regardless of the 1/4" restriction.
regards Martin
Edited By Martin Kyte on 11/12/2019 16:27:05
SillyOldDuffer11/12/2019 16:43:19
5002 forum posts
1061 photos
Posted by Maurice Taylor on 11/12/2019 16:25:35:
That must be right. So me saying 'While the presence of a choke in the pipe makes no difference to the flow, or to the movement of either piston, it does make a difference to the pressure!' must be wrong. Oh dear, now I'm confusing myself as well as everybody else.
Sackcloth and ashes AGAIN! Or I could go into politics...
blush
Hopper11/12/2019 23:51:47
3890 forum posts
83 photos
Ah. Didn't see the reference to tender in the OP on first reading.
In that case, the answer would be "It depends."
Depends on the abilities of the feed pump or injector. If it has the ability to increase the pressure differential between the two ends of the pipe by a sufficient amount then increased pressure will create increased flow through the smaller pipe, as flow is proportional to pipe radius times pressure, (all other things being equal of course).
But, if - as is often the case - the feed pump or injector is only just up to the job with a 3/8 pipe, and can not provide sufficient extra "suction" or pressure differential, the 1/4" pipe will restrict water flow.
So, disregarding frictional losses which would be somewhat minimal in such a situation, you might as well plumb the whole length in 1/4" pipe if you are going to do one section in 1/4".
The question remains: why would you even need to reduce your feed line from 3/8 to 1/4 in one place anyway? Can't you just make a bigger hole for the 3/8 pipe to pass through?
Robert Atkinson 212/12/2019 07:24:36
463 forum posts
21 photos
Posted by SillyOldDuffer on 11/12/2019 16:43:19:
blush
I think you are both correct, it depends on the condition of the system. The pressure is only constant throughout the system when it is STATIC. If anything is moving there are pressure differentials in the system.
On pressure testing with gas v liquid there is a worse case than gas, using a fluid that is gas at ambient and liquid at test pressure e.g. water over 100 deg C or LPG. With these when the pressure is released the liquid flash "boils" and expands elesing even more energy than the same volume and pressure of gas. There is a name for it "BLEVE" Boiling Liquid Expanding Vapour Explosion. Very nasty indeed especially if the fluid itself is flammable.
Robert G8RPI.
martin perman12/12/2019 15:25:09
1709 forum posts
70 photos
Gentlemen,
Arent we looking at a venturi **LINK** which happens to work with liquids and gases.
Martin P
Ausee.com.au
