Tom Senior M1 mill
Peter Simpson 105/12/2019 18:38:16
145 forum posts
6 photos
Does the table on an M1 mill, power drive in both directions ? If not do you have to rewind the table at each cut ?????
not done it yet05/12/2019 18:50:57
3933 forum posts
15 photos
Forgive me for asking what is likely very obvious, but how else would you get the table back to the pre-cutting position (other than by winding manually) if the power feed only operated in one direction and how would you avoid climb milling if the machine only power-feeds in one direction?
Oldiron05/12/2019 18:55:04
355 forum posts
22 photos
See here **LINK**
Hope it helps
regards
Andy Carruthers05/12/2019 19:19:24
262 forum posts
23 photos
Hi Peter,
Assuming your Mill does not have the S Type head with independent motor then X axis power drive is right to left only
With S Type head and VFD to main drive the X axis can be reversed as well as normal left to right travel
Peter Simpson 105/12/2019 19:36:59
145 forum posts
6 photos
Andy thanks for your reply, my mill does have the "S" type head. I will ensure that the main motor is driven by an inverter that I can drive backwards and forwards. "not done it yet" but will in the near future.
Andy Carruthers05/12/2019 19:59:28
262 forum posts
23 photos
Apologies, my last statement should have read ...normal right to left travel
