Ian Parkin | 02/12/2019 20:07:24 |
![]() 882 forum posts 215 photos | Has anyone any experience with Mitsubishi plcs i have 2 machines both very different which have both got the same problem the plc isn’t running and the prog light is flashing. both batteries were long dead operators say they been like that for years. i have replaced battery’s so that error has gone both machines have operated for years perfectly well one for 25 years the other 15 years do they lose the program? Is that what’s happened here? |
Mike Poole | 02/12/2019 20:58:04 |
![]() Moderator 2845 forum posts 67 photos | It’s a near certainty you have lost the program, do you have a backup and the means to load it? A paper listing would be the minimum help but manually entering it all is tedious. Mike |
Ian Parkin | 02/12/2019 21:14:43 |
![]() 882 forum posts 215 photos | Mike no nothing.... backup or means just strange that 2 machines in different locations have done the same within days of each other after working fine for years just coincidence? we will have to get machines agents in Edited By Ian Parkin on 02/12/2019 21:15:17 |
S.D.L. | 02/12/2019 21:17:11 |
229 forum posts 37 photos | Which PLC models are thet F1, F1x or rack based. If Block F series and no memeory module then no battery and power off = programe lost. Steve |
Ian Parkin | 02/12/2019 21:19:44 |
![]() 882 forum posts 215 photos | Steve i’m sure that the battery’s have been totally flat for years the dates on the ones i removed were 95 and 03 machines been switched off every night for years |
Ian Parkin | 02/12/2019 21:21:20 |
![]() 882 forum posts 215 photos | They are fx series |
S.D.L. | 04/12/2019 10:23:38 |
229 forum posts 37 photos | There isnt a run / program swith cthats someones moved.
I cant remember if FX are set to run in software or by switch.
Getting agents in sounds best bet as you said. |
