Vogvivo CNC router - Is anyone using one of these?
Steve Withnell07/12/2019 15:33:57
796 forum posts
215 photos
I've been using the KX1 to produce some basic PCB's, which is overkill really and the spindle speed is a bit limiting.
Mach 3 will drive this and the spindle speed is 10k so should be better suited to cutting PCB's and I can use it on the kitchen table rather than retire to the workshop!
Some of this stuff can turn out to be junk - so anyone run one of these?
Steve
geoff adams07/12/2019 15:46:44
160 forum posts
195 photos
hi Steve cant help you but you could try the mycncuk forum i find them very helpful
Geoff
Alan Wood 408/12/2019 16:45:48
136 forum posts
5 photos
Hi Steve
I obtained a CNEST3040T from an EBay second user which seems to have some of the components that are being used on the KX1. I have found the 3040 adequate for PCB milling at 5k rpm and have also run PCBs on my Tormach 440 at similar speeds.
You might want to consider adding limit switches to allow auto homing and also to give protection from overrun within the table and Z limits. I made some modifications to Mach3 that I found on the web to accommodate this and also for a Z height setter.
I use FlatCam to convert the CAD files into G Code.
The biggest issues in running the PCBs are the type of cutter you use and how flat you can grip the board to the mill table so as to avoid variations in depth of cut.
I have done some write ups here on my findings and there are various follow up pages. If you want some more info let me know.
Kind regards
Alan
